Votre avis sur le travail de Pope et al. 2007
    invite78d2ef62
    J'ai une question précise, concernant un travail récent de Pope et al. 2007 (abstract ci-dessous). En substance, les auteurs considèrent si je comprends bien que le taux de photolyse du Cl2O2 a été surévalué d'un facteur six et concluent que si leurs calculs sont bons, 60% du "trou" dans l'ozone stratosphérique sont inexpliqués par nos modèles.
    Ce travail est sérieux vu son journal de publication, mais quelle est au juste sa portée selon vous? Est-il discuté chez les spécialistes depuis mai? A-t-il été répliqué par des équipes indépendantes?
    Merci d'avance (et bravo pour la clarté et la qualité de votre vulgarisation ici).
    Charles Muller
    J Phys Chem A. 2007 May 3; : 17474723
    Ultraviolet Absorption Spectrum of Chlorine Peroxide, ClOOCl.
    Francis Pope , Jaron Hansen , Kyle Bayes , Randall Friedl , Stanley Sander
    The photolysis of chlorine peroxide (ClOOCl) is understood to be a key step in the destruction of polar stratospheric ozone. This study generated and purified ClOOCl in a novel fashion, which resulted in spectra with low impurity levels and high peak absorbances. The ClOOCl was generated by laser photolysis of Cl2 in the presence of ozone, or by photolysis of ozone in the presence of CF2Cl2. The product ClOOCl was collected, along with small amounts of impurities, in a trap at about -125 degrees C. Gas-phase ultraviolet spectra were recorded using a long path cell and spectrograph/diode array detector as the trap was slowly warmed. The spectrum of ClOOCl could be fit with two Gaussian-like expressions, corresponding to two different electronic transitions, having similar energies but different widths. The energies and band strengths of these two transitions compare favorably with previous ab initio calculations. The cross sections of ClOOCl at wavelengths longer than 300 nm are significantly lower than all previous measurements or estimates. These low cross sections in the photolytically active region of the solar spectrum result in a rate of photolysis of ClOOCl in the stratosphere that is much lower than currently recommended. For conditions representative of the polar vortex (solar zenith angle of 86o, 20 km altitude, and O3 and temperature profiles measured in March 2000) calculated photolysis rates are a factor of 6 lower than the current JPL/NASA recommendation. This large discrepancy calls into question the completeness of present atmospheric models of polar ozone depletion.
    invite68a2854d
    Re : Votre avis sur le travail de Pope et al. 2007
    Là vous me piégez car je n'ai pas eu connaissance de cette publication. Vue sa date de publication, elle n'a pas été prise en compte pour les conclusions du rapport de WMO-UNEP sur l'état de la couche d'ozone qui donne l'état des connaissances aujourd'hui. il faut savoir que les chimistes de laboratoire, dont je ne fais pas partie, n'arrêtent pas leur mesure sous prétexte que l'on vient de publier un rapport, même si les résultats des modèles sont en relativement bon accord avec les observations. Donc la banque de données spectroscopiques JPL/NASA s'enrichit tous les jours de nouvelles mesures que les modélistes vont maintenant incorporer dans leur modèles, mais je n'ai pas entendu parler de grands bouleversements dans les conclusions qui faisaient foi il y a quelques mois.
    La science avance tous les jours et toute nouvelle mesure a besoin de confirmation par d'autres équipes pour être crédible!
    M.-L. chanin
  1. Votre avis sur...
    Par invite69682400 dans le forum Lectures scientifiques
    Dernier message: 20/09/2007, 11h13
  2. Dnnez Votre Avis Sur Sujet Tipe 2006/2007
    Par invite8763d9a9 dans le forum TPE / TIPE et autres travaux
    Dernier message: 28/04/2006, 18h07
  3. Votre avis sur free
    Par inviteffd52f3c dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 28/08/2003, 22h37
  4. Votre avis sur XP familial
    Par inviteffd52f3c dans le forum Logiciel - Software - Open Source
    Réponses: 19
    Dernier message: 22/08/2003, 13h35
