[Programmation] Arduino MPU6050
Arduino MPU6050
    invite8ec3d623
    Arduino MPU6050
    Bonjour, j'aimerais savoir où puis je trouver les valeurs de yaw pitch et roll dans ce code(pour faire bouger des ervomoteurs)
    Code:
    #include "I2Cdev.h"
      #include "MPU6050_6Axis_MotionApps20.h"
      #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
      #include "Wire.h"
      #endif
      MPU6050 mpu;
      #define OUTPUT_TEAPOT
      #define LED_PIN 13
      bool blinkState = false;
      bool dmpReady = false;
      uint8_t mpuIntStatus;
      uint8_t devStatus;
      uint16_t packetSize;
      uint16_t fifoCount;
      uint8_t fifoBuffer[64];
      Quaternion q;
      VectorInt16 aa;
      VectorInt16 aaReal;
      VectorInt16 aaWorld;
      VectorFloat gravity;
      float euler[3];
      float ypr[3];
      uint8_t teapotPacket[14] = { '$', 0x02, 0,0, 0,0, 0,0, 0,0, 0x00, 0x00, '\r', '\n' };
      volatile bool mpuInterrupt = false;
      void dmpDataReady() {
      mpuInterrupt = true;
      void setup() {
      Wire.begin();
      TWBR = 24;
      #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
      Fastwire::setup(400, true);
      #endif
      Serial.begin(38400);
      while (!Serial);
      mpu.initialize();
      devStatus = mpu.dmpInitialize();
      mpu.setXGyroOffset(220);
      mpu.setYGyroOffset(76);
      mpu.setZGyroOffset(-85);
      mpu.setZAccelOffset(1788);
      if (devStatus == 0) {
      mpu.setDMPEnabled(true);
      attachInterrupt(0, dmpDataReady, RISING);
      mpuIntStatus = mpu.getIntStatus();
      dmpReady = true;
      packetSize = mpu.dmpGetFIFOPacketSize();
      } else {
      Serial.print(F("DMP Initialization failed (code "));
      Serial.print(devStatus);
      Serial.println(F(")"));
      pinMode(LED_PIN, OUTPUT);
      void loop() {
      if (!dmpReady) return;
      while (!mpuInterrupt && fifoCount < packetSize) {
      // other program behavior stuff here
      fifoCount = mpu.getFIFOCount();
      if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
      mpu.resetFIFO();
      Serial.println(F("FIFO overflow!"));
      } else if (mpuIntStatus & 0x02) {
      while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
      mpu.getFIFOBytes(fifoBuffer, packetSize);
      fifoCount -= packetSize;
      #ifdef OUTPUT_TEAPOT
      teapotPacket[2] = fifoBuffer[0];
      teapotPacket[3] = fifoBuffer[1];
      teapotPacket[4] = fifoBuffer[4];
      teapotPacket[5] = fifoBuffer[5];
      teapotPacket[6] = fifoBuffer[8];
      teapotPacket[7] = fifoBuffer[9];
      teapotPacket[8] = fifoBuffer[12];
      teapotPacket[9] = fifoBuffer[13];
      Serial.write(teapotPacket, 14);
      teapotPacket[11]++;
      #endif
      blinkState = !blinkState;
      digitalWrite(LED_PIN, blinkState);
    invitef86a6203
    Re : Arduino MPU6050
    Code:
    math   English Français     commande
    X      roll     (roulie)    aileron
    Y      pitch    (tanguage)  profondeur
    Z      yaw      (lacet)     palonnier
    à condition de respecter le sens qui est donné par le datasheet du MPU50
    X le sens des écritures ,
    y le haut et bas de l'écriture et
    Z dessus ,dessous le chip.
    https://www.quora.com/How-do-I-calcu...-accelerometer
    voir un exemple plus simple ici;
    http://electronics.stackexchange.com...s-from-mpu6050
    invite8ec3d623
    Merci d'avoir répondu.
    J'ai essayer avec le code http://electronics.stackexchange.com...s-from-mpu6050 cependant impossible de trouver le yaw(et le suppose que le pitch et roll sont ry et rz)
    invitef86a6203
    Cette ligne
    // collect readings
    accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    Ce sont les données qui viennent du gyro
    g pour gyro
    a pour accel
    Dans leur prog ils calculent un angle pour chaque axe.
    invitef86a6203
    Pour les x,y,z si tu respecte le sens du datasheet (image ci jointe) ce sera les même , sinon il faudra les mettre en correspondance.
    Il suffit de connecter le port série et envoyer les données pour voir ce qui bouge...
    invite8ec3d623
    Oui c'est ce que j'ai fais, mais on ne capte pas les yaw avec ces codes, j'avais déjà cherché avant d'ouvrir ce post et j'ai testé plein de code mais 1 seul trouve le yaw(car il le met en action grâce a processing et le teapot) et c'est celui que j'ai posté c'est pourquoi je voulais savoir ou se trouvait les informations (yaw pitch et roll) dans ce code.
    invitef86a6203
    vérifie ton câblage peut être une erreur!
    Personnellement j'ai testé la librairie avec l'exemple ça a fonctionné.
    gx,gy,gz pour le gyro
    ça envoie sur le port série.
    invite8ec3d623
    bon alors ça fais 3 jours que je me casse la tête la dessus, et là j'ai tout bien refait(branchement, retéléchargement des programmes) ET ça marche enfin.
    Merci à toi.
    Une dernière question pense tu que grâce a ce systeme je peux capter les mouvement de mon bras ?
  1. [Numérique] Pas de réponse du MPU6050 par I2C
    Par invite81681e58 dans le forum Électronique
    Dernier message: 23/06/2016, 07h05
  2. (Arduino) problème de téléversement de programme Arduino
    Par invite3e4197b0 dans le forum Électronique
    Dernier message: 17/05/2016, 09h28
  3. Carte Arduino UNO R3 ou Arduino Mega 2560 R3 ?
    Par invite94b5085f dans le forum Électronique
    Dernier message: 11/03/2015, 15h36
  4. Arduino anti rebond avec arduino
    Par invited0bffa74 dans le forum Électronique
    Dernier message: 23/10/2014, 17h04
  5. Communication arduino-arduino avec module Xbee
    Par inviteda9a8a4b dans le forum Électronique
    Dernier message: 23/12/2013, 17h24
