Eclipse 3.4.0: type error class not found : XrayLogger
    invite2003a1d4
    je suis actuellement en train de suivre un tutorial expliquant comment développer une application AS2 en utilisant Eclipse, Ant et X-Ray pour debugger.
    Voici le code utiliser:
    Code:
    import com.mosesSupposes.fuse.ZigoEngine;
    import com.mosesSupposes.fuse.FuseItem;
    import com.mosesSupposes.fuse.PennerEasing;
    import com.mosesSupposes.fuse.Fuse;
    import com.blitzagency.xray.util.XrayLoader;
    import com.dynamicflash.utils.Delegate;
    import com.mosesSupposes.fuse.Shortcuts;
    import com.blitzagency.xray.util.MtascUtility;
    import com.blitzagency.xray.logger.*;
    class com.friendsofed.recipeviewer.RecipeViewer
    private var baseClip:MovieClip;
    private var log:XrayLogger = new XrayLogger();
    public static function main(base:MovieClip) : Void
    var app:RecipeViewer = new RecipeViewer(base);
    public function RecipeViewer(base:MovieClip)
    baseClip = base;
    XrayLoader.addEventListener( XrayLoader.LOADCOMPLETE, this,"startApp");
    XrayLoader.addEventListener( XrayLoader.LOADERROR, this,"startApp");
    XrayLoader.loadConnector("xrayConnector_1.6.3.swf",base,true);
    public function startApp() : Void
    log.debug("this is a log message using log.debug()");
    trace("this is a log message using trace()");
    ZigoEngine.simpleSetup(Shortcuts,FuseItem,PennerEasing);
    var tf:TextField = baseClip.createTextField("testField",1,50,10,200,200);
    tf.text = "Hello World.";
    var f:Fuse = new Fuse();
    f.push({target:tf, start_y:1000, y:0, duration:6,ease:"easeOutBounce"});
    f.start();
    et le fichier build.xml:
    Code HTML:
    <project name="RecipeViewer">
    	<taskdef name="mtasc" classname="org.as2lib.ant.Mtasc" />
    	<property name="mtasc" location="C:/FlashTools/mtasc-1.14/mtasc" />
    	<property name="deploy.dir" location="C:" />
    	<property name="lib.dir" location="../lib" />
    	<property name="src.dir" location="src" />
    	<target name="build">
    		<mkdir dir="builds" />
    		<mtasc mtasc="${mtasc}"
    		version="8"
    		main="true"
    		header="800:600:30"
    		src="com/friendsofed/recipeviewer/RecipeViewer.as"
    		classpath="${src.dir} ; ${lib.dir}"
    		swf="builds/RecipeViewer.swf" />
    	</target>
    	<target name="buildAndCopy" depends="build">
    		<mkdir dir="${deploy.dir}/recipe_viewer" />
    		<copy todir="${deploy.dir}/recipe_viewer" >
    		<fileset dir="builds" />
    		</copy>
    	</target>
    </project>
    Lorsque je lance le programme, voici ce qu'il me ressort:
    Code:
    Buildfile: C:\Eclipse\Recette\recipe-viewer\build.xml
    build:
    [mtasc] Compiling 1 source file.
    [mtasc] C:\FlashTools\mtasc-1.14\mtasc -swf C:\Eclipse\Recette\recipe-viewer\builds\RecipeViewer.swf -header 800:600:30 -version 8 -cp C:\Eclipse\Recette\recipe-viewer\src -cp C:\Eclipse\Recette\lib -main com\friendsofed\recipeviewer\RecipeViewer.as
    [mtasc] C:\Eclipse\Recette\recipe-viewer\src/com/friendsofed/recipeviewer/RecipeViewer.as:14: characters 8-15 : type error class not found : XrayLogger
    BUILD FAILED
    C:\Eclipse\Recette\recipe-viewer\build.xml:15: Compile error!
    Total time: 656 milliseconds
    Ce que je crois comprendre, c'est que je n'ai pas réussi à suivre complètement les indications. Notemment, celle-ci:
    If you’ve configured the execute connection, you already have some of the logger connection functionality
    enabled. You can create a log variable of type XrayLogger in your class:
    Then you can use the debug(), warn(), and so on, methods to display debug information. The other
    mechanism of logging requires you to change an MTASC compile option. To set that up, follow these
    steps:
    1. In Eclipse, right-click your project, and select Properties.
    2. Select the AS2 Builder option on the left.
    3. Select the RecipeViewer builder from the grid, and click the Edit button.
    4. In the Trace Function field, enter com.blitzagency.xray.util.Mtas cUtility.trace.
    5. Click the OK button to accept your change.
    Je ne parviens pas à trouver l'onglet: "Trace Function field" dont ils parlent dans ce tutorial.
    Est-ce que quelqu'un aurait une idée à ce propos, s'il vous plait?
    Merci d'avance et à bientôt,
    Etienne.
    invite2003a1d4
    Re : Eclipse 3.4.0: type error class not found : XrayLogger
    Re-Hello,
    alors en fait, j'ai modifié le fichier build.xml en remplaçant la ligne suivante:
    Code HTML:
    par celle-ci:
    Code HTML:
     <property name="lib.dir" location="C:\flashtools\lib" />
    Pas besoin de chercher si vous aviez commencé.
    A bientôt, pour de vraies questions,
    Etienne.
  1. Routeur WL-122 : No valid web file system found
    Par Damon dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 03/10/2008, 14h15
  2. Réponses: 42
    Dernier message: 19/11/2007, 21h08
  3. DD 100Gb - Operation System not found
    Par invitea301fcd6 dans le forum Matériel - Hardware
    Réponses: 21
    Dernier message: 08/01/2007, 16h34
  4. registax : compressor not found.....?
    Par invite2b184cb4 dans le forum Matériel astronomique et photos d'amateurs
    Dernier message: 10/07/2006, 12h12
  5. New species found in Papua 'Eden'
    Par invitef0ba6147 dans le forum Biologie
    Dernier message: 07/02/2006, 15h50
