How do I simulate the fully differential OTA with HSPICE
    invitef8c30587
    Hi,
    I want to simulate with Hspice, the fully differential OTA such as, AC gain and phase margin. Generall speaking, fully differential amplifier has two input vin+/vin-, two outputs vout+/vout- .
    I know the differential mode gain is Av=(vout+ - vout-)/(vin+ - vin-).
    But How I do this in the Hspice.
    Regards
    invitee05a3fcc
    Re : How do I simulate the fully differential OTA with HSPICE
    Sorry, on est sur un forum qui cause en Français, le patois AngloSaxon, je ne veux pas le connaitre
    Tropique
    monfilsaziz,
    Exchanges on this forum are normally carried out in french.
    We do not want to exclude anyone, but the discussions have to remain understandable by the majority of other participants.
    Can you therefore proceed in french?
    If you're unable to do so, there are a number of english-speaking forums on the www (more in fact than in french). Example:
    http://www.edaboard.com/
    Tropique, tu as oublié de traduire ta signature:
    Tropique, you forgot the translation of your signature:
    No complex. I'm like you. Just better.
    Feel free to correct if necessary
    (Pour Daudet = Merci de corriger si nécessaire)
    Amicalement
    Re
    effectivement, étrange similitude:
    http://www.edaboard.com/ftopic105868.html
    Ils doivent être dans la même école.....
    A+,
  1. LTSpice & OTA
    Par invite219d4326 dans le forum Électronique
    Réponses: 22
    Dernier message: 29/05/2014, 12h50
  2. Hspice simulation inverseur
    Par invitef1539ac2 dans le forum Électronique
    Dernier message: 04/08/2009, 11h05
  3. Schéma dynamique OTA miller
    Par invite176d15a9 dans le forum Électronique
    Dernier message: 15/07/2009, 10h44
  4. Partial Differential Equations of Physics
    Par invite2593335f dans le forum Lectures scientifiques
    Dernier message: 06/08/2008, 01h05
  5. oculaires plossl celestron fully multi coated
    Par invite5ab5786e dans le forum Matériel astronomique et photos d'amateurs
    Dernier message: 28/04/2006, 12h48
