PIC] Compilateur CCS C - Problème utilisation PORTB PIC 16F876a
    invite087fa5ab
    j'utilise le compilateur c de ccs.
    -le compilateur indique 0error j'ai transférer le fichier HEX à proteus mais il ne se passe rien au niveau du PORTB s il vous plait aidez moi .voici le programme:
    #include <16F876A.h>
    #include <float.h>
    #include <math.h>
    //#device *=16 ADC=8 //16bit pointer, 8-bit ADC
    #use delay(clock=20000000)
    #fuses HS,NOWDT,NOPROTECT,PUT,NOWRT,B ROWNOUT,NOLVP
    #define TRISA 0b00000000
    #define TRISB 0b00000000
    #define TRISC 0b00000000
    #define Port_Ai 0b00000000 //Initial valua for Port A
    #define Port_Bi 0b00000000 //Initial valua for Port B
    #define Port_Ci 0b00000000 //Initial valua for Port C
    typedef struct {
    int1 bit0;
    int1 bit1;
    int1 bit2;
    int1 bit3;
    int1 bit4;
    int1 bit5;
    int1 bit6;
    int1 bit7;
    } flags;
    //Important time variables
    float ts, ta, tb, t0, tmag; //time related variable
    //Important phase variables
    float phase, phaset1; //to identify sector number
    float phaset2, thetha, thetha1, thetha2; //to calculate related time variables
    float modin; //modulation index
    float ZZ; //to convert angles larger than 360 degrees into the scale of 0 to 360 degrees
    //Important voltage related variables
    float vref, vdc; //to calculate modulation index
    //Other variables
    int8 i, j, h; //counter
    float nsamp, result1; //condition for one complete cycle
    int8 n; //sector number
    //Variables for Rounding up Process
    float result, integral, integral1, XX; // variables for rounding up process
    int8 YY, integral2;
    float testa1;
    //Interrupt Bit
    flags sys01;
    #define flg_10ms sys01.bit0
    //Arrays of Outputs of Each Sector (1 to 6)
    int8
    outta1[8]={0b00000000,0b00000100,0b0000 0110,0b00000111,0b00000111,0b0 0000110,0b00000100,
    0b00000000}; //test mar
    int8
    outta2[8]={0b00000000,0b00000010,0b0000 0110,0b00000111,0b00000111,0b0 0000110,0b00000010,
    int8
    outta3[8]={0b00000000,0b00000010,0b0000 0011,0b00000111,0b00000111,0b0 0000011,0b00000010,
    int8
    outta4[8]={0b00000000,0b00000001,0b0000 0011,0b00000111,0b00000111,0b0 0000011,0b00000001,
    int8
    outta5[8]={0b00000000,0b00000001,0b0000 0101,0b00000111,0b00000111,0b0 0000101,0b00000101,
    int8
    outta6[8]={0b00000000,0b00000100,0b0000 0101,0b00000111,0b00000111,0b0 0000101,0b00000100,
    int8 timema[8];
    //Initialization
    void init(){
    setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
    // enable_interrupts(INT_RDA);
    enable_interrupts(GLOBAL);
    enable_interrupts(INT_TIMER1);
    //Function to transfer output from array to output port
    void showout(){
    if(n == 1)
    for(j=0;j<8;j++)
    output_b(outta1[j]);
    delay_ms(timema[j]);
    if(n == 2)
    for(j=0;j<8;j++)
    output_b(outta2[j]);
    if(n == 3)
    for(j=0;j<8;j++)
    output_b(outta3[j]);
    if(n == 4)
    for(j=0;j<8;j++)
    output_b(outta4[j]);
    if(n == 5)
    for(j=0;j<8;j++)
    output_b(outta5[j]);
    if(n == 6)
    for(j=0;j<8;j++)
    output_b(outta6[j]);
    //Function to round up ta, tb and t0
    void roundup()
    result=modf(XX,&integral);
    YY = integral;
    if ((result >=0) && (result <0.5))
    YY = YY + 0;
    else{
    if ((result >= 0.5) && (result < 1))
    YY = YY + 1;
    //Function to identifying sector number
    void idsec()
    for(i=1;i<=6;i++)
    phaset1 = i*3.142/3;
    phaset1 = phaset1 - phase;
    phaset2 = phase - (i - 1)*3.142/3;
    if((phaset1 >=0) && (phaset2 >=0))
    n = i;
    //Function to collect and re-insert rounded up numbers for important time variables
    void rdjob()
    XX = ta;
    roundup();
    ta = YY;
    XX = tb;
    roundup();
    tb = YY;
    XX = t0;
    roundup();
    t0 = YY;
    //Function to obtain input details
    void in_put()
    vdc = 10;
    vref = 10;
    //fundamental frequency of 10 Hz (100 samples)
    phase = 2*3.142*h*0.01;
    // Calculation of time ta, tb, ts and t0
    void tcal()
    ts = 1000/100;
    thetha = phase;
    thetha1 = (n*3.142/3) - thetha;
    thetha2 = thetha - (n - 1)*3.142/3;
    tmag = (sqrt(3))*(modin)*ts/4; //moin=vref1/vdc1
    ta = (tmag)*(sin(thetha1)); //test time
    tb = (tmag)*(sin(thetha2)); //test time
    t0 = ts - ta - tb;
    t0 = t0/2;
    rdjob();
    //Putting times into timema array
    timema[0]=t0;
    timema[3]=t0;
    timema[4]=t0;
    timema[7]=t0;
    timema[1]=ta;
    timema[6]=ta;
    timema[2]=tb;
    timema[5]=tb;
    //Main function
    void main()
    Mainloop:
    nsamp = 100;
    result1=modf(nsamp,&integral1) ;
    integral2=integral1+1;
    h=1;
    do
    in_put();
    idsec();
    tcal();
    h++;
    } while (h < integral2);
    goto Mainloop;
    carcan
    Re : PIC] Compilateur CCS C - Problème utilisation PORTB PIC 16F876a
    Hello !
    tu n'appelles jamais ta fonction "Init", un programme écrit en CCS soit avoir une structure de ce genre :
    Code:
    void main()
       float Measure;
       int1 Hold = 0;
       char c;
       setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);
       Offset = read_int16_eeprom(0);
       Divid = read_float_eeprom(2);
       usb_cdc_init();
       usb_init();
       lcd_init();
       // [TOUT CE QUI FAIT PARTIE DE L'INITIALISATION]
       printf (lcd_putc,"\f");
       while(TRUE)
           //USB Dialog
           usb_task();
           // [TOUT CE QUI FAIT PARTIE DE LA BOUCLE PRINCIPALE]
    Sinon, je n'ai regardé qu'en vrac, mais ce n'est pas très judicieux (à mon avis) de faire des racines carrées et autres calculs longs avec un 16F !!!
    Laurent
  1. Problème utilisation PORTB PIC 16F876
    Par invite62afc4d2 dans le forum Électronique
    Dernier message: 19/06/2011, 17h06
  2. Probléme Pour Configurer le PORTB
    Par invite7cda0f37 dans le forum Électronique
    Dernier message: 06/02/2011, 12h26
  3. problème CAN pic 16F876A
    Par invitecd1c8761 dans le forum Électronique
    Dernier message: 06/04/2010, 14h17
  4. problème programmation d'un pic 16F876A
    Par invite7304b6e0 dans le forum Électronique
    Dernier message: 29/08/2007, 16h18
