compilateur pic
compilateur pic
    invite0374bd4b
    compilateur pic
    Bonjour j'ai récupérer un programme de pic 16F873 sur internet, par contre je ne sais pas avec quel compilateur je pourrai le compiler !!
    mon code est ci dessous:
    #include "16f873.h"
    #include "math24f.h"
    #define num1 1012
    #define num2 1022
    uns8 duty, mcount, ncount;
    float V_batt, Vin1_S1, Vin2_S1, Iin1_S1, Iin2_S1, G_S1, dI_S1, dV_S1, dG_S1, ero;
    void int_pwm(void){
    TRISC = bin(00110000);
    PORTC.1 = 0; // port c2 output (CCP1, PWM1)
    PIE1.1 = 0; // disable timer 2 interrupts
    PIE1.2 = 0; // disable ccp1 interrupts
    CCP1CON = 0; // CCP1 module off
    PR2 = 0b.0011.1110; // load period register (62)
    CCP1CON.5 = 0;
    CCP1CON.4 = 0;
    duty = 0b.0001.1111; // set duty cycle
    CCPR1L = 0b.0001.1111;
    T2CON = bin(00000000); // prescaler 1:1
    TMR2 = 0; // timer 2 off
    CCP1CON = bin(00001100); // ccp1 pwm mode, ccp1 module on
    void delay_20us (void){
    char count = 0x07;
    loop:
    if (-- count == 0){
    return;}
    else goto loop;
    void delay_100ms(void){
    char mcount = 0x4f; // M counter = 256
    loadn:
    char ncount = 0x4f; // N counter = 256
    decn:
    while (-- ncount > 0){
    goto decn;}
    while (-- mcount > 0){
    goto loadn;}
    return;
    void delay_200ms(void){
    char mcount = 0xff; // M counter = 256
    loadn:
    char ncount = 0xff; // N counter = 256
    decn:
    goto decn;}
    goto loadn;}
    return;
    void int_adc (void){
    TRISA =bin(00011111); // inputs/outputs
    ADCON1 = bin(10000000); // PortA, bit1,0 analog input
    void incduty(void){ // Increment the duty ratio by 1
    W = 60 - duty;
    while (STATUS.2 == 1){
    return;}
    duty = duty +1;
    CCPR1L = duty;
    return;
    void decduty(void){ // decrement the duty ratio by 1
    W = 0x2 - duty;
    return;}
    duty = duty -1;
    CCPR1L = duty;
    return;
    void start_conv(void){
    delay_20us();
    ADCON0.2 = 1; // start conversion
    test:
    if ( ADCON0.2 == 1){ // test go/done bit, conversion
    finish?
    goto test;}
    delay_100ms();
    return;
    void get_measure_batt (void){
    V_batt.low8 = ADRESL;
    V_batt.mid8 = ADRESH; // conversion complete get A/D
    result
    void get_Vin1_S1 (void){
    Vin1_S1.low8 = ADRESL;
    Vin1_S1.mid8 = ADRESH; // conversion complete get A/D
    result
    void get_Iin1_S1 (void){
    Iin1_S1.low8 = ADRESL;
    Iin1_S1.mid8 = ADRESH; // conversion complete get A/D
    result
    void get_Vin2_S1 (void){
    Vin2_S1.low8 = ADRESL;
    Vin2_S1.mid8 = ADRESH; // conversion complete get A/D
    result
    void get_Iin2_S1 (void){
    Iin2_S1.low8 = ADRESL;
    Iin2_S1.mid8 = ADRESH; // conversion complete get A/D
    result
    void test1 (void){
    if(Iin2_S1 == Iin1_S1 ){
    return;}
    if (Iin2_S1 > Iin1_S1){
    incduty();
    return;}
    if (Iin2_S1 < Iin1_S1){
    decduty();
    return;}
    void test2 (void){
    if ( dG_S1 == G_S1 || ero <= 0.01){
    delay_100ms();
    return;}
    if ( dG_S1 < G_S1){
    decduty();
    return;}
    if ( dG_S1 > ero){
    incduty();
    return;}
    void measure_batt(void){
    ADCON0 = bin(01101001); // select conversion clock = 8, AN0
    on
    start_conv();
    get_measure_batt();
    void main (void){
    int_pwm();
    T2CON.2 = 1; // timer 2 on, pwm1 on
    InitFpFlags();
    int_adc();
    measure_batt();
    again:
    if (V_batt >= num1 || V_batt <= num2){ // measuring the battery voltage
    delay_200ms;
    goto again;} // do nothing PWM module off
    ADCON0 = bin(01000001); // select conversion clock = 8, AN0
    on
    start_conv();
    get_Vin1_S1();
    ADCON0 = bin(01001001); // select conversion clock = 8, AN1
    on
    start_conv();
    get_Iin1_S1();
    while(1){
    char n;
    for (n =0; n <256; n++){ // looping for a while
    on
    start_conv();
    get_Vin2_S1();
    on
    start_conv();
    get_Iin2_S1();
    G_S1 = Iin2_S1 / Vin2_S1;
    dV_S1 = Vin2_S1 - Vin1_S1;
    dI_S1 = Iin2_S1 - Iin1_S1;
    dG_S1 = dI_S1 / dV_S1;
    ero = dG_S1 + G_S1; // error margin
    if (ero<0)
    ero = -ero;
    if (dV_S1 < 0 ){
    test2();
    goto swapIV;
    if(dV_S1 >= 0){
    test1();
    swapIV:
    Iin1_S1 = Iin2_S1;
    Vin1_S1 = Vin2_S1;
    if (n == 255){ // break the while loop and go
    break;} // back to measure battery voltage
    pouvez vous m'aider svp ?
    RISC
    Re : compilateur pic
    Je ne pense pas que ce soit le compilateur HiTech.
    Pour ceux qui connaissent d'autres compilateurs, ces lignes très particulières devrait leur permettre de reconnaitre le compilateur :
    Quelqu'un a une idée ??
    a+
  1. Conseil pour un compilateur PIC.
    Par inviteb9f49292 dans le forum Électronique
    Dernier message: 03/06/2010, 15h54
  2. pic et compilateur hi-tech
    Par invite50cc55df dans le forum Électronique
    Dernier message: 19/07/2009, 17h33
  3. problème de compilateur C pour pic
    Par invitefcd0dbb3 dans le forum Électronique
    Réponses: 19
    Dernier message: 25/10/2007, 20h22
  4. Compilateur C pour les pic
    Par invite42dae262 dans le forum Électronique
    Dernier message: 12/04/2007, 19h04
  5. PIC : compilateur C
    Par Toufinet dans le forum Électronique
    Dernier message: 12/02/2007, 10h13
