algorithme sur mikrobasic
    invite32a797f3
    Bnjr tt le monde je veux réaliser un algorithme sur mikrobasic qui compte le nombre de tours a partir de deux capteurs qui on deux signaux a et b ( prend en compte le sens de rotation du moteur cad incrémentation ou décrementation) puis l'affiché sur LCD j'ai fais se si et ca ne marche pas aider moi stp
    Code:
    program xd
     dim LCD_RS as sbit at RB0_bit
         LCD_EN as sbit at RB1_bit
         LCD_D4 as sbit at RB2_bit
         LCD_D5 as sbit at RB3_bit
         LCD_D6 as sbit at RB4_bit
         LCD_D7 as sbit at RB5_bit
        LCD_RS_Direction as sbit at TRISB0_bit
        LCD_EN_Direction as sbit at TRISB1_bit
        LCD_D4_Direction as sbit at TRISB2_bit
        LCD_D5_Direction as sbit at TRISB3_bit
        LCD_D6_Direction as sbit at TRISB4_bit
        LCD_D7_Direction as sbit at TRISB5_bit
    dim Char_Tours as string [3]
    dim Nb_Tours as byte
    dim Nb_Tours_P as byte
    dim  Compteur as word
    dim AB_state  as byte
    dim A as sbit at RA0_bit
    dim B as sbit at RA1_bit
    dim AA as sbit at AB_State.0
    dim AP as sbit at AB_State.1
    dim BA as sbit at AB_State.2
    dim BP as sbit at AB_State.3
    ' End Lcd module connections
    dim txt1 as char[8]
        txt2 as char[7]
     i   as byte            ' Loop variable
    sub procedure Move_Delay()       ' Function used for text moving
      Delay_ms(500)                  ' You can change the moving speed here
    end sub
    main:
       ADCON1 = 0x07                     ' Configure AN pins as digital I/O
       ADCON0 = 0x00
       PORTA = 0x00
       TrisA=0x00
      PORTB = 0xFF
      TRISB = 0xFF
      txt1 ="NB.Tours:"
      txt2 ="NB.Tours:"
      Lcd_Init()                     ' Initialize Lcd
      Lcd_Cmd(_LCD_CLEAR)            ' Clear display
      Lcd_Cmd(_LCD_CURSOR_OFF)       ' Cursor off
      Lcd_Out(1,1,txt1)              ' Write text in first row
      Lcd_Out(1,11,Char_Tours)              ' Write text in second row
      Delay_ms(2000)
      while TRUE                     ' Endless loop
          if
            AA <> A then
            AP=AA
            AA=A
          end if
          if
            BA <> B then
            BP=BA
            BA=B
          end if
          if ((AP=0) and (BP=0))     then
              if ((AA=1) and (BA=0)) then
               Compteur = Compteur +1
              end if
              if ((AA=0) and (BA=1))   then
                Compteur = Compteur -1
              end if
          end if
          if ((Ap=1) and (BP=0))     then
              if ((AA=1) and (BA=1)) then
              end if
              if ((AA=0) and (BA=0))     then
              end if
          end if
          if ((Ap=1) and (BP=1))     then
              end if
              if ((AA=1) and(BA=0))     then
              end if
          end if
          if ((Ap=0) and (BP=1))     then
              end if
              end if
          end if
              NB_Tours_P = NB_Tours
              NB_Tours = Compteur div 4
          if  NB_Tours_P <> NB_Tours then
              byteToStr ( Nb_Tours , Char_Tours)
              Lcd_out (1,11,Char_Tours)
          end if
      wend
    end.
    Dernière modification par JPL ; 29/04/2013 à 14h46. Motif: Ajout de la balise Code (#) pour garder l'indentation et changement du titre
    JPL
    Re : algorithme sur mikrobasic
    À transférer éventuellement en Électronique ?
    invite32a797f3
    j'ai rien reçu !!
    JPL
    Ce n'est ni une hot line ni un service après-vente. Il faut que tu attendes que quelqu'un capable de t'aider passe sur le forum.
    invite32a797f3
    ui je sais m'ai vraiment j'ai besion d'aide car je compte sur vous et je ss un etudiant et j fais mon projet fin d'etude
    Jack
    Citation Envoyé par vdicc_86 Voir le message
    Ca n'empêche pas de lire et respecter la charte (les titres doivent être explicites, pas de doublon) et les règles particulières à chaque forum (balises code)
    merci d'en tenir un peu plus compte à l'avenir
  1. Théorie de l'existence du monde physique en parallèle du monde virtuel
    Par invitef992f14c dans le forum Epistémologie et Logique (archives)
    Réponses: 28
    Dernier message: 17/04/2011, 11h03
  2. monde virtuel/monde réel?
    Par invite02d60949 dans le forum Discussions scientifiques
    Dernier message: 01/07/2010, 22h52
  3. bnjr
    Par invite4318cb4b dans le forum Environnement, développement durable et écologie
    Dernier message: 15/01/2009, 19h21
