demande de l'aide
demande de l'aide
    safouane271289
    demande de l'aide
    Code HTML:
    index.html
    <html>
        <head>
            <script type="text/javascript">
                function verif()
    if((f.log.value)!==(f.pass.value))
            alert("mot de pass et login invaldes" )
       else if((f.log.value=="" ) && (f.pass.value=="" ))
                alert("le login et mot de pass sont vide" );
            else if ((f.log.value="admin" ) && (f.pass.value="admin" ))
              if (f.liste[0].selected)
                  alert("Nesus" )
              else
                  window.open('nmap.html')
                obj=new packages.com.outil.scan.Nessus();
    </script>
    </head>
        <body background="kali-linux.jpg">
            <div><h1><center><font Color="#FFFF00"><marquee >Bienvenue dans Ma Plateforme</font></h1></center></marquee></div>
                            <center>
                                <form name="f">
            <table>
                <TR><TD align='right'><font Color="#FFFF00">Votre Login</font></TD><TD><INPUT size=12 name='log'></TD></TR>
                <TR><TD align='right'><font Color="#FFFF00">Votre mot de passe</font></TD><TD><INPUT type=password size=12 name='pass'></TD></TR>
                <tr><td><font Color="#FFFF00">Choisir une outil</font></td>
                    <td>
                        <select name="liste">
      <option value="Nessus">Nessus</option>
      <option value="Nmap">Nmap</option>
    </select>
                    </td>
            </tr>
            <tr><td></td><td>
                    <p> <input  type="submit" value="ok" onclick=verif()>
                      <input  type="reset" value="Annuler" ></p>
                </td></tr>
                    </table>
        </form>
                        </center>
        </body>
    </html>
    Nessus.java
    package com.outil.scan;
    import java.io.BufferedReader;
    import java.io.InputStreamReader;
    public class Nessus {
     public static void main(String[] args) {
     	Nessus obj = new Nessus();
     	//in mac oxs
     	String command = "/etc/init.d/nessusd start";
                    String command1= "iceweasel www.google.fr" ;
     	//in windows
     	//String command = "ping -n 3 " + domainName;
     	String output = obj.executeCommand(command);
     	System.out.println(output);
     private String executeCommand(String command1) {
     	StringBuffer output = new StringBuffer();
     	Process p;
                    Runtime r = Runtime.getRuntime();
     	try {
                        r.exec(" iceweasel https://kali:8834/html5.html#/scans" );
       p = Runtime.getRuntime().exec(command1);
       p.waitFor();
       BufferedReader reader =
                                new BufferedReader(new InputStreamReader(p.getInputStream()));
                            String line = "";
       while ((line = reader.readLine())!= null) {
       	output.append(line + "\n" );
     	} catch (Exception e) {
       e.printStackTrace();
     	return output.toString();
    1-je veux que mon code Nessus.java est exécuté lorssque j'appuis sur le boutton html ok .Je souhaiterais que tu teste ce deux code et tu va comprendre mieux
    Code HTML:
    code nmap.html
    <html>
        <head>
            <title></title>
            <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
        </head>
            <div><h1><center><font Color="#FFFF00">Nmap</font></h1></center></div>
    <center><textarea cols="60" rows="20"></textarea></center><p></p>
    <center><input type="submit" value="Valider"></center>
        </body>
    </html>
    code nmap.java
    public class Nmap {
     	Nmap obj = new Nmap();
     	//in mac oxs
     	String command = "nmap  192.168.1.2 ";
     	//in windows
     private String executeCommand(String command) {
     	Process p;
     	try {
       p = Runtime.getRuntime().exec(command);
       p.waitFor();
                            String line = "";
    2- comme pour mon premier demande (éxècute le code java dans boutton html) mais je souhaiterais que le résultat de nmap.java est affiche dans le textarea
    et merci pour votre collaboration
    Dernière modification par JPL ; 07/04/2014 à 19h45. Motif: ajout de balises html
    bisou10
    Re : demande de l'aide
    C'est une blague ? Java != Javascript !
    invitef35ebd48
    Avec du PHP et sa fonction exec() ça me parait jouable : t'appelle ta classe en ligne de commande sur ton serveur.
    bisou10
    Dans ce cas il vaut mieux passer par une page jsp, je suppose. Objectivement, c'est réalisable, mais honnêtement, cela signifie récupérer les données issues de java, les aller-retour entre serveur/client, bref, dans le meilleur des cas, un code inbitable
    invite0bbe92c0
    Citation Envoyé par bisou10 Voir le message
    Quand on en est à tester la valeur du username en constante dans le code client, on est plus à ça près ....
    invitef35ebd48
    Mais sinon c'est obligé de passer par une page html ? Parce pour appeler du java, le plus simple ,c'est quand même de faire une IHM en java.
    Jack
    Il va falloir arrêter avec ces titres qui ne veulent rien dire. On le sait que tu ouvres une discussion parce que tu as besoin d'aide.
    je rappelle que d'après la carte de Futura, LES TITRES DOIVENT ETRE EXPLICITES
  1. demande d'aide
    Par invitee3faf6b4 dans le forum Mathématiques du supérieur
    Dernier message: 13/03/2014, 14h06
  2. demande d aide
    Par invite15af46dd dans le forum Électronique
    Réponses: 23
    Dernier message: 10/05/2013, 13h59
  3. demande d'aide svp
    Par invite5dc3fc1e dans le forum Électronique
    Dernier message: 20/12/2012, 17h08
  4. demande d'aide
    Par invitebe79128b dans le forum Technologies
    Dernier message: 14/03/2010, 16h07
