help me pour la traduction de cette memoire
    inviteb867a714
    2. Experimental
    2.1. Synthesis
    The starting material was synthesized by taking l-Valine
    (Loba Chemie-AR grade) and Hydrochloric acid (Merck) in a
    1:1 stoichiometric ratio. The required amount of starting materials
    for the synthesis of l-valine hydrochloride (LVHCl) salt was
    calculated according to the following reaction:
    C5H11NO2 +HCl → C5H12NO2Cl
    The calculated amount of hydrochloric acid was first dissolved
    in deionized water. l-Valine was then added to the
    solution slowly by stirring. The prepared solution was allowed
    to dry at room temperature and the salts were obtained by slow
    evaporation technique. The purity of the synthesized salt was
    further improved by successive recrystallization process.
    2.2. Solubility
    In solution growth techniques, the size of a crystal depends
    on the amount of the material available in the solution which in
    turn is decided by the solubility of the material in the solvent.
    The solubility of LVHCl in deionized water was determined as
    a function of temperature in the temperature range of 30–50 ◦C.
    The beaker containing the solution was maintained at a constant
    temperature and continuously stirred. The amount of LVHCl
    required to saturate at this temperature was estimated and this
    process repeated for various temperatures. On reaching saturation,
    the equilibrium concentration of the solute was determined
    by gravimetric method. The variation of solubility with temperature
    is shown in Fig. 1.
    2.3. Growth of LVHCl
    The saturated solution of LVHCl was prepared at room temperature
    from the recrystallized salt. The solution was then
    filtered twice to remove the suspended impurities and allowed to
    crystalline by the slow evaporation technique at room temperature.
    A good transparent crystal of size 20mm×6mm×4mm
    harvested in a growth period of 30 days is shown in Fig. 2.
    3. Characterization
    The single crystal X-ray diffraction analysis of LVHCl crystal
    was carried out using ENRAF NONIUS CAD4 X-ray diffractometer
    and its lattice parameters were determined. Fourier
    transform infrared spectrum was recorded by the KBr pellet
    technique using a BRUKER 66V FTIR spectrometer to confirm
    the vibrational structure of the crystalline compound with
    scanning range of wavenumber 400–4000 cm−1. UV–vis spectrum
    was recorded in the range of 200–2000 nm using VARIAN
    CARY 5E spectrometer. Thermal behavior of the grown sample
    was studied by using STA 1500 thermal analyzer. The NLO
    property of LVHCl was tested by Kurtz powder SHG test using
    an Nd:YAG laser (1064 nm).
    4. Results and discussion
    4.1. Single crystal X-ray diffraction studies
    The single crystal X-ray diffraction has been carried out using
    Enraf Nonius-CAD4 diffractometer. From the measurements we
    found that the grown specimen of LVHCl belongs to monoclinic
    system having the space group P21. The determined lattice
    dimensions are given in Table 1. It is in good agreement with
    the reported literature values.
    4.2. Fourier transform infrared studies
    The infrared spectrum of the grown crystal has been taken in
    the range of 400–4000 cm−1. The sample is made as a pellet by
    using KBr. The Fourier transform infrared (FTIR) spectrum of
    LVHCL is shown in Fig. 3. The spectrum shows the presence of
    all the functional groups in LVHCL crystal and summarized in
    Table 2.
    A broad, strong absorption in the 2900–3300 cm−1 range,
    including the absorption at 3082 cm−1 correspond to the stretching
    band of the NH3
    + ion of the amino acid. This region
    results from superimposed O–H and NH3
    + stretching bands.
    Absorption in this region is also characterized by multiple fine
    structures on the lower wavenumber side of the band and weak
    absorptions due to COO− ions. Also, prominent is the relatively
    strong symmetricalNH3
    + bending band around 1519 cm−1 [14].
    A strong band arising from C–COO− stretching is observed
    at 1216 cm−1 [15]. Further a strong carbonyl absorptions at
    1743 cm−1 confirms the COOH and COO− groups of the compound.
    Appearance of this band confirms the formation hydrochloride salt of l-valine [16]. This justifies the protonation
    of carbonyl group in LVHCL. The absorptions of LVHCL
    has been compared with those of the parent compound (l-valine)
    in Table 2. The shifts in the positions of the characteristic peaks
    confirm the formation of the new compound.
    4.3. Optical transmission studies
    Fig. 4 shows the optical transmission spectrum of LVHCl
    single crystal. From the spectrum, it is evident that the LVHCl
    crystal has a very low UV cutoff wavelength of 295 nm, along
    with a large transmission window in the entire visible region.
    Hence, it can be utilized for SHG from a laser operating at
    1064 nm or other optical application in the blue region.
    4.4. Thermal studies
    To find the thermal characteristics ofLVHCl, differential thermal
    analysis (DTA) and thermogravimetric analysis (TGA) were
    carried out simultaneously in a thermal analyzer (STA 1500).
    The sample was heated at a rate of 10 ◦C/min in protected nitrogen
    gas flow. 1.25 mg of the sample was taken to carry out the
    experiment. Fig. 5 shows the thermograms illustrating simultaneously
    recorded TGA and DTA.
    From DT curve, it is observed that the material undergoes
    an irreversible endothermic transition at about 211 ◦C where
    the decomposition starts. The material is fully decomposed at
    260 ◦C. The weight loss curve is very sharp and it starts at 211 ◦C
    and ends at 277 ◦C. This weight loss is due to the liberation
    of volatile substances. The sharpness of the endothermic peak
    shows good degree of crystallinity of the grown ingot. The peak
    at 277 ◦C indicates a phase change from liquid to vapor state as
    evidence from the loss of weight in the TG curve.
    inviteb867a714
    Re : help me pour la traduction de cette memoire
    helpme pour la traduction est un necessaire cpoour enterprise de memore
    invite751056e1
    Citation Envoyé par coushmar 40 Voir le message
    N'ouvre pas un topic à chaque fois que tu veux faire traduire qqch
    Voici ta 1ere discussion: http://forums.futura-sciences.com/ch...-francais.html
    Tu peux y mettre une suite hein
    inviteb7fede84
    Il s'agit de traduction et non de questions relatives à la chimie, donc hors sujet. Des outils de traductions en ligne existent, tu as déjà eu des réponses précédemment. A titre exceptionnel je t'adresse une réponse par message privé, et je ferme la discussion.
  1. Aide pour traduction sumérienne
    Par invitef59a90c0 dans le forum Archéologie
    Dernier message: 06/02/2011, 16h55
  2. Bonjour j'ai besoin d'une traduction pour cette gravure dans une pierre
    Par invite96f87e2b dans le forum Archéologie
    Dernier message: 31/03/2010, 14h48
  3. [Biologie végétale] Traduction pour les botanistes
    Par invited9f37326 dans le forum Biologie
    Dernier message: 26/10/2007, 17h06
  4. [L2] Traduction pour de la tomographie sismique
    Par invitef28c49d8 dans le forum Géologie et Catastrophes naturelles
    Dernier message: 13/12/2004, 18h49
