Des nouvelles de SpaceX - Page 44
Page 44 sur 45 PremièrePremière 44 DernièreDernière
Affichage des résultats 1 291 à 1 320 sur 1344
  1. #1291
    GBo
    Re : Des nouvelles de SpaceX
    Le 7ème vol d’essai du Starship de SpaceX a lieu ce soir normalement, avec comme objectif original de tester le déploiement de satellites Starlink dans l’espace.
    VO: https://www.spacex.com/launches/miss...rship-flight-7
    The upcoming flight test will launch a new generation ship with significant upgrades, attempt Starship’s first payload deployment test, fly multiple reentry experiments geared towards ship catch and reuse, and launch and return the Super Heavy booster.
    VF : https://youtu.be/RZdsrkUUUC4
    Dernière modification par GBo ; 16/01/2025 à 17h37.
  2. #1292
    Gwinver
    Bonsoir.
    Impressionné par la quantité et l'ampleur des évolutions, du moins telles que décrites.
    A block of planned upgrades to the Starship upper stage will debut on this flight test, bringing major improvements to reliability and performance. The vehicle’s forward flaps have been reduced in size and shifted towards the vehicle tip and away from the heat shield, significantly reducing their exposure to reentry heating while simplifying the underlying mechanisms and protective tiling. Redesigns to the propulsion system, including a 25 percent increase in propellant volume, the vacuum jacketing of feedlines, a new fuel feedline system for the vehicle’s Raptor vacuum engines, and an improved propulsion avionics module controlling vehicle valves and reading sensors, all add additional vehicle performance and the ability to fly longer missions. The ship’s heat shield will also use the latest generation tiles and includes a backup layer to protect from missing or damaged tiles.
    The vehicle’s avionics underwent a complete redesign, adding additional capability and redundancy for increasingly complex missions like propellant transfer and ship return to launch site. Avionics upgrades include a more powerful flight computer, integrated antennas which combine Starlink, GNSS, and backup RF communication functions into each unit, redesigned inertial navigation and star tracking sensors, integrated smart batteries and power units that distribute data and 2.7MW of power across the ship to 24 high-voltage actuators, and an increase to more than 30 vehicle cameras giving engineers insight into hardware performance across the vehicle during flight. With Starlink, the vehicle is capable of streaming more than 120 Mbps of real-time high-definition video and telemetry in every phase of flight, providing invaluable engineering data to rapidly iterate across all systems.
  3. #1293
    GBo
    En effet !
    Le bon lien pour la VF (direct):
    https://youtu.be/-QmR8KGMj5w
  4. #1294
    GBo
    Echec du 2ieme étage.
  5. #1295
    GBo
    Communiqué de SpaceX sur l'incident:
    Starship experienced a rapid unscheduled disassembly during its ascent burn. Teams will continue to review data from today's flight test to better understand root cause.
    With a test like this, success comes from what we learn, and today’s flight will help us improve Starship’s reliability.
    Source: https://x.com/SpaceX/status/1880033318936199643
    NB: "unscheduled disassembly" signifie explosion dans le jargon de SpaceX.
    Un article de space.com avec des vidéos amateur spectaculaires des débris 2ieme étage qui retombent:
    "Watch SpaceX Starship explode over Atlantic Ocean on Flight Test 7 (videos)"
    https://www.space.com/space-explorat...-test-7-videos
    Dernière modification par GBo ; 17/01/2025 à 08h19.
  6. #1296
    yves95210
    Mais nouveau succès de la récupération du booster...
  7. #1297
    GBo
    Citation Envoyé par yves95210 Voir le message
    En effet, ils en sont donc à 2 succès sur 3 pour le moment, puisque le vol d'essai N°6 s'est fini par un sacrifice volontaire du 1er étage au large de Boca Chica.
    Il est d'ailleurs remarquable de voir sur la rentrée d'hier que c'est le même angle de pénétration dans la pince que lors du vol N°5, la chorégraphie est bien huilée.
    Dernière modification par GBo ; 17/01/2025 à 09h32.
  8. #1298
    GBo
    L'"astronogamer" Scott Manley revoit le match (warning : fort accent écossais):
    https://youtu.be/vfVm4DTv6lM
  9. #1299
    GBo
    Le 8ime vol d'essai du Starship est prévu en principe Vendredi 28 Février à 23:30 UTC, donc 1 heure plus tard en heure de Paris (et nous on sera samedi matin du coup).
    Source (à checker):
    https://nextspaceflight.com/starship/
  10. #1300
    GBo
    Le site annonce un décalage de quelques jours:
    "SpaceX is targeting NET March 3rd at 5:30 PM CST (23:30 UTC) for Starship Flight 8,[...] "
  11. #1301
    pendant ce temps là les détritus d'EM tombent en Pologne :https://01actu.net/sciences/debris-s...ogne-securite/
  12. #1302
    Lockheed
    Avec 25 tirs depuis le début de l'année, ma femme qui séjourne actuellement à Warsawa (Varsovie) a plus de chance de me ramener un morceau d'un Falcon que d'un Ariane !
  13. #1303
    Gwinver
    Il faudrait aussi évaluer les précautions que prennent les constructeurs lors des lancements pour limiter les risques pour la population.
  14. #1304
    . . . Il faudrait aussi évaluer les précautions que prennent les constructeurs . . .
    . . . des immeubles ?
  15. #1305
    Bon, c'est quand même anecdotique. L'important n'est-il pas de satelliser du starlink ?
    Et je constate que EM n'a même pas pris la peine de muter le bug en feature, c'est que ça doit être secondaire . . .
  16. #1306
    GBo
    Ce n'est exactement vrai car lors de la désintégration récente du Starship dernière version juste au-dessus d'iles habitées des Caraïbes, le docteur Folamour de la tech a déclaré sans attendre:
    Nom : Folamour.png
Affichages : 354
Taille : 136,2 Ko
    Source: https://x.com/elonmusk/status/1880040599761596689
    Dernière modification par GBo ; 28/02/2025 à 16h10.
  17. #1307
    GBo
    En fait la FAA vient seulement de donner le feu vert pour pour le test flight #8 de Starship:
    "FAA clears SpaceX to launch Starship after explosive failure rained debris over populated islands"
    https://edition.cnn.com/2025/02/28/s...val/index.html
    Article daté de ce jour (Vendredi 28 Février) !
    Et pour autant, l'enquête sur l'accident du flight test #7 du 16 janvier reste ouverte.
    Dernière modification par GBo ; 28/02/2025 à 21h15.
  18. #1308
    zebular
    Citation Envoyé par Lockheed Voir le message
    Oui mais ariane n'en lance pas des masses.
    Pour autant que je suis admiratif sur la qualité des lancements.
    Commercialement parlant, la falcon 9 est l'outil d'actualité, ariane devient une niche.
    Les marges sont parfois superieures mais le chiffre d'affaire c'est peanut.
  19. #1309
    Gwinver
    Bonsoir.
    Une partie des débris sont tombés vers (voire même sur) les îles Turks et Caicos.
    https://www.boursorama.com/bourse/ac...0f6321f63c408d
    Ca semble impressionnant vécu d'en dessous.
    Les habitants des îles de la Caïque du Sud et de la Caïque du Nord ont décrit à Reuters un grondement intense qui a fait trembler le sol et ont déclaré avoir reçu des messages d'amis de la Caïque du Nord qui avaient trouvé des morceaux carbonisés de ce qu'ils pensaient être des débris du Starship.
    "Mon miroir et les murs tremblaient", a déclaré Veuleiri Artiles, une femme qui travaillait à la Caïque du Sud lorsque les débris sont tombés. "J'avais l'impression d'être dans un avion... J'avais les oreilles qui sifflaient
    "J'ai eu l'impression d'un tremblement de terre", a déclaré Ibalor Calucin, qui vit sur l'île de Providenciales. "C'était effrayant... tous les habitants de notre appartement ont couru vers le parking
    Legrondement provenait des nombreux débris orange de l'explosion du Starship qui franchissaient le mur du son en plongeant dans l'atmosphère, provoquant de fortes détonations à travers les îles, selon les données des capteurs sismiques au sol analysées par Benjamin Fernando, chercheur en sismologie à l'université Johns Hopkins.
  20. #1310
    FAA qui si j'ai bien suivi est maintenant plus ou moins sous contrôle d'EM!!!!!
    https://www.01net.com/actualites/elo...americain.html
    La notion de conflit d’intérêt semble avoir disparu des politiques US.
  21. #1311
    Ça n'a jamais eu cours aux USA.
    Le truc de la FAA est qu'elle est quand même victime de beaucoup d'effets parasites des politiques des administrations successives pour un ciel surchargés d'intérêts commerciaux et privés et là dessus se greffe depuis le 20 janvier une réforme des habitudes et quelques morts.
  22. #1312
    Ce n'est exactement vrai car lors de la désintégration récente . . .
    Oui oui, c'est ce que je voulais dire : jusque là c'est gratuit ! - apparemment ils ont les Polonais à la cool -
  23. #1313
    GBo
    Source (à checker):
    Deuxième report, car cette nuit le compte à rebours s'est arrêté automatiquement à T-40 secondes...
    Prochaine date:
    SpaceX is targeting NET Wednesday March 5th at 5:30pm CST (23:30 UTC) for Starship Flight 8.
    Donc pour l'heure de Paris, rdv après minuit dans la nuit de mercredi à jeudi.
  24. #1314
    GBo
    Rebelote, bonne récup du 1er étage mais perte du deuxième étage, a priori pour des raisons similaires au Flight 7.
  25. #1315
    ThM55
    Et Musk veut vraiment remiser le SLS?
  26. #1316
    GBo
    Citation Envoyé par Tawahi-Kiwi Voir le message
    La limite de ce que j'imaginais: est-ce qu'on sait fermer un bras sans fermer l'autre? (donc sans avoir a pousser un booster mal aligne pour permettre la fermeture de la pince)
    Au fait a posteriori tu avais raison en Octobre, la fermeture des deux bras de mechazilla a l'air d'être contrôlée indépendamment pour l'un et l'autre (alors que je soutenais que la fermeture était symétrique - au jeu mécanique près), on le voit très bien dans cet angle du vue dans cette vidéo du 3ieme rattrapage réussi du booster du Starship (à partir de la 106ime seconde):
    "Why Is Starship So Difficult to Get Right?"
    https://www.youtube.com/watch?v=39j-TJI0SsU&t=106s
    Le procédure a l'air également d'être automatisée en fonction de la position exacte de la fusée à chaque instant, dans une boucle de rétroaction assez serrée.
    Dernière modification par GBo ; 15/03/2025 à 16h09.
  27. #1317
    Tawahi-Kiwi
    Apres une serie d'echecs, Starship Flight 10 a finalement eu une mission en apparence un succes complet avec un splashdown du Starship dans l'ocean indien a une vitesse tout a fait raisonnable et en un seul morceau !
    T-K
  28. #1318
    Garion
    Il manquait des bouts quand même. Il y a eu une explosion a proximité des moteurs dés le début de la descente.
  29. #1319
    Tawahi-Kiwi
    oui, je me suis un peu avance sur le 'en un seul morceau'
    un des ailerons etait un peu kaput aussi.
  30. #1320
    GBo
    La série noire pour Starship est passée on dirait, c'est reparti !
    Quelqu'un sait pourquoi le 1er étage n'a pas été récupéré au fait ?
  1. SpaceX Falcon 9 heavy
    Par invitef904670e dans le forum Astronautique
    Réponses: 70
    Dernier message: 25/02/2018, 20h46
  2. Explosion d'une fusée Falcon 9 de SpaceX sur le pas de tir
    Par invite0bbe92c0 dans le forum Actualités
    Dernier message: 02/09/2016, 17h48
  3. Spacex
    Par Moinsdewatt dans le forum Astronautique
    Réponses: 72
    Dernier message: 02/09/2016, 13h54
  4. SpaceX et Mars
    Par invite9f80122c dans le forum Astronautique
    Dernier message: 25/05/2011, 16h30
