Detecting step motor effort
    invite5ccac3dd
    I'm working on a project using steper motor which turn a threaded shaft (long screw) in order to open or close a water valve (high flow, high pressure).
    My fear is that, after a long time of use, the grease on the threaded shaft will dissapear and it can became hard for the stepper motor to rotate correctly the threaded shaft.
    In order to tell the user to add grease, I have to know when the stepper needs more effort than before to rotate the threaded shaft. So, would it be possible to detect the "effort" made by the stepper in order to get this information on the Arduino?
    Any ideas are welcomed!
    Re : Detecting step motor effort
    Hello Wilma902
    Welcome on the forum.
    Citation Envoyé par Wilma902 Voir le message
    I'm working on a project using steper motor ...
    Your question has been moved because misplaced.
    French is the only langage permitted, so it’s closed.
  1. arduino STEP MOTOR
    Par invitef38b92de dans le forum Programmation et langages, Algorithmique
    Dernier message: 22/10/2018, 17h34
  2. Transferts de boues de STEP à STEP
    Par invite061b66af dans le forum Environnement, développement durable et écologie
    Dernier message: 10/12/2013, 13h59
  3. [Biologie Moléculaire] conservation ADNc et one step-RT-PCR VS two step RT-PCR
    Par invitec8445610 dans le forum Biologie
    Dernier message: 30/10/2010, 14h50
  4. Erreur DETECTING IDE DRIVES
    Par inviteb88a3ff6 dans le forum Matériel - Hardware
    Dernier message: 05/07/2008, 07h56
  5. detecting IDE drive
    Par inviteb9e4093f dans le forum Matériel - Hardware
    Dernier message: 22/07/2004, 18h58
