Aide sur DATASHEET
Aide sur DATASHEET
    invitec35bc9ea
    Aide sur DATASHEET
    je cherche à comprendre ces deux datasheets. certaines caracteristiques sont claires, d'autres le sont moins.
    INPUT
    ADC Resolution (Analog AAF): 24 bits
    Sample Resolution (Digital AAF): 32 bit floating point
    Coupling: AC/DC, Diff., SE, ICP
    Anti-alias Filters: 100 dB protection, all ranges
    Dynamic Range: 110 dB
    Input Ranges: 0.1, 1.0, 10.0 V Full Scale
    Input Impedance: 100 kΩ symmetric for Diff.; 100 kΩ with 50Ω shield to GND for SE
    Max Input Voltage: 80vPeak, 2.5vRmsShield (SE)
    CMRR: 60 dB (typical), f<40 kHz
    Amplitude Accuracy: +/- 0.020dB (0.2%FS) at 1kHz for 15degC < T < 40degC
    Amplitude Ripple: (Digital AAF) - 0.005dB for 0 < f < fS / 2.56
    Amplitude Droop: (Analog AAF) - 0.005dB at 5kHz; 0.010dB at 25kHz; 0.050dB at 49kHz
    Residual Offset: +/- 0.1% FS AND not larger than 3mvDC
    Phase Accuracy: 0.05deg to 0.5deg for DC to 40kHz
    Crosstalk between Inputs: <-100 dB
    Crosstalk between inputs and source:< -90 dB
    THD: 100 dB @ 1 kHz
    Minimum SampleRate: less than 1Sps
    Maximum SampleRate: 204.8 kHz
    Maximum useful Frequency: 40 kHz standard, 93 kHz optional
    Frequency Accuracy: 25ppm
    Time Accuracy: 25ppm
    TACHO
    Max. Frequency: 200 kHz
    Input Range: +/-24 V FS
    Adjustable threshold, holdoff, prescaling
    FREQUENCY MEASUREMENT
    Frequency Span
    Frequency Range: 150kHz to 1300 MHz
    Setting Modes: Centre frequency plus Span,
    or Start plus Stop frequencies
    Maximum Span: 1299.85 MHz
    Minimum Span: 320 kHz, or Zero Span with
    demodulation
    Setting Resolution: 1 kHz at any frequency
    Setting Accuracy: Reference Frequency Accuracy
    for Start, Stop & Centre
    (Zero-Span) frequencies
    Initial Accuracy: Better than ± 10 ppm at 20 oC
    Stability: Better than ± 10 ppm
    over 10 oC to 30 oC
    Ageing: Better than ± 3 ppm per year
    Phase Noise
    Phase Noise: Typically -100dBc/Hz at 100kHz
    offset at 500MHz
    Resolution Bandwidth
    RBW: Selectable 280 kHz or 15 kHz
    Video Filtering: Selectable independently of RBW
    setting
    Markers
    No. of Markers: One, Two (or None)
    Marker Resolution: 0.1 kHz at all frequencies
    Marker Accuracy: 1/320th of Span ± 0.1kHz plus reference
    frequency accuracy.
    Readout: The frequencies at the marker
    points and the frequency difference
    are displayed
    AMPLITUDE MEASUREMENT
    Amplitude Range
    Display Range: 80 dB
    Reference Level: Selectable as -20 dBm or 0dBm
    Amplitude Accuracy
    Ref. Level
    Accuracy:
    Better than ± 1 dB at 50MHz
    (20oC ± 5oC)
    Flatness: Better than ± 1.5 dB over 0.5MHz
    to 1300MHz
    Linearity: Better than ± 1 dB over 50dB from
    reference level
    Noise Floor: Better than -90 dBm average displayed
    noise floor
    (reference level = -20 dBm, RBW
    = 15 kHz)
    Distortion and Spurii
    3rd Order Intermod.:< –60dBc for two signals at 10dB
    below reference level (500MHz
    and 501MHz)
    Harmonic: < –60dBc at 10dB below reference
    level (100MHz)
    1st & 2nd Image: <– 55dBc, typically <– 60dBc
    Residual Spurii: Below noise floor
    Markers
    Resolution: 0.1 dB
    Readout: The level at the marker points and
    difference are displayed.
    SWEEP
    Sweep Method: Peak detection for 320 points per
    sweep. The amplitude and frequency
    of the peak level found
    within each sub-span is stored
    (sub-span = span/320).
    Sweep Time: Set automatically by Span and,
    RBW.
    Sweep Modes: Normal (continuous), Single, Peak
    Hold, Average (2 to 256).
    Sweep Control: Run and Stop buttons. Peak-hold
    and Average are reset whenever
    Run is pressed.
    SIGNAL INPUT
    Input Connector: SMA connector, 50
    VSWR: 1.5 : 1 typical
    Maximum Level: + 20 dBm
    resolution du convertisseur analogique numerique
    quelle difference avec ce qui percede?
    Diff et ICP, je comprends. les autres pas trops
    plage de tensions acceptées?
    impedence d'entrée. comment ça se fait que ça change d'un couplage à un autre?
    tensions max
    THD: 100 dB @ 1 kHz
    optional
    freq max
    TACHO
    freq et tensions max
    invitec35bc9ea
    Re : Aide sur DATASHEET
    Frequency Span
    demodulation
    over 10 oC to 30 oC
    Phase Noise
    offset at 500MHz
    setting
    Markers
    frequency accuracy.
    are displayed
    Amplitude Range
    Amplitude Accuracy
    Ref. Level
    Accuracy:
    (20oC ± 5oC)
    to 1300MHz
    reference level
    noise floor
    = 15 kHz)
    and 501MHz)
    level (100MHz)
    Markers
    Resolution: 0.1 dB
    SWEEP
    RBW.
    Run is pressed.
    SIGNAL INPUT
    je ne comprends quasiment rien.
    alayn91
    Ouf !!
    Voir les fichiers joints.
    Les premières specs semblent appartenir à un analyseur de spectre BF, par FFT.
    Les secondes semblent correspondre à un analyseur de spectre RF, ancienne génération.
    Si questions, il y a, elles devront être pertinentes et correstement formulées.
    Salutations.
    Alain.
    invitec35bc9ea
    Merci alayn91,
    au final je ne m'interesse qu'au premier analyseur. d'ailleur à quoi à tu reconnu que c'etait un analyseur de frequence, et pas juste une carte d'acquisition?
    quelle difference entre resolution CAN et resolution echantillon? je croyais qu'un CAN est justement un echantilloneur/ bloqueur non?
    c'est quoi un coublage AC/DC et asysmetrique?
    Filtres anti-repliement: 100 dB, sur toutes les gammes.
    les 100dB ça represente quoi?
    Gamme dynamique: 100 dB.
    gamme dynamique de 100dB, ça veut dire quoi?
    Gammes d’entrée: 0.1, 1.0, 10V pleine échelle.
    ça c'est clair
    Impédance d’entrée: 100 kΩ symétrique différentiel, 100 kΩ avec 50 Ω à la masse pour l’asymétrique;
    j'attends de voir ce que c'est que les couplage symetrique et asymetrive pour dire si j'ai bien compris ou pas.
    Tension d’entrée max: 80V crète, 2.5 V eff blidage( asymétrique)
    2.5 V eff blidage( asymétrique) j'ai pas compris
    Taux de rejection du mode commun: 60 dB typique, f< 40 kHz.
    Précision en amplitude: +/- 0.020dB(0.2% pleine echelle) à 1 kHz, pour 15°C < T < 40°C.
    Ondulation d’amplitude: (filtre anti-repliement numérique): 0.005dB pour 0 < f échantillonage/256.
    Perte d’amplitude(filtre anti-repliement analogique): 0.005dB à 5kHz; etc.
    Tension décalge résiduelle: +/- 0.1% pleine échelle et inférieure à 3mV continu.
    Précision de phase: 0.05 degré à 0.5 degré du continu à 40 kHz.
    Diaphonie entrées: <-100dB.
    Distorsion harmonique totale: 100bD @ 1 kHz.
    Désolé mais je n'ai rien compris à tout ça
    Vitesse d’échantillonnage minimum: < 1 échantillon/s.
    Vitesse d’échantillonnage max: 204.8 kHz.
    Fréquence utile max: 40 kHz standard, 93 kHz en option.
    c'est clair
    Précision en fréquence: 25 ppm(part per million=E10-6)
    Précision temporelle: 25 ppm.
    pas vraiment saisi
    Fréquence max: 200 kHz.
    Gamme d’entrée: +/- 24 V pleine échelle.
    c'est clair.
    Déclenchement, interdiction de déclenchement, mise à l’échelle réglables.
    pas trops.
    alayn91
    Réponses.
    Salutations.
    Alain.
    invitec35bc9ea
    bonsoir Alyn91, desolé de n'avoir donné réponse plus tot. je n'avais meme pas internet etant donné les circonstances.
    d'abord je voulais te dire ma gratitude pour toute ton aide. ces derniers temps j'ai eu quelques soucis de santé, j'avais donc d'autres priorités. je dois encore régler ces soucis, et en revenant en pleine forme, j'espère, j'éplucherais tous tes précieux manuscrits.
  1. Question sur datasheet PIC16F877
    Par invite2dc206d9 dans le forum Électronique
    Dernier message: 16/02/2008, 20h54
  2. [Brun] tv lcd question sur un ic datasheet
    Par invite95abd005 dans le forum Dépannage
    Dernier message: 21/11/2007, 15h03
  3. question sur Datasheet optocoupleur HCPL0530
    Par inviteea545236 dans le forum Électronique
    Dernier message: 05/11/2007, 13h15
  4. Presision sur une datasheet
    Par invite49856ed4 dans le forum Électronique
    Dernier message: 10/11/2005, 18h27
  5. Recherche de Datasheet sur le SGS 605062
    Par inviteeddea82a dans le forum Électronique
    Dernier message: 21/04/2003, 19h50
