Edp
Edp
    turbulent
    Edp
    Bonjour;
    Merci de m'expliquer pourquoi j'obtiens des valeurs en nombres complexes pour F et f.
    Code:
    clc;clear all;close all;
    %%%%Geometry of domain%%%%%%%%%%%
    W=1.95; % width of domain
    L=1.22; %  High of domain
    Hs=.85;
    %Nr=55;%51; %No of grids in x diretcion
    Nr=55;
    Nz=55; %101;%No of grids in z diretcion
    dr=W/(Nr-1); % width of element
    dz=L/(Nz-1); % height of element
    nt = 10;
    dt=1;
    ks=0.0045949074;
    nV=4;
    mV=1-1/nV;
    alphaV=9;
    thetas=.43;
    thetar=0;
    %x=(0:Nr)*dr; y=(0:Nz)*dy; % x , y values on the grid
    %%%% Boundary conditions %%%
    F=ones(Nr,Nz);%zeros(Nr,Nz);%
    Ss=ones(Nr,Nz);
    f=zeros(Nr,Nz);
    wt=ones(Nr,Nz);
    C=zeros(Nr,Nz);
    k=zeros(Nr,Nz);
    T=20;
    Z=[0:dz:L];
    F(Nr,:)=1.22;
    Ndt=round(T/dt); % Nombre de pas de temps
    t=0;
    for nz=1:Nz
      f(Nr,:)=.305 - nz*dz;
    end
    %k(Nr,:)=1000*ks;
    k(Nr,:)=ks;
    F(round(.122/dr):round(1.95/dr),1)=F(round(.122/dr):round(1.95/dr),2); %Bottom condition for F
    f(round(.122/dr):round(1.95/dr),1)=F(round(.122/dr):round(1.95/dr),1); %Bottom condition for f
    k(round(.122/dr):round(1.95/dr),1)=0; %Bottom condition for k
    F(round(.122/dr):round(1.95/dr),Nz)=F(round(.122/dr):round(1.95/dr),Nz-1); %Top condition for F
    %f(round(.122/dr):round(1.95/dr),Nz)=0;
    %k(round(.122/dr):round(1.95/dr),Nz)=1000*ks; %Top condition for k
    F(round(.122/dr),1:round(0.305/dz))=0.305;
    F(1,1:round(0.305/dz))=0.305;
    for nz=1:round(1.22/dz)
      f(round(1.95/dr),nz)=0.305;
    end
    for nz=1:round(0.305/dz)
      f(round(.122/dr),nz)=0.305-nz*dz;
    end
    k(round(.122/dr),1:round(.305/dz))=1000*ks;
    k(1,1:round(.305/dz))=1000*ks;
    for nz=round(.305/dz):round(Hs/dz)
      F(round(.122/dr),nz)=nz*dz;
      f(round(.122/dr),nz)=0;
      k(round(.122/dr),nz)=1000*ks;
      F(1,nz)=nz*dz;
      %f(1,nz)=0;
      k(1,nz)=1000*ks;
    end
    for nz=round(Hs/dz):Nz
      F(round(.122/dr),nz)=F(round(.122/dr)-1,nz);
      %f(round(.122/dr),nz)=F(round(.122/dr)+1,nz);
    end
    %%%%% Computation %%%%%%%%
    f_old=f;
    %F_intial=F;
    f_intial=f;
    %k_initial=k;
    Gauss_Seidel_iteration = 1;
    for nx=1:Ndt % Incrément de temps
      t=t+dt;
      tolerance=1e-5;
      Iter=0;
      for m = 1:nt
        %error = 9e-9;
        error=.5;
        while(error > tolerance)
        %Iter=Iter+1;
        %disp(Iter);
        %Hold=F;
        for nz=2:Nz-1
          for nx=round(.122/dr)+1:Nr-1
            a=(k(nx,nz)+k(nx,nz-1))/(2*dz^2);
            b=((dr*nx).*k(nx,nz)+(dr*(nx-1)).*k(nx-1,nz))./(2*(dr*nx)*dr^2);
            d=((dr*nx).*k(nx,nz)+(dr*(nx+1)).*k(nx+1,nz))./(2*(dr*nx)*dr^2);
            e=(k(nx,nz)+k(nx,nz+1))/(2*dz^2);
            f1=C(nx,nz)/dt;
            g=-(k(nx,nz+1)+k(nx,nz-1))/(2*dz);
            c=-(a+b+d+e+f1);
            f(nx,nz)=-[a.*f(nx,nz-1)+b.*f(nx-1,nz)+d.*f(nx+1,nz)+e.*f(nx,nz+1)+f1.*f_old(nx,nz)+g]./c;
            Ss(nx,nz)=(1+(alphaV*abs(min(f(nx,nz),0))).^nV).^(-mV);
            %Ss(nx,nz)=(1+(-alphaV*f(nx,nz))^nV)^(-mV);
            C(nx,nz)=alphaV*(thetas-thetar)*(nV-1)*(alphaV*abs(min(f(nx,nz),0))).^(nV-1)./...
            ((1+(alphaV*abs(min(f(nx,nz),0))).^nV).^((2*nV-1)/nV));
            % C(nx,nz)=alphaV*(thetas-thetar)*(nV-1)*(Ss(nx,nz).^(nV/(nV-1))-1).^((nV-1)/nV)./...
            %((Ss(nx,nz)).^((1-2*nV)/(nV-1)));
            k(nx,nz)=ks*(1-(1-Ss(nx,nz).^(-mV)).^mV).^2.*Ss(nx,nz).^.5;
            F(nx,nz)=f(nx,nz)+nz*dz;
            %  F(nx,nz)=[k(nx,nz).*((F(nx+1,nz)+F(nx-1,nz-1))/dr^2+(F(nx,nz+1)+F(nx,nz-1))/dz^2)+(k(nx+1,nz)-k(nx-1,nz)).*F(nx+1,nz)/(2*dr^2)+...
            %(k(nx,nz+1)-k(nx,nz-1)).*F(nx,nz+1)/(2*dz^2)]./[2*k(nx,nz)*(1/dr^2+1/dz^2)(k(nx+1,nz)-k(nx-1,nz))/(2*dr^2)+...
            %(k(nx,nz+1)-k(nx,nz-1))/(2*dz^2)];
            if  f(nx,nz)==0;
              wt(nx,nz)=nz*dz; %F(nx,nz);
            endif
          endfor
        endfor
        %Error=sqrt(sumsq(F-Hold));
        %Error=sqrt(F-Fold);
        %Error=max(abs(F-Fold));
        error = max(abs(f_old - f)); %max(max(abs(f_old - f)));
        f_old = f;
        Gauss_Seidel_iteration = Gauss_Seidel_iteration + 1;
      end
      f_intial = f;
    end
    end
    %%% Plotting the results %%%
    x=0:dr:W;   % width array  (in m)
    z=0:dz:L;   % Height array  (in m)
    %[X,Y] =meshgrid(x,z);
    %v=[0.8 0.6 0.4 0.2 0.1 0.05 0.01];
    %colormap(jet);
    %contourf(x, z, f');
    %surf(f)
    %shading flat
    %plot(x,F)
    %plot(x,wt)
    plot(x,f)
    title("Charge distribution");
    xlabel("Radial coordinate (in m)");
    ylabel("Position (in m)");
    title(sprintf('No. of Unsteady Gauss-Seidel Iterations(IMPLICIT) = %d', Gauss_Seidel_iteration));
    umfred
    Re : Edp
    quel langage ? matlab ?
    il va falloir déboguer en pas à pas pour essayer de comprendre, ça semble se passer dans la boucle quand nz=3; après rien de grave, les parties imaginaires sont a priori nulles.
