comment lutter contre les parasites secteur - Page 2
Affichage des résultats 31 à 36 sur 36
    invitee05a3fcc
    Re : comment lutter contre les parasites secteur
    Citation Envoyé par naima75 Voir le message
    voici les schemas ils sont realises par Mr bruno gavand
    Ton PIC est alimenté en 6V ? c'est limite ...limite !
    C'est un 16F??? (illisible sur le schéma ?)
    invite84cbd597
    c un pic16F84 alimente sous 5v tres bien filtree et regule.
    voici le code source realise par bruno gavand.
    program
    symbol LUNDI = 0
    symbol MARDI = 1
    symbol MERCREDI = 2
    symbol JEUDI = 3
    symbol VENDREDI = 4
    symbol SAMEDI = 5
    symbol DIMANCHE = 6
    symbol LMMJV = 7
    symbol NBALARM = 21
    const alarmTable as byte[NBALARM * 4] = (
    ' JOUR HEURE MINUTE DUREE (secondes, 59 maxi)
    LMMJV, 7, 45, 6,
    LMMJV, 7, 55, 6,
    LMMJV, 8, 55, 6,
    LMMJV, 9, 55, 6,
    LMMJV, 10, 05, 6,
    LMMJV, 11, 00, 6,
    LMMJV, 12, 00, 6,
    LMMJV, 13, 45, 6,
    LMMJV, 13, 55, 6,
    LMMJV, 14, 55, 6,
    LMMJV, 15, 55, 6,
    LMMJV, 16, 05, 6,
    LMMJV, 17, 00, 6,
    LMMJV, 18, 00, 6,
    SAMEDI, 7, 45, 6,
    SAMEDI, 7, 55, 6,
    SAMEDI, 8, 55, 6,
    SAMEDI, 9, 55, 6,
    SAMEDI, 10, 05, 6,
    SAMEDI, 11, 00, 6,
    SAMEDI, 12, 00, 6
    dim maxcount as word
    dim scaler as word
    dim jj as byte
    dim hh as byte
    dim mn as byte
    dim ss as byte
    dim digiled as byte[4]
    dim digit as byte
    dim dp as byte
    dim key as byte
    dim alarm as byte
    sub procedure interrupt
    dim i as byte
    scaler = scaler + 1
    if scaler > maxcount
    then
    scaler = 0
    inc(ss)
    if ss = 60
    then
    ss = 0
    inc(mn)
    if mn = 60
    then
    mn = 0
    inc(hh)
    if hh = 24
    then
    hh = 0
    inc(jj)
    if jj = 7
    then
    jj =0
    end if
    end if
    end if
    end if
    end if
    #ifdef CATHODE_COMMUNE
    PORTA = PORTA and $f0
    TRISA = $0f
    key = PORTA
    TRISA = 0
    PORTB = 0
    #else
    PORTA = PORTA or $0f
    TRISA = $0f
    key = PORTA
    key = not(key)
    TRISA = 0
    PORTB = $ff
    #endif
    key = key and $07
    digit = digit + 1
    if digit > 3
    then
    digit = 0
    i = $01
    else
    i = $01 << digit
    end if
    PORTB = digiled[digit]
    PORTA = PORTA or i
    #else
    PORTB = not(PORTB)
    PORTA = PORTA and not(i)
    #endif
    INTCON.T0IF = 0
    end sub
    sub function intTo7seg(dim n as byte) as byte
    select case n
    case 0 result = $3F
    case 1 result = $06
    case 2 result = $5B
    case 3 result = $4F
    case 4 result = $66
    case 5 result = $6D
    case 6 result = $7D
    case 7 result = $07
    case 8 result = $7F
    case 9 result = $6F
    end select
    end sub
    sub procedure setValue(dim v as ^byte, dim s as byte, dim max as
    byte)
    digiled[0] = s
    digiled[1] = 0
    while 1
    if key.0
    then
    inc(v^)
    if(v^ > max)
    then
    v^ = 0
    end if
    end if
    if key.1
    then
    if(v^ = 0)
    then
    v^ = max
    else
    dec(v^)
    end if
    end if
    if key.2
    then
    Delay_ms(50)
    while key.2
    wend
    Delay_ms(50)
    scaler = 0
    ss = 0
    return
    end if
    digiled[2] = intTo7seg(v^ / 10)
    digiled[3] = intTo7seg(v^ mod 10)
    delay_ms(300)
    wend
    end sub
    main:
    dim i as byte
    dp = 0
    hh = 0
    mn = 0
    ss = 0
    jj = 0
    maxcount =15625
    PORTA = %00010000
    TRISA = %00000000
    PORTB = 0
    TRISB = $00
    INTCON = %10100000
    OPTION_REG = %11011000
    Delay_ms(50)
    setValue(@hh, 116, 23)
    setValue(@mn, 55, 59)
    setValue(@jj, 14, 6)
    while true
    if key
    then
    digiled[0] = intTo7seg(jj)
    digiled[1] = 0
    digiled[2] = intTo7seg(ss / 10)
    digiled[3] = intTo7seg(ss mod 10)
    else
    if hh < 10
    then
    digiled[0] = 0
    digiled[1] = intTo7seg(hh)
    else
    digiled[0] = intTo7seg(hh / 10)
    digiled[1] = intTo7seg(hh mod 10)
    end if
    digiled[2] = intTo7seg(mn / 10)
    digiled[3] = intTo7seg(mn mod 10)
    end if
    if scaler > maxcount / 2
    then
    dp.1 = 1
    else
    dp.1 = 0
    end if
    digiled[0].7 = dp.0
    digiled[1].7 = dp.1
    digiled[2].7 = dp.2
    digiled[3].7 = dp.3
    alarm = 0
    for i = 0 to (NBALARM - 1) * 4 step 4
    if ((alarmTable[i] = jj) or
    ((alarmTable[i] = LMMJV)and (jj< SAMEDI))) and (alarmTable[i + 1]
    = hh) and (alarmTable[i + 2] = mn) and (alarmTable[i + 3] > ss)
    then
    inc(alarm)
    end if
    next i
    if alarm
    then
    dp.3 = 1
    PORTA.4 = 0
    else
    dp.3 = 0
    PORTA.4 = 1
    end if
    wend
    end.
    invite84cbd597
    salut.que voulez vous dire par "c limite... limite" svp?
    c un pic 16f84 alimente sous 5v tres stable.
    invite84cbd597
    Citation Envoyé par jyvoipabo Voir le message
    Il faut rechercher un bug dans le programme,
    JP
    vous avez le programme en micro basic.
    contient il un bug? merci
    invitee05a3fcc
    J'avais lu 6V sur les schémas ....
    Pour le PNP, c'est bon (tu es dans la condition tension relais = tension µC) mais passe R1 à 2,2K
    Tu as fait le test avec le RC aux bornes du contact du relais?
    invite6d608176
    Je te remercie de me remercier, mais je ne connais pas le micro basic.
    JP
  1. Comment lutter contre l'humidité
    Par inviteffd3c5e3 dans le forum Matériel astronomique et photos d'amateurs
    Dernier message: 12/05/2009, 05h46
  2. comment lutter contre la buée
    Par invitedf5ac49b dans le forum Matériel astronomique et photos d'amateurs
    Dernier message: 25/01/2008, 20h56
  3. Comment lutter contre l'obésité ?
    Par inviteb73ce398 dans le forum Discussions scientifiques
    Réponses: 24
    Dernier message: 22/03/2007, 13h53
