CAN et afficheur LCD
    invited25fdd6b
    je cherche des exemples de montage si possible sur proteus pour un montage de potentiomètre, CAN (convertiseur analogique numérique), et un afficheur LCD.
    je vous remercie d'avance...
    invite9fe8593a
    Re : CAN et afficheur LCD
    montage
    code mikroC :
    * Project name:
    ADC_on_LCD (Displaying ADC result on LCD)
    * Copyright:
    (c) Mikroelektronika, 2005.
    * Description:
    This code demonstrates how to use library function ADC_read, and library
    procedures and functions for LCD display (4 bit interface).
    * Test configuration:
    MCU: PIC16F877A
    Dev.Board: EasyPIC4
    Oscillator: HS, 08.0000 MHz
    Ext. Modules: LCD
    SW: mikroC v5.0
    * NOTES:
    None.
    unsigned char ch;
    unsigned int t;
    char a[17], *tc;
    long tlong;
    void main() {
    INTCON = 0; // disable all interrupts
    LCD_Init(&PORTB); // initialize (4-bit interface connection)
    LCD_Cmd(LCD_CURSOR_OFF); // send command to LCD (cursor off)
    LCD_Cmd(LCD_CLEAR); // send command to LCD (clear LCD)
    OPTION_REG = 0x80;
    ADCON1 = 0x82; // configure VDD as Vref, and analog channels
    TRISA = 0xFF; // designate porta as input
    tc = "voltage:"; // assign text to string a
    while (1) {
    t = ADC_read(0); // get ADC value from 2nd channel
    LCD_Out(2,1,tc); // print string a on LCD, 2nd row, 1st column
    tlong = t * 5000; // use (int) multiplication instead of (long)
    asm { // and fill the upper two bytes manually
    MOVF STACK_2,W
    MOVWF _tlong+2
    MOVF STACK_3,W
    MOVWF _tlong+3
    t = tlong >> 10;
    ch = t / 1000; // prepare value for diplay
    LCD_Chr(2,9,48+ch); // write ASCII at 2nd row, 9th column
    LCD_Chr_CP('.');
    ch = (t / 100) % 10;
    LCD_Chr_CP(48+ch);
    ch = (t / 10) % 10;
    LCD_Chr_CP(48+ch);
    ch = t % 10;
    LCD_Chr_CP(48+ch);
    LCD_Chr_CP('V');
    Delay_ms(1);
  1. Afficheur LCD
    Par invite2d9e7c03 dans le forum Électronique
    Réponses: 39
    Dernier message: 24/01/2013, 13h26
  2. afficheur lcd en afficheur 7 segment
    Par invite3cc40cdb dans le forum Électronique
    Dernier message: 04/02/2008, 10h43
  3. Afficheur LCD
    Par invite854748b1 dans le forum Électronique
    Dernier message: 18/06/2007, 20h25
  4. afficheur LCD
    Par invited6314dc8 dans le forum Électronique
    Dernier message: 08/06/2007, 10h24
  5. afficheur lcd
    Par invite1a260649 dans le forum Électronique
    Dernier message: 26/01/2005, 17h53
