Matlab "Unable to convert expression containing symbolic variables into ddouble array"
    turbulent
    Bonjour tout le monde. Merci de m'aider à corriger "Unable to convert expression containing symbolic variables into ddouble array"
    Code:
    %Root of linear or nonlinear function
    % Root-Finding in Matlab of function
    %defined on interval [a,b]
    clc
    %format short
    %format long
    % Find all roots of function real.
    % Solve Eq f(x)=0 on interval [a,b].
    L=3;
    A=1.08;
    f=@(x) tan(L*x)+2*x;
    a=-5;
    b=5;
    fplot(f,[a,b]),grid on;
    zero=fzero(@(x)f(x),a);
    oldzero=zero;
    zerotot=zero;
    eps=1e-6;
    nRoots=100;
    for i=a:0.01:b
    zero=fzero(@(x)f(x),i);
    long=length(zerotot);
    if abs(zero - zerotot)> eps & (a<= zero) & (zero <= b)
    zerotot=[zerotot;zero];
    long=long+1;
    end
    oldzero=zerotot(long);
    end
    index=find(zerotot<a);
    zerotot(index)=[];
    index=find(zerotot>b);
    zerotot(index)=[];
    %Check:
    froots=f(zerotot); % equal to 0?
    index=find(abs(froots)<=eps);
    Roots=sort(zerotot(index))
    z=0:.1:L;%L;%
    %dt =.1;
    for i=1:6
      if i==1
      T=0;
      end
      if i==2
      T= .25;
      end
      if i==3
      T=1;%.2;%*60;% Après 15 min;%1500;
      end
      if i==4
       T=3;%.2;%*60;% Après 20  min;%0.1;
      end
      if i==5
      T=7;%.2;%*60;% Après 30  heure;%
      end
      if i==6
      T=10;%.2;%*60;% Après 40 minutes;
      end
        n=length(Roots);
    syms n
    %Roots=sort(zerotot(index));
    %Roots=subs(sort(zerotot(index)));
    Roots=sym(sort(zerotot(index)));
    % symsum(sin(Roots(i )*z).*sin(Roots(i )*L).*exp(-(Roots(i ).^2).*t )./(1+...
    %         L /2+2*L*Roots(i ).^2),1,length(Roots));
    symsum(sin(Roots.*sym(z)).*sin(Roots*L).*exp(-(Roots.^2).*sym(T) )./(1+...
            L /2+2*L*Roots.^2),1,n);
    fsum=symsum(sin(Roots.*sym(z)).*sin(Roots*L).*exp(-(Roots.^2).*sym(T) )./(1+...
    f=log(A -(A-1)*exp(-sym(z))-4*(A)*exp(L-...
             sym(z)).*exp(-sym(T) ).*fsum); %subs
       % fplot(double(f),z)
    end
    F=subs(f)
    % plot(double(f),z)
    plot(double(F),z)
    %end
    Biname
    Re : Matlab "Unable to convert expression containing symbolic variables into ddouble array"
    Je n'utilise jamais Matlab. Curieux de tester GPT sur le sujet, je lui copie ton msg, il me répond ceci que je ne comprends pas/peu :
     Cliquez pour afficher
    A-t-il raison ?
    Biname
    turbulent
    Merci infiniment Biname.
    Effectivement, le problème résidait dans la définition de n. Le code marche bien, malheureusement, il n'aboutit pas aux bons résultats. L'essentiel pour moi c'est qu'il marche. Le reste, c'est à moi de le régler.
    Biname
    Citation Envoyé par turbulent Voir le message
    C'est GPT qu'il faut remercier, pas moi !
    Merci, pour le retour.
    Biname
    umfred
    Pour une prochaine fois, en plus du message d'erreur lui-même, il serait bien aussi d'indiquer la ligne où cette erreur est survenue, ça permet de directement cibler la bonne ligne à corriger/analyser.
    turbulent
    C'est promis
    MissJenny
    j'aime beaucoup cette phrase...
    turbulent
    Je veux dire qu'il n y a pas d'erreurs de programmation, mais ça n'aboutit pas aux résultats attendus.
    MissJenny
    tu t'enfonces...
    turbulent
    Merci, c'est gentil. Pourriez-vous ne pas commenter à mes questions, même si vous avez la bonne réponse.
    Biname
    J'ai demandé à GPT de trouver une éventuelle erreur dans la formulation
    Je n'ai pas fait l'effort d'essayer comprendre. Est-ce pertinent ?
    Biname
    turbulent
    En fait, j'ai déjà remplacé les variables sym par les variables réelles et j'ai même modifié le code. Maintenant, le problème réside dans fsum, à propos duquel, ce matin, j'ai posté dans ce forum mon message intitulé "Fzero all roots". Merci Biname pour l'effort déployé même si GPT qui s'en occupait.
    Biname
    Je viens de passer une heure agréable avec GPT qui, grâce à toi, m'a initié à la programmation symbolique, il m'a traduit ton code en Python et là, j'ai compris ... pas rien ça
    Biname
    turbulent
    C'est intérresant, mais comme je l'ai cité dans mon message précédent, mon problème, maintenant réside dans le calcul des Roots. Le code (modifié) que j'ai appliqué me donne des racines bizarres:
    Code:
    f=@(x) tan(100*x)+2*x;
    a=-5.0;
    b=5.0;
    %fplot(f,[a,b]),grid on;
    oldzero=zero;
    zerotot=zero;
    eps=1e-9;
    for i=a:0.01:b
    long=long+1;
    end
    end
    zerotot(index)=[];
    zerotot(index)=[];
    En testant par exemple la dernière valeur affichée Roots(231)= 4.6663 et f(4.6663)=-0.2956 et pourtant eps=1e-9. Est-ce que avec Pyton, on obtient les mêmes résultats ou c'est différent ?
    Paraboloide_Hyperbolique
    Biname
    A la calculette on trouve f(4.6663) = -0.29556...
    Tu voudrais trouver zéro ? , je comprends mieux miss Jenny.
    Biname
    turbulent
    Je n'ai pas besoin de "calculette" !!!!
    Moi, je cherche à vérifier la condition:
    Code:
    Biname
    Code:
    A l'endroit de la racine en x=~4.66... la courbe est quasi verticale, d'où la difficulté de trouver la racine avec précision, même pour dx = 1e-9
    Pour f(x) = tg(100x) + 2x, racine entre 4.66 et 4.67
    Bounds: x=4.66000000 y=11.04046803, x =4.67000000 y = 7.38826799
    Root found at x = 4.66526509 (eps = 1e-9)
    Derivative at the root: f'(x) = 563.06569550
    Arctan of the derivative: arctan(f'(x)) = 89.89824328 degrees
    Biname
    turbulent
    Merci comme même, le problème est déjà résolu.
    Dernière modification par turbulent ; 19/07/2023 à 19h54.
    umfred
    la réponse a été donnée sur son autre post https://forums.futura-sciences.com/p...all-roots.html
    c'est le format d'affichage du résultat qui biaise la valeur (affichée)
    on peut forcer l'affichage long via l'instruction matlab "format long" , ou mieux, passer directement la valeur retournée dans la fonction f(Roots(231)) et ça donne bien une valeur inférieure à l'epsilon définie
    Biname
    Est-ce que la courbe est bien très verticale en la racine ?231, x=4.66... ?
    Je me demande si 'mon' code ne trouve pas l'infini (pi/2) de la tangente ?
    Biname
    turbulent
    La vérité, ce qui m'importait, c'est les courbes f(z, T), c'est parfait.
    Dernière modification par turbulent ; 19/07/2023 à 20h17.
    Biname
    La valeur ___minimale___ de la dérivée de tg(bx) est b pour x = N * pi
    Ajouter 2 x augmente encore la pente.
    Si b=100, dx=1 >> dy=100 ... au moins
    Biname
  1. "NextDNS" : site "RTL" dans l'allowlist, pourtant le "play" est bloqué ici (voir lien)
    Par sypqys dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 18/09/2020, 18h23
  2. configuration équatoriale ou " Quad-array "
    Par AK48 dans le forum Géologie et Catastrophes naturelles
    Dernier message: 05/07/2020, 21h08
  3. VB mettre le micro en mode " ecoute" "veille" et "stop" sous visual basic
    Par invite5ea368ff dans le forum Programmation et langages, Algorithmique
    Dernier message: 14/12/2015, 13h45
  4. Matlab: fonction "filter" --> le signal est "retourné" --> pourquoi ?
    Par invitea29b3af3 dans le forum Électronique
    Dernier message: 21/11/2011, 09h24
  5. HELP "Unable to access jarfile" minecraft
    Par invite4e49250f dans le forum Logiciel - Software - Open Source
    Dernier message: 02/08/2011, 17h39
