undeclared identifier!!!!
    invite7ab3af0a
    salut...
    comment peut-on corriger ce prog afin qu'il puisse mesurer la consommtion de la carte (DUT1 ET DUT2) à travers le pic et affiche le résultat sur l'afficheur lcd .mon compilateur est le mikroc pro for pic que je suis pas familier avec, les erreur sont toujour de declaration de usart_init,lcd_config
    ce le code:
    //DECLARATION DES VARIABLES GLOBALES
    char strInput;
    unsigned int i;
    unsigned char VAL[4]={'\0','\0','\0','\0'};
    unsigned char VAL1[4]={'\0','\0','\0','\0'};
    unsigned char msg1[15]={' ',' ',' ',' ','S','A','G','E','M','C','O', 'M',' ',' ',' '};
    unsigned char msg2[15]={' ',' ','S','E','R','V','I','C','E', ' ',' ','T','E','S','T'};
    void Init_Main()
    INTCON=0;//disactivation des interruptions
    ADCON1 = 0x80; // Configure analog inputs and Vref 88
    TRISA = 0xFF; // PORTA is input DE PREFERENCE PIN4 "RA02"
    TRISD = 0x00; //portD is output
    TRISE = 0x00; //portE is output
    TRISB = 0x00; //portB is output
    PORTD = 0x00; //INITIALISATION PORTD=0
    TRISD=0x00; //PORTD IS OUTPUT EXEPTION
    Usart_Init(9600); // Configuration du Beaud
    Lcd_Config(&PORTD, 1, 3, 2, 7, 6, 5, 4); //EXEPTION
    Lcd_Init(&PORTD); // EXEPTION
    lcd_cmd(LCD_CLEAR);
    lcd_cmd(LCD_CURSOR_OFF);
    Delay_ms(500);
    // FONCTION N°2 DE CONVERSION DECIMALE TO CHAINE DE CARACTERE
    void DecToChar (unsigned int ValDec,unsigned char *ValChar)
    ValChar[0]='0'+(ValDec/1000);
    ValChar[1]='0'+(ValDec%1000)/100;
    ValChar[2]='0'+((ValDec%1000)%100)/10;
    ValChar[3]='0'+((ValDec%1000)%100)%10;
    //fonction de conversion analogique numerique calcul de COURANT continue
    void Courant_DC ()
    unsigned int valeur=0;
    long int accum=0;
    unsigned int moy=0;
    int k;
    for(k=0;k<500;k++)
    valeur=Adc_Read(0);
    valeur=((ADRESH << 8) + ADRESL);
    accum=accum+valeur;
    moy=(accum/500);
    DecToChar (moy,VAL);
    //FONCTION D'AFFICHAGE hyperterminal tension RS232
    void hypertension ()
    Usart_Write(VAL[0]);
    Delay_ms(100);
    Usart_Write(VAL[1]);
    Delay_ms(100);
    Usart_Write(VAL[2]);
    Delay_ms(100);
    Usart_Write(VAL[3]);
    // FONCTION AFFICHAGE LCD tension
    void LCDTENSION ()
    unsigned char volt;
    unsigned int volt_oku;
    // char *text;
    long tlong;
    LCD_Cmd(LCD_CURSOR_OFF);
    LCD_Cmd(LCD_CLEAR);
    // text = "CURRENT:";
    Lcd_Out(1,1,"CURRENT:");
    // Lcd_Out(2,1,"POWER:");
    volt_oku=Adc_Read(0);
    volt_oku=((ADRESH << 8) + ADRESL);
    tlong = ((long)volt_oku * 60000) - 10240000;
    tlong = tlong /18944 ;
    volt = tlong / 1000;
    Lcd_Chr(1, 9,48+volt); // X,...
    LCD_Chr_CP('.'); // .,...
    volt = (tlong / 100)%10;
    LCD_Chr_CP(48+volt); // .,X..
    volt = (tlong / 10) % 10;
    LCD_Chr_CP(48+volt); // .,.X.
    volt = tlong % 10;
    LCD_Chr_CP(48+volt); // .,..X
    Lcd_Out(1,14," A");
    Lcd_Cmd(Lcd_CURSOR_OFF);
    //PROGRAMME PRINCIPAL
    void main()
    Init_Main();
    for (i=0;i<=15;i++){
    lcd_chr_cp(msg1[i]);
    delay_ms(100);
    Lcd_Cmd(LCD_SECOND_ROW);
    lcd_chr_cp(msg2[i]);
    delay_ms(100);
    delay_ms(1000);
    lcd_cmd(LCD_CLEAR);
    // Lcd_Chr(1, 1,'A');
    // lcd_chr_cp('&');
    // lcd_chr_cp('S');
    // lcd_chr_cp(msg2[i]);
    while(1)
    if (Usart_Data_Ready())// If data is received
    strInput = Usart_Read();
    switch (strInput)
    case '2': // DUT2
    intcon=0x00;// disactivation d'interruption
    /* PORTD.F0=1;
    PORTD.F1=1;
    PORTD.F2=0;
    PORTD.F3=0; */
    Courant_DC ();
    hypertension ();
    LCDTENSION();
    break;
    case '1': // DUT1
    /*PORTD.F0=0;
    PORTD.F1=0;
    PORTD.F2=0;
    PORTD.F3=0; */
    Courant_DC ();
    hypertension ();
    LCDTENSION();
    break;
    pleaaaaase help.
    invite29971eb1
    Re : undeclared identifier!!!!
    Tes fonctions usart_init et lcd_config sont définies ailleurs.
    Il ne s'agit pas d'une question pour un forum mais des bases de la programmation en C...Tu devrais vite aller refaire un tour dans les premiers chapitres
    Allez, un petit indice.... "#include"
  1. Os a identifier
    Par invite32c52df2 dans le forum Archéologie
    Réponses: 16
    Dernier message: 03/07/2022, 06h02
  2. Os à identifier
    Par invite06b2ccb7 dans le forum Paléontologie
    Dernier message: 27/06/2010, 16h23
  3. Insecte à identifier
    Par invitec19c7cab dans le forum Identification des espèces animales ou végétales
    Dernier message: 10/11/2008, 21h20
  4. Identifier un insecte
    Par invitee02f3fed dans le forum Identification des espèces animales ou végétales
    Dernier message: 09/11/2008, 18h53
  5. Reptile à identifier
    Par invite3ff396ad dans le forum Identification des espèces animales ou végétales
    Dernier message: 06/11/2008, 19h15
