conversion matlab vers mathematica
    invitea41a00b4
    J'ai recu plusieurs codes écrits en Matlab, et je voudrais les convertir en Mathematica. Je ne sais pas me servir de Mathlab et mon établissement ne le possede pas donc je dois absolument les convertir en Mathematica . Est ce que quelqu'un peut m'aider ? Merci d'avance
    Voici les codes:
    (1er code)
    (Defining the constant surface for the Poincare section
    Zerocross2.m)
    function [v,ist,df] = zerocross2(t,x,varargin)% varargin absorbs unwanted
    parameters flag,g,l1, etc
    % event function for test_poincare.m
    v = sin(x(2)); % event is x(2)=0 (ie when v is zero)
    %v = x(2);
    ist = 1; % if true, terminate evolution when this event occurs
    df = 1; % increasing sense only
    (2ème code)(Producing the trajectory of the outer bob, Poincare section, angular velocity graph and energy of the system
    PoincareTrajecAngleEnergy.m)
    clear
    %Code mainly adapted from Alexander Barnett
    %declare time step
    T = 10;
    %y0 = [0;0;-2;0]; % close to regular
    %y0 = [pi;pi;0;0];
    % y0 = [pi;pi;.5;0]; % chaotic
    % y0=[0.5233;0;0.5233;0]%periodic
    y0 = [0.2,0.2828,0,0]%perfect periodic with energy = 0.7809
    %y0 = [0.2,-0.2828,0,0]%perfect quasiperiodic with energy = 0.7809
    %y0 = [27.8;0;1.22;2.62] %perfect KAM scenario
    %y0 = [0,0,2,20]
    %y0 = [0,0,1,20];
    y0 =[pi;0;.5;.5];%high energy
    s=ode45(@doublependulum2,[0,T],y0,[],0,1,1,1,1);
    t = 0:0.01:T; x = deval(s,t)';
    x1=sin(x(:,1));
    y1=-cos(x(:,1));
    x2=x1+sin(x(:,2));
    y2=y1-cos(x(:,2));
    figure; plot(x2,y2); axis equal; xlabel('position');ylabel('vel ocity');title
    ('trajectory')
    tmax = 1e2; % max time to wait until next intersection
    ns = 1000; % how many intersection (iterations of P map)
    tp = nan*(1:ns); yp = nan*zeros(numel(y0),ns); yi = y0; % init arrays
    figure;
    for n=1:ns
    s = ode45(@doublependulum2, [0, tmax], yi,
    odeset('Events',@zerocross2,'a bstol',1e-9),0,9.8,1,1,1,1);
    if isempty(s.xe), disp('no intersection found!');
    else tp(n) = s.xe(end); yi = s.ye(:,end); yp(:,n) = yi;
    %plot3(mod(yi(1),2*pi),yi(3),y i(4),'+'); hold on; if mod(n,10)==0, drawnow; end
    % note it's in 3d now
    plot(yi(1),yi(4));hold on; if mod(n,10)==0, drawnow; end
    end
    end
    xlabel('x_1'); ylabel('x_3'); zlabel('x_4'); axis vis3d;
    title('Poincare section (sin(x_2)=0, increasing)');
    figure;
    plot(t,x(:,3),'magenta',t,x(:, 4),'black');title('Angular velocities');
    energy = hamiltonian(y0)
    (3ème code)(Calculates the lyapunov exponent, the average lyapunov exponent and traces the separation of close trajectories
    Crudelyap.m)
    clear
    nruns =100;
    %for calculating average later
    h = zeros(1,nruns);
    %indexing of h
    k = 1;
    for j=1:nruns
    % y0 = [pi+0.1*rand(1);pi;.5;0];
    % y0 = [0+0.1*rand(1);0;-2;0];
    %y0 = [pi;pi;10.515;-2.17];%periodic with T = 0.5
    %y0 = [];%quasiperiodic;
    y0 = [pi+0.1*rand(1);pi;0.5;0];%chaotic
    %y0 = [pi;pi;0;0];
    %y0 = [0;0;-2;0];%close to regular
    %y0 = [27.8;0;1.22;2.62];
    %y0 = [pi;0;0.5;0.5];
    %y0 = [0;0;2;20];
    %y0 = [pi;0;5;5];%high energy
    %y0 = [0.2;0.2828;0;0];%perfect periodic with energy = 0.7809
    %y0 = [0.2+0.1*rand(1);-0.2828;0;0];
    %y0 = [0.2;-0.2828;0;0];%perfect quasiperiodic with energy = 0.7809
    T = 20;
    o = odeset('abstol',1e-14);
    s=ode45(@doublependulum2,[0,T],y0,o,0,1,1,1,1); % note changes
    eps = 1e-9;
    s2 = ode45(@doublependulum2,[0,T],y0+[eps;0;0;0],o,0,1,1,1,1); % note changes
    t = 0:0.01:T; x = deval(s,t)';xe = deval(s2,t)';
    x1=sin(x(:,1));
    y1=-cos(x(:,1));
    x2=x1+sin(x(:,2));
    y2=y1-cos(x(:,2));
    xe1 = sin(xe(:,1));
    ye1=-cos(xe(:,1));
    xe2 = xe1+sin(xe(:,2));
    ye2= ye1-cos(xe(:,2));
    %store the size
    N = numel(ye2);
    %figure; plot(t, [y2 ye2], '-');title('Trajectories of two intial points with a
    distance 10^-9')
    logsep = zeros(1,N);
    %loop fills matrix logsep with natural log of the changing separation
    %between the initial trajectories
    for i = 1:N
    logsep(i) = (log(abs(y2(i)-ye2(i)))-log(eps));
    end
    %figure; plot(t,logsep);title('lyapunov exponent');
    t1=5;
    t2=0.7;
    %stores the exponent in a matric
    h(k) = (logsep(t1/0.01)-logsep(t2/0.01))/(t1-t2);
    k=k+1;
    end
    figure;
    %average lyapunov exponent
    plot(1:j,h)
    title('average lyapunov exponent');
    (4ème code)
    clear
    T = 10;
    %y0 = [0;0;0;10]; %really good
    %y0 = [pi;pi;0.5;0];
    %y0 = [0;0;-2;0];
    %y0=[0;0;2;20];
    y0 = [0.2,-0.2828,0,0];
    y0 = [pi;0;.5;.5]
    %y0 = [pi;pi;0.5;0]
    %find energy for the inital conditions
    %creates a plot with four figures of the variables plotted against each
    %other
    figure;
    subplot(222)
    plot(x(:,3),x(:,4));title('ang ular velocities')
    subplot(221)
    plot(x(:,1),x(:,2));title('ang les')
    subplot(223)
    plot(x(:,1),x(:,3));title('pos itions and momentum of 1')
    subplot(224)
    plot(x(:,2),x(:,4));title('pos itions and momentum of 1')
    invitea41a00b4
    Re : conversion matlab vers mathematica
    aidez moi s'il vous plait c'est important, j'ai surtout du mal à traduire les boucles. Je vais apporter des précisions sur ce que je souhaite faire. Je travaille sur un double pendule. Les équations du mouvement sont données ici : http://gilbert.gastebois.pagesperso-...ule_double.htm. ( dans mon cas, m1=m2=l1=l2=1 ). J'ai déjà résolu les équations differentielles sur Mathematica et obtenu le graphe de la trajectoire et le portrait de phase, mais il me reste le plus important à programmer: la section de poincaré en 2D et 3D (1er code et 2ème code), et le graphe me donnant l'exposant de Lyapunov (3ème code). Merci d'avance
    Jaunin
    Bonjour, Rock_and_drink,
    Si vous avez Mathématica, avez-vous la possibilité d'importé du Matlab ?
    Je vois que vous avez aussi fait d'autre demande, mais encore sans solution, ça ne semble pas évident.
    Wolframe n'a pas de solution ?
    Jaunin__
    http://forums.wolfram.com/mathgroup/archive/1998/May/msg00173.html
    http://www.mathkb.com/Uwe/Forum.aspx...ode-conversion
    invitea41a00b4
    Merci pour votre réponse. Wolfram a une solution, mais il faut avoir Mathematica et matlab. J'ai seulement mathematica et je ne peux pas avoir Matlab
  1. conversion vers une image sous matlab
    Par invite3270ee48 dans le forum Programmation et langages, Algorithmique
    Dernier message: 06/04/2011, 20h16
  2. conversion 2d vers 2.5d
    Par invite1f81e06b dans le forum Mathématiques du supérieur
    Dernier message: 04/11/2010, 18h34
  3. Conversion matlab en scilab
    Par invite60e37dfb dans le forum Mathématiques du supérieur
    Dernier message: 03/09/2010, 23h18
  4. Pb de conversion Matlab/Scilab...
    Par invited706c2ee dans le forum Logiciel - Software - Open Source
    Dernier message: 12/08/2009, 16h13
  5. conversion du C vers le VHDL
    Par invite8dd87bb3 dans le forum Électronique
    Dernier message: 04/05/2008, 13h26
