Pic32mx mplab v8.92
Pic32mx mplab v8.92
    davidif
    Pic32mx mplab v8.92
    Afin de me familiariser avec ce micro, je fait quelque essai de configu et ne comprend pas une chose, pourquoi l'horloge de mon système cadence à 80MHZ alors qu'il devrait etre a 160Mhz d'après la programmation ci-dessous:
    Code:
     *      PIC32MX
     * FileName:        main.c
     * Dependencies:    plib.h
     * Processor:       PIC32MX
     * Complier:        MPLAB C32
     *                  MPLAB IDE
     * Company:
     * auteur:
    #include <plib.h>
    #include "fonction.h"
    #define extern
    #include "definition.h"
    #undef extern
    #if defined (__32MX360F512L__) || (__32MX460F512L__) || (__32MX795F512L__) || (__32MX430F064L__)
    #pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_1, FPLLODIV = DIV_1, FWDTEN = ON
    #pragma config POSCMOD = OFF, FNOSC = FRCPLL, FPBDIV = DIV_1
    #endif
    void init_port(void)
        // Clear PORTA bits so there are no unexpected flashes when setting
        // them to output in the next step
        mPORTDClearBits(BIT_2 |BIT_1 | BIT_0);
    	mPORTBClearBits(BIT_8|BIT_9 |BIT_10 | BIT_11);
        // Make lower four bits of PORTD as output
        mPORTDSetPinsDigitalOut(BIT_3 |BIT_2 |BIT_1 | BIT_0);
    	mPORTBSetPinsDigitalOut(BIT_8|BIT_9 |BIT_10 | BIT_11);
    void init_timer1(void)
    	// Configure Timer 1 using PBCLK as input, 1:256 prescaler
        // Period matches the Timer 1 frequency, so the interrupt handler
        // will trigger every one second...
    	//OpenTimer1(T1_ON | T1_SOURCE_INT | T1_PS_1_1, PERIOD);
    	T1CONbits.ON=1;	   //enable clock timer1
    	T1CONbits.TCS=0;   //internal clock
    	T1CONbits.TCKPS=0; //Prescalaire 1:1
    	INTClearFlag(INT_T1);
        // Set up the timer interrupt
        //INTEnable(INT_T1, INT_ENABLED);
    	ConfigIntTimer1(T1_INT_ON | T1_INT_PRIOR_2);
    // Configure the Timer 1 interrupt handler
    void __ISR(_TIMER_1_VECTOR, ipl2) Timer1Handler(void)
        	// Clear the interrupt flag
      		mPORTDToggleBits(BIT_2 | BIT_1 | BIT_0);
    		mPORTBToggleBits(BIT_8|BIT_9 |BIT_10 | BIT_11);
    int main(void)
    	// Enable multi-vector interrupts
        INTConfigureSystem(INT_SYSTEM_CONFIG_MULT_VECTOR);
        INTEnableInterrupts();
        INTEnableSystemMultiVectoredInt();//ClrWdt();
    	init_timer1();
    	init_port();
    	init_variable();//ClrWdt();
    	//PORTSetPinsDigitalOut(IOPORT_D,BIT_3);
     		while (1)
    return 0;
    Mon timer met 816uS pour compter de 0000 à FFFF, donc correspond à 80Mhz et non pas 160Mhz comme configuré.
    Avez vous une idée
    invite860936ec
    Re : Pic32mx mplab v8.92
    Citation Envoyé par davidif Voir le message
    Avez vous une idée
    bonjour, la fréquence max des pic32mx est de 100mhz (32MX450xxx) et 80MHZ (pic 32MX460xxx)
    donc , pas possible de monter à 160 mhz.
    davidif
    Merci Guillaume83 pour ta réponse, effectivement je n'ai pas regardé la limite technique en fréquence qui est de 80Mhz pour les PIC32MX5XX/6XX/7XX d'après mes docs, malgrés que j'ai testé pouvoir aller jusqu'a 96Mhz en FPLLMUL = MUL_24, je me suis basé uniquement sur le code qui d'après lui m'amenait à FPLLMUL = MUL_20 donc 160Mhz je ne savais pas que le micro limitait au dessus de 100Mhz.
    Que je fasse FPLLMUL = MUL_20, FPLLIDIV = DIV_1 ou FPLLMUL = MUL_20, FPLLIDIV = DIV_2 j'ai toujours mes 80Mhz, je suis donc limité, mais par contre je ne comprend pas une chose ?
    Poourquoi n'ai-je pas la même fréquence quand je fais FPLLMUL = MUL_20, FPLLIDIV = DIV_1, FPLLODIV = DIV_2 ou FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1 ? on divise par deux dans les deux cas que je sache ?
    invite860936ec
    fpllidiv (Frequence Pll In Diviseur) est avant la pll, il est utilisé pour addapter la fréquence d'entree (4MHZ<F entree PLL< 5MHZ)en fonction du quartz utilisé.
    fpllodiv(Frequence Pll Out Diviseur) est en sortie de la PLL, il est utilisé pour diviser la fréquence de sortie de la PLL en fonction des besoins .
    EX:
    Fréquence quartz: 8Mhz
    fpllidiv=2 -> F entrée PLL=4mhz ->pll multiplier=20 ->frequence sortie Pll=80mhz -> fpllodiv=2 sysclk=40mhz
    Fréquence quartz: 4Mhz
    1: fpllidiv=1 -> F entrée PLL=4mhz ->pll multiplier=20 ->frequence sortie Pll=80mhz -> fpllodiv=2 sysclk=40mhz
    2: fpllidiv=2 -> F entrée PLL=2mhz ->pll multiplier=20 ->frequence sortie Pll=40mhz -> fpllodiv=2 sysclk=20mhz (exemple hors spécification microchip car f entree pll doit etre 4MHZ<F entree PLL< 5MHZ
    dans tous les cas, 80mhz et 4MHZ<F entree PLL< 5MHZ sont des valeurs garanties par microchip. il est possible de les dépasser mais alors les résultats ne sont plus garantis par microchip
    RISC
    David,
    Tu as oublié une chose très importante qui doit se trouver au début de chaque programme pour un PIC32 :
    Code:
    #define FCY 80000000UL
    SYSTEMConfigPerformance( FCY);  // configurer pour la performance maximum
    NB : le PIC32 divise par 1 : Fcy = Fosc
    a+
    davidif
    En fait Risc, ce que tu définis au début c'est la fréquence de fonctionnement du pic si je ne me trompe pas ? c'est a dire que tu définis 80Mhz.
    avec
    Moi j'ai défini cette fréquence à 8Mhz
    #pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = ON
    // Mode oscillateur int, pas de PLL, FPB/1
    #pragma config POSCMOD = OFF, FNOSC = FRC, FPBDIV = DIV_1
    et ça fonctionne correctement .
    RISC
    Si tu n'as pas besoin de tourner à 80MHz pas de PB, par contre il faut quand même faire :
    Code:
    #define FCY 8000000UL    // entrer la fréquence réelle à laquelle travaille le PIC
    A 8MHz, tu n'auras aucun wait state pour aller chercher des instructions, la limite tant 30MHz
    SYSTEMConfigPerformance( FCY) va optimiser les initialisations internes pour donner le maximum de performance à la fréquence choisie par l'utilisateur.
    Cette fonction retourne je crois FPBDIV, s'il n'est pas à 1 tu utilises la macro pour le reforcer à 1 si nécessaire.
    a+
    davidif
    a quoi sert les wait stat ? effectivement j'ai mis cette instruction en texte puisqu'une fois la fréquence défini dans les pragma elle n'était plus nécessaire, enfin je croyais
    SYSTEMConfig(SYS_FREQ, SYS_CFG_WAIT_STATES | SYS_CFG_PCACHE);
    et que veut dire le UL à la fin
    tu me dis qu'au minimum la fréquence doit être de 30Mhz et dans l'idéale pour bien fonctionner un micro doit être à combien ?
    RISC
    Pour les "wait states" .. voir la documentation de la FLASH du PIC32 ou encore mieux :Si tu comprends pas ce mot utilises la macro que je t'ai conseillée :
    C'est justement fait pour ne pas avoir à s'occuper de cela ;=)
    La fréquence maximum du PIC32 est 80MHz mais si tu n'as pas besoin de tourner à 80MHz n'importe quelle autre fréquence plus basse est acceptable.
    Pour UL (unsigned long) à la fin, voir la documentation sur le langage C
    a+
    Dernière modification par RISC ; 20/10/2013 à 00h00.
    davidif
    Ok merci pour l'info RISC, d'ailleurs pourrais tu m'aider sur un autre sujet dont je n'arrive pas à avancer
    http://forums.futura-sciences.com/el...s-pic32-2.html
    Problème qui pourtant me paraissai pas compliqué à la base
  1. PIC32MX boîtier VTLA
    Par invite3026ff02 dans le forum Électronique
    Dernier message: 25/08/2013, 06h30
  2. Routine Interruption Pic32MX
    Par invitee13c535c dans le forum Électronique
    Dernier message: 28/01/2013, 21h33
  3. RTCC Pic32Mx
    Par invite024026d4 dans le forum Électronique
    Dernier message: 23/11/2012, 10h07
  4. Timer PIC32MX
    Par invitee8f75e57 dans le forum Électronique
    Dernier message: 26/07/2012, 09h38
  5. PWM Sur PIC32MX
    Par inviteddae56c8 dans le forum Électronique
    Dernier message: 23/09/2011, 23h25
