[Autre] Diptrace 5.0 version bêta
    Janpolanton
    Diptrace 5.0 est téléchargeable : https://diptrace.com/fr/download/download-diptrace/
    mag1
    Re : Diptrace 5.0 version bêta
    Merci, j'ai la version 4.3 . Tu connais les différences?
    MM
    Janpolanton
    Salut mag1,
    Je l'ai téléchargé mais pas encore essayé.
    Il y a manifestement pas mal de nouveauté, plus ou moins utiles à notre niveau d'utilisation je pense.
    Voilà la liste des changements issue de leur site :
    - Digital SPICE Simulator.- Plugins + documentation how to make plugins with any programming language.
    - Examples of plugins with source codes:
    Make solder mask openings for selected trace segments (Object Pascal, Delphi);
    Make dashed/dotted lines (C#).
    - PCB Calculator:
    Trace Width, Clearance, Current, Resistance;
    Transmission Line and Differential Pair Width, Gap, Impedance;
    Width, Length, Gap and Layer Stackup could be set by selected trace/layout settings or manually.
    - Planar Inductors: adjusting parameters and placing to layout or saving to library.
    - Cross Selection and Highlight between PCB and Schematic.
    - "Place selected by list" option in PCB Layout (allows to select blocks in Schematic and make component placement in PCB Layout by using cross selection feature).
    - Via Stitching for copper pours, polygons, board.
    - Via Shielding for traces.
    - Export Schematic and PCB to PDF directly.
    - Updating PCB from Netlist of any third-party software.
    - Assigning any copper layer shape to pad in Pattern Editor.
    - Wire/Trace color transfer between PCB and Schematic (Convert to PCB / Update from Schematic / Back annotate).
    - New and updated component libraries:
    Capacitors (Film Axial Vertical, Film Radial);
    Diodes (Axial Vertical);
    Opto (Bar Graphs, Emitters LED Light Bars);
    Opto Displays (LCD, OLED, 7-Segment LED, Dot Matrix);
    Resistors (Axial Vertical);
    Objects (Pad Special, Plated Half-Holes, Digital Spice Models).
    - New and updated pattern libraries:
    Capacitors (Axial Vertical, Molded, Radial Dipped Rectangular);
    Displays (LCD, 7-Segment LED, OLED, Dot Matrix);
    LED (DIP, SIP);
    Objects (Pad Special, Plated Half-Holes).
    - Push and Shove Router is not included in beta-version yet (debug and integration in process).
    Janpolanton
    Pour ceux qui sont intéressés par cette version en "freeware" 500 broches / 2 couches, il faudra demander une nouvelle clé d'enregistrement car celle qui vous a été fournie pour la version 4.x n'est pas compatible.
    Ci-dessous, j'ai volontairement masqué mes clés...
    Hello JP,
    Thank You for contacting us!
    You can use the following registration data for DipTrace Non-Profit License (Lite):
    User name: Non-profit use only
    Reg key for version 4.x: yyyy-yyyy-yyyy-yyyy-yyyy
    Reg. key for version 5.x: xxxx-xxxx-xxxx-xxxx-xxxx
    The registration data should be copied into nag-screen or Help/Register
    dialog box. If you don't have the program yet, please download it from
    https://diptrace.com/download/download-diptrace/
    With kind regards,
    Victor Savenko
    DipTrace Team
    Dernière modification par Janpolanton ; 10/03/2024 à 08h22.
  1. [Outils/Fab/Comp] Question DipTrace
    Par mag1 dans le forum Électronique
    Dernier message: 23/06/2021, 22h17
  2. Fausse version béta, mais vrai troyen
    Par yoda1234 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 23/05/2010, 16h42
  3. [MAJ] MSN messenger 7 disponible au téléchargement en version beta
    Par invite37693cfc dans le forum Logiciel - Software - Open Source
    Dernier message: 08/10/2004, 12h57
