mess lcd pic16f84
mess lcd pic16f84
    invitefc1671e3
    mess lcd pic16f84
    j'ai un problème. comment afficher correctement le message sur lcd
    Le message n'est jamais stable il flashe. Mai quand j’exécute juste la fonction index ou vitesse elles sont correctes. mais si je mets une condition ça commencer de flasher
    ORG RESET_V ; RESET vector location
    RESET GOTO START
    ORG ISR_V ; Interrupt vector location
    INTERRUPT BCF STATUS, RP0 ; Select bank 0
    GOTO INTERRUPT
    ; Send a message using a table to output a message
    ; OK
    TABLE_MSG
    MOVLW 0 ; Startindex of table message
    DISP_MSG
    MOVWF TABLE_INDEX ; Holds message address
    CALL MSG1
    ANDLW 0x0FF ; Check if at end of message
    BTFSC STATUS, Z ; (zero returned at end)
    GOTO TABLE_MSG_END
    CALL LCDPUTCHAR ; Display character
    MOVF TABLE_INDEX, W ; Point to next character
    ADDLW 1
    GOTO DISP_MSG
    TABLE_MSG_END RETURN
    TABLE_MSG1
    DISP_MSG1
    CALL MSG2
    GOTO TABLE_MSG_END1
    ADDLW 1
    GOTO DISP_MSG1
    TABLE_MSG_END1 RETURN
    TABLE_MSG2
    DISP_MSG2
    CALL MSG3
    GOTO TABLE_MSG_END2
    ADDLW 1
    GOTO DISP_MSG2
    TABLE_MSG_END2 RETURN
    TABLE_MSG3
    DISP_MSG3
    CALL MSG1
    GOTO TABLE_MSG_END3
    ADDLW 1
    GOTO DISP_MSG3
    TABLE_MSG_END3 RETURN
    TABLE_VIT
    VIT
    CALL MSG5
    GOTO TABLE_VIT_END3
    ADDLW 1
    GOTO VIT
    TABLE_VIT_END3 RETURN
    ; LCD Module Subroutines
    ; LCDINIT
    ; Initilize LC-Display Module
    ; Should be modified to your needs (i.e. display type, cursor on/off, etc.)
    ; OK
    LCDINIT
    ; Busy-flag is not yet valid
    CLRF LCD_CTRL ; ALL PORT output should output Low.
    ; power-up delay
    MOVLW 0x01E
    CALL X_DELAY500 ; 30 * 0.5mS = 15mS
    ; Busy Flag should be valid from here
    MOVLW 0x038 ; 8-bit-interface, 2-lines
    CALL LCDPUTCMD
    MOVLW 0x000 ; disp.off, curs.off, no-blink
    CALL LCDDMODE
    CALL LCDCLEAR
    MOVLW 0x004 ; disp.on, curs.off
    CALL LCDDMODE
    MOVLW 0x002 ; auto-inc (shift-cursor)
    CALL LCDEMODE
    RETURN
    ; LCD_ENABLE
    ; Pulses LCD enable pin
    ; OK
    LCD_ENABLE
    BSF LCD_CTRL, LCD_E ; LCD E-line High
    BCF LCD_CTRL, LCD_E ; LCD E-line Low
    RETURN
    ; LCDBUSY
    ; Returns when LCD busy-flag is inactive
    ; OK
    LCDBUSY
    BSF STATUS,RP0 ; Select Register page 1
    MOVLW 0x0FF ; Set PORTB for input
    MOVWF LCD_DATA_TRIS
    BCF STATUS, RP0 ; Select Register page 0
    BCF LCD_CTRL, LCD_RS; Set LCD for command mode
    BSF LCD_CTRL, LCD_RW; Setup to read busy flag
    MOVF LCD_DATA, W ; Read busy flag + DDram address
    ANDLW 0x80 ; Check Busy flag, High = Busy
    BTFSS STATUS, Z
    GOTO LCDBUSY
    LCDNOTBUSY BCF LCD_CTRL, LCD_RW
    BSF STATUS, RP0 ; Select Register page 1
    MOVLW 0x000
    MOVWF LCD_DATA_TRIS ; Set PORTB for output
    RETURN
    ; LCDCLEAR
    ; Clears display and returns cursor to home position (upper-left corner).
    LCDCLEAR
    MOVLW 0x001
    CALL LCDPUTCMD
    RETURN
    ; LCDHOME
    ; Returns cursor to home position.
    ; Returns display to original position (when shifted).
    LCDHOME
    MOVLW 0x002
    CALL LCDPUTCMD
    RETURN
    ; LCDEMODE
    ; Sets entry mode of display.
    ; Required entry mode must be set in W
    ; b0 : 0 = no display shift 1 = display shift
    ; b1 : 0 = auto-decrement 1 = auto-increment
    ; b2-7 : don't care
    ; OK
    LCDEMODE
    ANDLW 0x003 ; Strip upper bits
    IORLW 0x004 ; Function set
    CALL LCDPUTCMD
    RETURN
    ; LCDDMODE
    ; Sets display control.
    ; Required display mode must be set in W
    ; b0 : 0 = cursor blink off 1 = cursor blink on
    ; b1 : 0 = cursor off 1 = cursor on
    ; b2 : 0 = display off 1 = display on (display data remains in DDRAM)
    ; b3-7 : don't care
    ; OK
    LCDDMODE
    ANDLW 0x007 ; Strip upper bits
    IORLW 0x008 ; Function set
    CALL LCDPUTCMD
    RETURN
    ; LCDSCGA
    ; Sets Character-Generator-RAM address. CGRAM is read/written after
    ; this setting.
    ; Required CGRAM address must be set in W
    ; b0-5 : required CGRAM address
    ; b6-7 : don't care
    LCDSCGA
    ANDLW 0x03F ; Strip upper bits
    IORLW 0x040 ; Function set
    CALL LCDPUTCMD
    RETURN
    ; LCDSDDA
    ; Sets the Display-Data-RAM address. DDRAM data is read/written after
    ; this setting.
    ; Required DDRAM address must be set in W
    ; b0-6 : required DDRAM address
    ; b7 : don't care
    ; OK
    LCDSDDA
    IORLW 0x080 ; Function set
    CALL LCDPUTCMD
    RETURN
    ; LCDGADDR
    ; Returns address counter contents, used for both DDRAM and CGRAM.
    ; RAM address is returned in W
    LCDGADDR
    MOVWF LCD_DATA_TRIS
    MOVF LCD_DATA, W ; Read busy flag + RAM address
    ANDLW 0x07F ; Strip upper bit
    MOVLW 0x000
    RETURN
    ; LCDPUTCHAR
    ; Sends character to LCD
    ; Required character must be in W
    ; OK
    LCDPUTCHAR
    MOVWF LCD_TEMP ; Character to be sent is in W
    CALL LCDBUSY ; Wait for LCD to be ready
    BCF LCD_CTRL, LCD_RW; Set LCD in read mode
    BSF LCD_CTRL, LCD_RS; Set LCD in data mode
    MOVF LCD_TEMP, W
    MOVWF LCD_DATA ; Send data to LCD
    RETURN
    ; LCDPUTCMD
    ; Sends command to LCD
    ; Required command must be in W
    ; OK
    LCDPUTCMD
    MOVWF LCD_TEMP ; Command to be sent is in W
    BCF LCD_CTRL, LCD_RS; Set LCD in command mode
    MOVF LCD_TEMP, W
    RETURN
    ; Delay_time = ((DELAY_value * 3) + 4) * Cycle_time
    ; DELAY_value = (Delay_time - (4 * Cycle_time)) / (3 * Cycle_time)
    ; i.e. (@ 4MHz crystal)
    ; Delay_time = ((32 * 3) + 4) * 1uSec
    ; = 100uSec
    ; DELAY_value = (500uSec - 4) / 3
    ; = 165.33
    ; = 165
    DELAY500 MOVLW D'165' ; +1 1 cycle
    MOVWF DELAY ; +2 1 cycle
    DELAY500_LOOP DECFSZ DELAY, F ; step 1 1 cycle
    GOTO DELAY500_LOOP ; step 2 2 cycles
    DELAY500_END RETURN ; +3 2 cycles
    X_DELAY500 MOVWF X_DELAY ; +1 1 cycle
    X_DELAY500_LOOP CALL DELAY500 ; step1 wait 500uSec
    DECFSZ X_DELAY, F ; step2 1 cycle
    GOTO X_DELAY500_LOOP ; step3 2 cycles
    X_DELAY500_END RETURN ; +2 2 cycles
    ; Table message to display
    MSG1
    addwf PCL ,F ;Jump to char pointed to in W reg
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    retlw '+'
    MSG1_END
    retlw 0
    IF ( (MSG1 & 0x0FF) >= (MSG1_END & 0x0FF) )
    MESSG "Warning - User Definded: Table 'MSG1' crosses page boundry in computed jump"
    ENDIF
    return
    MSG2
    retlw '+'
    retlw ' '
    retlw ' '
    retlw ' '
    retlw 'R'
    retlw 'O'
    retlw 'B'
    retlw 'O'
    retlw 'T'
    retlw 'O'
    retlw 'S'
    retlw ' '
    retlw ' '
    retlw '.'
    retlw ' '
    retlw ' '
    retlw ' '
    retlw ' '
    retlw ' '
    MSG2_END
    retlw 0
    IF ( (MSG2 & 0x0FF) >= (MSG2_END & 0x0FF) )
    ENDIF
    return
    MSG3
    retlw '+'
    retlw ' '
    retlw ' '
    retlw 'F'
    retlw '4'
    retlw ' '
    retlw 'p'
    retlw 'o'
    retlw 'u'
    retlw 'r'
    retlw ' '
    retlw 'E'
    retlw 'N'
    retlw 'T'
    retlw 'R'
    retlw 'E'
    retlw 'R'
    retlw ' '
    retlw ' '
    MSG3_END
    retlw 0
    IF ( (MSG3 & 0x0FF) >= (MSG3_END & 0x0FF) )
    ENDIF
    return
    MSG5
    retlw 'L'
    retlw 'a'
    retlw ' '
    retlw 'V'
    retlw 'i'
    retlw 't'
    retlw 'e'
    retlw 's'
    retlw 's'
    retlw 'e'
    retlw ' '
    retlw 'e'
    retlw 's'
    retlw 't'
    retlw ':'
    retlw ' '
    retlw ' '
    retlw ' '
    retlw ' '
    MSG5_END
    retlw 0
    IF ( (MSG5 & 0x0FF) >= (MSG5_END & 0x0FF) )
    ENDIF
    return
    INDEX
    call LCDCLEAR
    MOVLW '+' ; ASCII '0'
    MOVWF COUNT
    MOVLW LCD_LINE0
    CALL LCDSDDA ; Position cursor leftmost on first line
    CALL TABLE_MSG ; Display message
    MOVLW LCD_LINE0 + 0x013
    MOVF COUNT, W
    CALL LCDPUTCHAR ; Display line number
    MOVWF COUNT
    MOVLW LCD_LINE1
    CALL TABLE_MSG1 ; Display message
    MOVLW LCD_LINE1 + 0x013
    MOVF COUNT, W
    MOVWF COUNT
    MOVLW LCD_LINE2
    CALL TABLE_MSG2 ; Display message
    MOVLW LCD_LINE2 + 0x013
    MOVF COUNT, W
    MOVWF COUNT
    MOVLW LCD_LINE3
    CALL TABLE_MSG3 ; Display message
    MOVLW LCD_LINE3 + 0x013
    MOVF COUNT, W
    RETURN
    VITESSE
    CALL LCDCLEAR
    MOVWF COUNT
    MOVLW LCD_LINE1
    MOVF COUNT, W
    MOVLW ' ' ; ASCII '0'
    MOVWF COUNT
    MOVLW LCD_LINE2
    CALL TABLE_VIT ; Display message
    MOVF COUNT, W
    RETURN
    ; Initialize processor registers
    START ; POWER_ON Reset (Beginning of program)
    CLRF STATUS ; Do initialization, Select bank 0
    CLRF INTCON ; Clear int-flags, Disable interrupts
    CLRF PCLATH ; Keep in lower 2KByte
    CLRF PORTA ; ALL PORT output should output Low.
    CLRF PORTB
    BSF STATUS, RP0 ; Select bank 1
    MOVLW 0x0F8 ; RA2-0 outputs, RA4-3 inputs
    MOVWF TRISA
    MOVLW 0x000 ; RB7-0 outputs
    MOVWF TRISB
    BSF OPTION_REG, NOT_RBPU ; Disable PORTB pull-ups
    CALL LCDINIT ; Initialize LCDisplay
    loop
    btfss PORTA,3
    call VITESSE
    btfsc PORTA,3
    CALL INDEX
    goto loop
    END
    Re : mess lcd pic16f84
    Bjr sdow...
    T'es sur qui te manques pas une paire d'instructions du genre:
    Print :"Bonjour"
    End: "Merçi"
    Je ne te serais d'aucun secours, mais cela peut en inciter qq uns à prendre ta demande en considération.
  1. pic16F84
    Par inviteaa98cb7b dans le forum Électronique
    Réponses: 89
    Dernier message: 14/05/2007, 13h42
  2. pic16F84
    Par invite4769246c dans le forum Électronique
    Réponses: 64
    Dernier message: 07/05/2007, 23h26
  3. Pic16f84-04/p
    Par inviteeab0141b dans le forum Électronique
    Dernier message: 30/09/2006, 20h50
  4. programmation PIC16F84
    Par inviteb4585ab0 dans le forum Électronique
    Dernier message: 24/06/2006, 00h19
  5. gradateur à pic16f84
    Par invitee382f91e dans le forum Électronique
    Dernier message: 03/06/2005, 10h44
