jointure table PHP
jointure table PHP
    invitebfa037be
    jointure table PHP
    J'ai réaliser une jointure de la table user et de la table services mais j'aimerais savoir si elle est correcte et savoir ce que je peux arranger dans mon code php car la jointure ne fonctionne pas.
    J'utilise le MVC multiple.
    Merci d'avance.
    Code HTML et PHP :
    Code HTML:
    <div class="container">
        <form action="index.php?controller=user&action=list" method="POST">
            <div class="form-group">
                <label for="parm0">id_user</label>
                <input class="form-control" id="parm0" name="parm0" type="text" readonly value="{parm0}"/>
            </div>
                <label for="parm1">Nom</label>
                <input class="form-control" id="parm1" name="parm1" type="text" {readonly} value="{parm1}"/>
            </div>
                <label for="parm2">Prénom</label>
                <input class="form-control" id="parm2" name="parm2" type="text" {readonly} value="{parm2}"/>
            </div>
                <label for="id_services">id_services</label>
                <select name="id_services" id="id_services">
                    <?php
                    const SERVER = "sqlprive-pc2372-001.p******************";
                    const USER = "ce***********";
                    const PASSWORD = "t**********";
                    const BASE ="c********";
                      $connexion = new PDO("mysql:host=" . self::SERVER . ";dbname=" . self::BASE, self::USER, self::PASSWORD);
                            $requete = "SELECT user.id_user,
                                        user.Nom, user.Prenom,
                                        user.id_services,services.Services
                                        FROM user
                                        INNER JOIN services
                                        ON user.id_user=services.id_services";
                            $resultat = $connexion->query($requete);
                            $liste = $resultat->fetchAll(PDO::FETCH_ASSOC);
                            foreach($liste as $donnee){
                                $valeur = $donnee['id_services'];
                                echo "<option value='".$valeur."'>" . $donnee['id_services'] . "</option>";
                </select>
            </div>
                <button class="btn btn-primary" type="submit" id="action" name="action" value="{action}">{lib_action}</button>
            </div>
        </form>
    </div>
    Code PHP:
    <?php
    class UserView {
        private
    $page;
        public function
    __construct(){
    $this->page = $this->searchHTML('header');
    $this->page .= $this->searchHTML('nav');
        public function
    displayList($list){
    $this->page .= "<h3>Vous êtes sur la page User</h3>";
    $tableau = '<div class="container">'
    . '<table class="table table-striped table-bordered" cellspacing="0">'
    . '<thead>'
    . '<th>Nom</th><th>Prénom</th><th>id_services</th><th>Modifier</th><th>Supprimer</th>'
    . '</thead><tbody>';
            foreach (
    $list as $ligne){
    $tableau .= "<tr><td>$ligne[1]</td>"
    ."<td>$ligne[2]</td>"
    ."<td>$ligne[3]</td>"
    ."<td><a href='index.php?controller=user&action=formUpdate&parm0=$ligne[0]&parm1=$ligne[1]&parm2=$ligne[2]&parm3=$ligne[3]'><svg xmlns='http://www.w3.org/2000/svg' width='16' height='16' fill='currentColor' class='bi bi-pencil' viewBox='0 0 16 16'>
                <path fill-rule='evenodd' d='M12.146.146a.5.5 0 0 1 .708 0l3 3a.5.5 0 0 1 0 .708l-10 10a.5.5 0 0 1-.168.11l-5 2a.5.5 0 0 1-.65-.65l2-5a.5.5 0 0 1 .11-.168l10-10zM11.207 2.5L13.5 4.793 14.793 3.5 12.5 1.207 11.207 2.5zm1.586 3L10.5 3.207 4 9.707V10h.5a.5.5 0 0 1 .5.5v.5h.5a.5.5 0 0 1 .5.5v.5h.293l6.5-6.5zm-9.761 5.175l-.106.106-1.528 3.821 3.821-1.528.106-.106A.5.5 0 0 1 5 12.5V12h-.5a.5.5 0 0 1-.5-.5V11h-.5a.5.5 0 0 1-.468-.325z'/>
              </svg></a></td>"
    ."<td><a href='index.php?controller=user&action=formDelete&parm0=$ligne[0]&parm1=$ligne[1]&parm2=$ligne[2]&parm3=$ligne[3]'><svg xmlns='http://www.w3.org/2000/svg' width='16' height='16' fill='currentColor' class='bi bi-trash' viewBox='0 0 16 16'>
                <path d='M5.5 5.5A.5.5 0 0 1 6 6v6a.5.5 0 0 1-1 0V6a.5.5 0 0 1 .5-.5zm2.5 0a.5.5 0 0 1 .5.5v6a.5.5 0 0 1-1 0V6a.5.5 0 0 1 .5-.5zm3 .5a.5.5 0 0 0-1 0v6a.5.5 0 0 0 1 0V6z'/>
                <path fill-rule='evenodd' d='M14.5 3a1 1 0 0 1-1 1H13v9a2 2 0 0 1-2 2H5a2 2 0 0 1-2-2V4h-.5a1 1 0 0 1-1-1V2a1 1 0 0 1 1-1H6a1 1 0 0 1 1-1h2a1 1 0 0 1 1 1h3.5a1 1 0 0 1 1 1v1zM4.118 4L4 4.059V13a1 1 0 0 0 1 1h6a1 1 0 0 0 1-1V4.059L11.882 4H4.118zM2.5 3V2h11v1h-11z'/>
              </svg></a></td></tr>"
    $tableau .= "</tbody></table><a class='btn btn-primary' href='index.php?controller=user&action=add' role='button'>Ajouter un utilisateur</a></div>";
    $this->page .= $tableau;
    $this->display();
        public function
    displayAdd(){
    $this->page .= "<h3>Vous êtes sur la page d'ajout d'un utilisateur</h3>";
    $paramatres = array(
    "readonly"=>"",
    "parm0"=>"",
    "parm1"=>"",
    "parm2"=>"",
    "parm3"=>"",
    "action"=>"add",
    "lib_action"=>"Ajouter");
    $this->displayForm($paramatres);
        public function
    displayUpdate($id){
    $this->page .= "<h3>Vous êtes sur la page de modification d'un utilisateur</h3>";
    "readonly"=>"",
    "parm0"=>$id['id_user'],
    "parm1"=>$id['Nom'],
    "parm2"=>$id['Prenom'],
    "parm3"=>$id['id_services'],
    "action"=>"update",
    "lib_action"=>"Modifier");
        public function
    displayDelete($id){
    $this->page .= "<h3>Vous êtes sur la page de suppression d'un utilisateur</h3>";
    "readonly"=>"readonly",
    "action"=>"delete",
    "lib_action"=>"Supprimer");
        private function
    displayForm($paramatres){
    $this->page .= "<h3>Formulaire</h3>";
    $this->page .= $this->searchPHP('userForm');
    $this->page = str_replace("{readonly}", $paramatres["readonly"], $this->page);
    $this->page = str_replace("{parm0}", $paramatres["parm0"], $this->page);
    $this->page = str_replace("{parm1}", $paramatres["parm1"], $this->page);
    $this->page = str_replace("{parm2}", $paramatres["parm2"], $this->page);
    $this->page = str_replace("{parm3}", $paramatres["parm3"], $this->page);
    $this->page = str_replace("{action}", $paramatres["action"], $this->page);
    $this->page = str_replace("{lib_action}", $paramatres["lib_action"], $this->page);
    $this->display();
        public function
    display(){
    $this->page .= $this->searchHTML('footer');
            echo
    $this->page;
        private function
    searchHTML($filename){
    $content = file_get_contents('../MVC/view/html/'.$filename.'.html');
            return
    $content;
        private function
    searchPHP($filePHP){
    $content = file_get_contents('../MVC/view/html/'.$filePHP.'.php');
            return
    $content;
    Dernière modification par JPL ; 30/03/2021 à 14h36.
    umfred
    Re : jointure table PHP
    tu lies les 2 tables par le fait que user.id_user correspond à services.id_services, (un id user est un id service ??)
    tu devrais les lier par user.id_services=services.id_s ervices
  1. comment faire un sum et jointure de table?
    Par noam dans le forum Programmation et langages, Algorithmique
    Dernier message: 23/06/2017, 11h48
  2. access- jointure de 2 tables
    Par ivgu1939 dans le forum Programmation et langages, Algorithmique
    Dernier message: 11/11/2016, 15h30
  3. jointure mysql probleme
    Par invitec7fd8fb0 dans le forum Programmation et langages, Algorithmique
    Dernier message: 04/09/2011, 21h53
  4. Jointure mur de pierre / mur de placo
    Par invite71ba1ae6 dans le forum Bricolage et décoration
    Dernier message: 06/05/2010, 07h44
  5. Jointure semantique SQL connect
    Par invite0f3760c9 dans le forum Logiciel - Software - Open Source
    Dernier message: 27/04/2008, 12h38
