compiler un programme
    invitec35bc9ea
    Arrow compiler un programme
    bonsoir,
    j'essai depuis quelques temps de compiler les sources de "openfem", et je bute sur l'etape 3:
    Code:
    3/ Include OpenFEM in your default path. For this, launch Matlab and
    change directories to <installdir>/openfem, then run the path check:
    ofutil('path')
    Then save your updated path for future Matlab sessions or include the above
    lines in your startup.m file, see matlabrc, (or have your system administrator
    modify your $MATLAB/toolbox/local/pathdef.m file).
    4/ Move the openfem/html directory to $MATLAB/help/toolbox/openfem if you want
    it to be seen by MATLAB (cf. 2/).
    5/ Compiling
    For proper operation of OpenFEM, you should have three mex files (compiled
    dynamically linked libraries). of_mk is the gateway interface for
    FORTRAN routines of the OpenFEM library. sp_util groups C routines
    used for model assembly and associated functions. nopo2sd provides
    translation between the NOPO format of MODULEF and the OpenFEM format.
    You can compile these functions using the associated ofutil commands
    (help ofutil). Or the combined ofutil('mexall').
    You are done !
    You will find demos of OpenFEM capabilities in the openfem/demos and
    openfem/test directories.
    quecun pourrai-t-il, m'aider à y voir plus clair?
    http://www-rocq.inria.fr/OpenFEM/art...?id_article=31
    invitec35bc9ea
    Re : compiler un programme
  1. SourceBoostC C compiler
    Par invite553ae296 dans le forum Électronique
    Réponses: 62
    Dernier message: 17/09/2007, 22h40
  2. CCS compiler
    Par invitefc1671e3 dans le forum Électronique
    Dernier message: 16/09/2007, 21h27
  3. compiler source C
    Par invitec35bc9ea dans le forum Logiciel - Software - Open Source
    Réponses: 23
    Dernier message: 01/05/2007, 04h46
  4. compiler un programme assembleur avec le DOS
    Par invite0b127ea6 dans le forum Logiciel - Software - Open Source
    Dernier message: 05/09/2006, 11h47
  5. re-compiler? (logiciel R)
    Par kinette dans le forum Logiciel - Software - Open Source
    Dernier message: 25/01/2006, 10h14
