C bus can projet filtrage
    invite4749424e
    je dois réaliser un filtrage sur un bus can pour ne recevoir que d'un seul identifiant.
    Cependant je suis un peu perdu dans le code et ne trouve pas la solution. je vous envois mon application de base:
    Code:
    //! @brief CAN spy displaying CAN activity on UART's
    //! This file can be parsed by Doxygen for automatic documentation generation.
    //! This file has been validated with AVRStudio-413528/WinAVR-20070122.
    //! @version $Revision: 3.20 $ $Name: jtellier $
    //! @todo
    //! @bug
    //_____ I N C L U D E S ________________________________________________________
    #include "config.h"
    #include "uart_lib.h"
    #include "uart_drv.h"
    #include "can_lib.h"
    #include "can_drv.h"
    #include "rtc_drv.h"
    //_____ M A C R O S ____________________________________________________________
    //_____ D E F I N I T I O N S __________________________________________________
    #define RXCAN   'R'
    #define TXCAN   'T'
    //_____ D E C L A R A T I O N S ________________________________________________
    void spy_printing(U8 rxtx, st_cmd_t* msg);
    void can_error_mode(void);
    extern U8 txt_logo_atmel[];
    //_____ F U N C T I O N S ______________________________________________________
    //  @fn main
    //! Core of "base.c".
    //! - CAN communications are listen, captured and a resume is sent on UART_0
    //! - An CAN Echo also is sent: ID(sent)=ID(received)+1
    //!                             DLC = 8
    //!                             RTR = 0
    //!                             Data[6:7]=CANSTMH:CANSTML
    //! Note: If some key is pushed while RESET, only Spy mode is enabled.
    //! Note: Exit in UART ECHO MODE if CAN ID == 0 as CAN error simulation
    //! @warning UART's at 38400 bauds
    //!          CAN in auto-bitrate
    //! @param none.
    //! @return Integer 0
    int main (void)
    U8 mode;    // mode==0: spy+echo, mode!=0: only spy
    U8 txt_can_ana_1[]="======= UART in CAN ANALYZER =======";
    U8 txt_can_ana_2[]="======= Echo + UART in CAN ANALYZER =======";
    U8 i, u8_temp;
    U8 buffer[8];
    st_cmd_t message;
    //tx_type	tx_frame;
    //--- I N I T
        // Clock prescaler Reset
        CLKPR = 0x80;  CLKPR = 0x00;
        DDRA =0xFF;
    	rtc_int_init();
        //- Pull-up on TxCAN & RxCAN one by one to use bit-addressing
        CAN_PORT_DIR &= ~(1<<CAN_INPUT_PIN );
        CAN_PORT_DIR &= ~(1<<CAN_OUTPUT_PIN);
        CAN_PORT_OUT |=  (1<<CAN_INPUT_PIN );
        CAN_PORT_OUT |=  (1<<CAN_OUTPUT_PIN);
         // Init UART-0 at 38400 bauds
        Uart_select(UART_0);
        uart_init(CONF_8BIT_NOPAR_1STOP,38400);
        uart_mini_printf ("\r\n\n-0- ======= CAN SPY ECHO EXAMPLE ======= -0-\r\n");
        uart_mini_printf ("%s",txt_logo_atmel);
        if(mode==0) uart_mini_printf ("-0 %s 0-\r\n\n",txt_can_ana_2);
        else uart_mini_printf ("-0 %s 0-\r\n\n",txt_can_ana_1);
        uart_mini_printf ("-0- ... No Activity on CAN Bus ! ...\r");
        // --- Init CAN (special AUTOBAUD)
        //- Wait until activity on RxCAN
        while ((CAN_PORT_IN & (1<<CAN_INPUT_PIN)) != 0);
            //- Reset CAN peripheral
        Can_reset();
            //- Set CAN Bit-timming
        can_init((U16)CAN_BAUDRATE);        // c.f. macro in "can_drv.h"
            //- Set CAN Timer Prescaler
        CANTCON = CANBT1;                   // Why not !
    //--- C O R E   O F   C A N - E C H O --- C O R E   O F   C A N - E C H O ---
        while(1)
        //- CAN ECHO: WAIT FOR RECEIVED
            // --- Init Rx data
            message.pt_data = &buffer[0];
            for(i=0; i<8; i++) buffer[i]=0;
            // --- Rx Command
            message.cmd = CMD_RX;
            // --- Enable Rx
            while(can_cmd(&message) != CAN_CMD_ACCEPTED);
            // --- Wait for Rx completed
            while(1)
                u8_temp = can_get_status(&message);
                if (u8_temp != CAN_STATUS_NOT_COMPLETED) break; // Out of while
            if (u8_temp == CAN_STATUS_ERROR) break; // Out of the function
        //- CAN ECHO: PRINT-UART OF CAN FRAME RECEIVED
            spy_printing(RXCAN, &message);
            // ---- Exit if CAN ID == 0
            if (message.id.ext == 0) break; // Out of function (CAN ERROR simulation)
            if (message.id.std == 0) break; // Out of function (CAN ERROR simulation)
        //- CAN ECHO: RESPONSE
            if(mode==0)
                // --- Init Tx data
                buffer[6] = CANSTMH;
                buffer[7] = CANSTML;
                // --- Tx Command
                message.id.ext++;   // Incrementation of ID to remove possible clashes
                message.dlc = 8;
                message.cmd = CMD_TX_DATA;
                // --- Enable Tx
                // --- Wait for Tx completed
                while(1)
                //- CAN ECHO: PRINT-UART OF CAN FRAME TRANSMITTED
                spy_printing(TXCAN, &message);
                            // ---- Exit if CAN error(s)
                if (u8_temp == CAN_STATUS_ERROR) break; // Out of function
        can_error_mode();
        return 0;
    //  @fn spy_printing
    //! CAN communications are resumed on UART_0
    //! @param  - 'R' for receive frame, 'T' for transmit frame.
    //!         - CAN message
    //! @return  none
    U8 indx;
        if (msg->ctrl.ide)
            uart_mini_printf ("-0- %cxCAN @ %02X%02X: 0x%08lX(Ext.), L=%d, ", rxtx, CANSTMH, CANSTML, msg->id.ext, msg->dlc);
        else
            uart_mini_printf ("-0- %cxCAN @ %02X%02X:      0x%03X(Std.), L=%d, ", rxtx, CANSTMH, CANSTML, msg->id.std, msg->dlc);
        if (msg->ctrl.rtr)
            Uart_select(UART_0); uart_mini_printf ("Remote\r\n");
        else
            for(indx=0; indx< (msg->dlc-1); indx++)
                Uart_select(UART_0); uart_mini_printf ("%02X-", *(msg->pt_data + indx));
            Uart_select(UART_0); uart_mini_printf ("%02X\r\n", *(msg->pt_data + indx));
    //  @fn can_error_mode
    //! Exit in UART ECHO MODE if CAN ID == 0 as CAN error simulation.
    //! @param  none.
    //! @return  none
    //--- C A N    E R R O R
    U8 i;
    U8 txt_ech_mod[]="======= UART in ECHO MODE =======";
        Uart_select(UART_0); uart_mini_printf ("\r\n-0- ======= CAN LINE ERROR ");
        for(i=0; i<6; i++)
            wait_for(1000); //- Wait for 1000 milli-seconds (1 s)
            Uart_select(UART_0); uart_mini_printf ("*");
        wait_for(1000); //- Wait for 1000 milli seconds
        Uart_select(UART_0); uart_mini_printf (" Exit From Program! ======= -0-\r\n\n");
    //- UART ECHO
        Uart_select(UART_0); uart_mini_printf ("-0 %s 0-\r\n",txt_ech_mod);
        while(1)
            if (uart_test_hit())
                uart_putchar(uart_getchar());   // Echo on UART-0
    merci d'avance
    Dernière modification par Philou67 ; 04/04/2011 à 16h36. Motif: Balise CODE
    Calou80
    Re : C bus can projet filtrage
    Il faudrait le schéma, le uC utilisé (visiblement ATMEL mais lequel?), le contrôleur CAN, le transceiver, type de bus (véhicule, propriétaire?), vitesse, les terminaisons CAN... plein de choses en plus quoi
    Philou67
    Et aussi un code posté à l'aide de la balise [CODE]...
    inviteeb160de1
    Citation Envoyé par Calou80 Voir le message
    Ben d'apres les registres il s'agit d'un AVR, pour ce qui est du controleur CAN il semble que l'acces s'y fasse également par registres, donc controleur interne.
    Chez Atmel, ils n'aiment pas trop le CAN apparemment : tu ne trouveras que les ref AT90CANxxx, et le mega64M1 (celui la je ne le connaissais pas).
    Je n'y connais rien au CAN donc je n'irai pas plus loin, mais bon la réponse à la question se trouve si on connait cette famille de micros..
    Calou80
    Pour ce qui est du contrôleur, effectivement, je n'avais pas pris la peine d'aller plus loin dans les recherches ce qui semble être justifié car le demandeur n'a pas apporter plus d'indication et semble se désinteresser de nos réponses.
    Tant pis....
    invitef98f3dba
    bonjours, je faire le PFE le nom de mon projet horloge mural commande pour afficher sur le afficher 7 segment le date , heure , alarme spl j'aime le programme avec deux pic 16F877 et 7 boutons
  1. Caméras avec bus commande et bus données séparées.
    Par invite5b497461 dans le forum Électronique
    Dernier message: 08/02/2011, 11h04
  2. Projet sur le bus CAN ! besoin d'aide
    Par invitec94a51d1 dans le forum Électronique
    Dernier message: 05/11/2010, 21h32
  3. Filtrage
    Par invite9d3ab8a4 dans le forum Électronique
    Dernier message: 24/05/2009, 19h33
  4. Filtrage
    Par invite4fcc3501 dans le forum Électronique
    Dernier message: 17/04/2009, 10h44
