Problème Matlab
Problème Matlab
    invite3875204e
    Problème Matlab
    alut je vois dans cet forum que tu as déjà rencontré mon problèlme est ce que tu peux m'aider STP
    j'essaye de faire un programme dans matlab pour modifier un texte :
    mon texte et le suivant
    Code :
    Code:
    $$ Generated on November-07-09 1:41:06 PM
    $$ CATIA APT VERSION 1.0
    $$ Manufacturing Program.1
    $$ Part Operation.1
    $$*CATIA0
    $$ MSYS/
    $$ 0.00000 1.00000 0.00000 -95.00000
    $$ -1.00000 0.00000 0.00000 63.50000
    $$ 0.00000 0.00000 1.00000 40.00000
    $$ ICAM - MM PPTABLE / ICAM_MM.pptable- V16.0541
    $$ Part Operation : Part Operation.1
    $$ Manufacturing Program : Manufacturing Program.1
    PARTNO Manufacturing Program.1
    UNITS/MM
    $$ Do not diagnose CYCLE/OFF when cycles are not active
    PPFUN/15,1318046,OFF
    $$ Do not diagnose FEDRAT when threading
    PPFUN/15,1319003,OFF
    $$ Ignore TLAXIS commands, use vector on GOTO instead
    SYN/'TLAXIS','$$*TLAXIS'
    $$ OPERATION NAME : Tool Change.1
    $$ Start generation of : Tool Change.1
    MULTAX/ON
    $$ TOOLCHANGEBEGINNING
    CUTTER/ 4.763000, 2.381500, 0.000000, 2.381500, 0.000000,$
    0.000000, 5.000000
    $$ Select sequence 2 to include tool compensation (OSETNO)
    PPRINT TOOL: T1 End Mill D 10
    LOADTL/1
    COOLNT/
    $$ TOOLCHANGEEND
    $$ End of generation of : Tool Change.1
    PPRINT OPERATION: Multi-Axis Flank Contouring.1
    $$ OPERATION NAME : Multi-Axis Flank Contouring.1
    $$ Start generation of : Multi-Axis Flank Contouring.1
    SPINDL/ 60.0000,RPM,CLW
    FEDRAT/ 2000.0000,MMPM
    GOTO / -4.00000, 81.50000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / 1.00000, 81.50000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / 1.00000, 81.50000, 2.13150,-1.000000, 0.000000, 0.000000
    SPINDL/ 30.0000,RPM,CLW
    FEDRAT/ 180.0000,MMPM
    GOTO / 1.00000, 76.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 1.00000, 63.00000, 2.13150,-1.000000, 0.000000, 0.000000
    SPINDL/ 35.0000,RPM,CLW
    GOTO / 1.00000, 52.50000, 2.13150,-1.000000, 0.000000, 0.000000
    SPINDL/ 40.0000,RPM,CLW
    GOTO / 1.00000, 42.00000, 2.13150,-1.000000, 0.000000, 0.000000
    SPINDL/ 45.0000,RPM,CLW
    GOTO / 1.00000, 31.50000, 2.13150,-1.000000, 0.000000, 0.000000
    SPINDL/ 50.0000,RPM,CLW
    GOTO / 1.00000, 21.00000, 2.13150,-1.000000, 0.000000, 0.000000
    SPINDL/ 55.0000,RPM,CLW
    GOTO / 1.00000, 10.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 1.00000, 0.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 1.00000, -5.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 1.00000, -5.00000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / -4.00000, -5.00000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / -3.00000, 81.50000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 81.50000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 81.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 76.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 63.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 52.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 42.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 31.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 21.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 10.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, 0.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, -5.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 2.00000, -5.00000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / -3.00000, -5.00000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / -2.00000, 81.50000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 81.50000, 7.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 81.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 76.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 63.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 52.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 42.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 31.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 21.00000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 10.50000, 2.13150,-1.000000, 0.000000, 0.000000
    GOTO / 3.00000, 0.00000, 2.13150,-1.000000, 0.000000, 0.000000
    ce que je chercher à faire c'est de supprimer toutes les lines sauf les lines ou il ya "GOTO" et "FEDRAT"
    ça veut dire à la fin j'aurai un text ou il ya juste les valeurs de GOTO et FEDRAT
    zak
    Dernière modification par yoda1234 ; 06/12/2009 à 05h11.
    yoda1234
    Re : Problème Matlab
    Rappel de notre charte qui dit:
    Les doublons ne sont pas autorisés. Merci de ne pas poster le même sujet dans plusieurs rubriques pour éviter l'éparpillement des discussions.
    De plus, tu devrais éviter de t'incruster dans un fil datant de deux ans.
    Je t'invite également a utiliser les fonctionnalités de l'éditeur de texte, en effet tu aurais dû utiliser la fonction "Code" symbolisée par ceci pour introduire tes lignes de code.
    Là où l'ignorance est un bienfait, c'est de la folie d'être sage (Thomas Gray).
  1. problème interface MATLAB
    Par invite7b1518cc dans le forum Électronique
    Dernier message: 23/09/2007, 15h24
  2. Problème 3D Matlab
    Par invited6e52fb2 dans le forum Logiciel - Software - Open Source
    Dernier message: 23/06/2006, 14h38
  3. Probléme MATLAB
    Par invitef03e0ed1 dans le forum Logiciel - Software - Open Source
    Dernier message: 17/05/2006, 10h48
  4. probleme matlab
    Par invitefe22fd59 dans le forum Logiciel - Software - Open Source
    Dernier message: 25/04/2005, 10h39
  5. problème matlab
    Par invitef5b3a62a dans le forum Logiciel - Software - Open Source
    Dernier message: 23/02/2005, 09h51
