Nouveau type de PAN* ?
    invite2bab68d1
    Bonjour à tous/toutes,
    Je ne savais ou poster le sujet mais la section "physique" m'a semblé la plus adaptée.
    * Selon Wiki : Phénomène aérospatial non identifié (PAN) est un terme qui désigne un quelconque phénomène atmosphérique voire extra-atmosphérique observé dont la nature n'a pu ou pas encore pu trouver d'explication.
    J'en ai peut-être un à vous proposer et je suis sur une piste :
    http://www.youtube.com/watch?v=1IAGE9f0K1Q
    http://www.youtube.com/watch?v=1Z_-uK5Btik
    http://www.youtube.com/watch?v=Sc9Ks6H3coY
    http://www.youtube.com/watch?v=cUcH3VClzUI
    http://www.youtube.com/watch?v=b6BSz...eature=related
    La piste :
    The alignment of ice crystals in changing electric fields
    Purchase
    $ 31.50
    T. C. FosterE-mail The Corresponding Author, 1 and J. HallettCorresponding Author Contact Information, E-mail The Corresponding Author
    Desert Research Institute, 2215 Raggio Parkway, Reno, NV 89512, USA
    Received 1 August 2001;
    accepted 1 December 2001.
    Available online 14 February 2002.
    Abstract
    Orientation of ice crystals in the form of thin plates (diameter up to 30 μm, thickness 0.5 to a few μm) was investigated optically for crystals nucleated in a supercooled cloud in a laboratory cold chamber. Random orientation caused by Brownian rotation of small crystals (apparent as twinkling) and alignment caused by airflow resulting from fall motion of larger crystals was changed by application of an electric field either as a step or as an oscillating square wave of variable frequency of order 1–10 Hz. Video records and time exposed still photographs demonstrated crystal fall, oscillation, and orientation changes with electric field magnitude and frequency. Thin film interference colours provided crystal thickness, mass, and moment of inertia. Realignment began for electric fields greater than 0.5–1 kV/m and was complete above 10 kV/m. Measurements of degree of alignment (from random orientation to completely parallel to the electric field) and its time dependence (of order tenths of seconds) are consistent with predictions of a theoretical oscillator model based on electrical torques on ellipsoids in viscous air. In a changing electric field at low frequency, the crystal realignment varies along with the variation field and at high frequency they remain aligned along the average field. These results are applied to larger crystals as occur in the atmosphere with implication for remote sensing of ice by radar and lidar as influenced by local electric fields and with the possibility of their remote measurement by optical observation of changing crystal orientations.
    Source : http://www.sciencedirect.com/science...6980950200008X
    Sachant que la luminosité visible des cristaux de glace (via un changement d'alignement) en suspension peut-être influencée par les mouvements d'air (le fameux airflow ?) mais aussi par des champs électrostatiques ayant une valeur > 1V/mm, je présume qu'il serait peut-être souhaitable d'envoyer ces vidéos à ces chercheurs (?).
    Qu'en pensez-vous ?
    Europa73
    obi76
    Re : Nouveau type de PAN* ?
    Citation Envoyé par Europa73 Voir le message
    pourquoi ? Une vidéo sur youtube n'est pas une preuve. Mieux vaut mettre des résultats d'expériences menées en laboratoire que des phénomènes peut être truqués ou du à la vieillesse des VHS ou autre, et dont on ne connait même pas la source.
    Dernière modification par obi76 ; 09/08/2011 à 10h08.
    phys4
    Merci pour ces très belles vidéos.
    Pour deux au moins d'entre elles, nous observons la formation de nuages de cristaux de glace au sommet de cumulonimbus. Très spectaculaire en rétro-éclairage.
    obi76
    J'en rajoute une couche pour ne pas qu'on se méprenne sur ce que j'ai dis. Ces vidéos ne sont pas forcément truquées (apparemment elles ne le sont pas), mais lorsqu'on écrit un papier, on ne cite pas des choses dont on ne connait pas la provenance, et dont on n'a pas la certitude de leur validité.
    invite2bab68d1
    Salut Obi76,
    Je vous comprend tout à fait concernant la validité de vidéos trouvées sur le net.
    Ceci étant dit, je me demande tout simplement si ce qui a été filmé pourrait tout simplement avoir un rapport avec la publication que j'ai cité.
    Le phénomène n'a jamais été filmé (par des scientifiques) à ma connaissance...
    Europa
    invitecf9c25ff
    bonjour. laisse tomber retouche.d image. il y a deux. deux images supperposees.
    salut
  1. Nouveau type de virus
    Par invite72e9f130 dans le forum Sécurité et malwares : désinfectez votre machine
    Dernier message: 26/02/2010, 19h26
  2. Nouveau type de dessin astro
    Par invite5ab5786e dans le forum Matériel astronomique et photos d'amateurs
    Dernier message: 14/09/2007, 21h15
  3. Un nouveau type de Newton ???
    Par invite1c713433 dans le forum Matériel astronomique et photos d'amateurs
    Dernier message: 21/07/2006, 21h33
  4. nouveau type de connection internet
    Par invitead62cfd3 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 23/04/2005, 18h08
