Récupération d'une tension via la liaison RS485
    tinaarfa
    Salam,
    J'ai fait un programme qui permet de récupérer une tension par la commande 0025H et recevoir une valeur phase voltage Ua entre 0 et 99999 (de type Word) via RS485 avec un pic 18F2550 ,
    Qui peut me donner son avis !
    Ci joint le Schéma sur isis et le programme pic :
    _______
    Code:
    #include <18F2550.h>
    #FUSES NOWDT                    //No Watch Dog Timer
    #FUSES HS                    //Internal Oscillator, HS used by USB
    #FUSES NOPROTECT                //Code not protected from reading
    #FUSES NOBROWNOUT                 //Reset when brownout detected
    #FUSES NOPUT                    //No Power Up Timer
    #FUSES NOCPD                    //No EE protection
    #FUSES NOSTVREN                   //Stack full/underflow will cause reset
    #FUSES NODEBUG                  //No Debug mode for ICD
    #FUSES NOLVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
    #FUSES NOWRT                    //Program memory not write protected
    #FUSES NOWRTD                   //Data EEPROM not write protected
    #FUSES NOIESO                     //Internal External Switch Over mode enabled
    #FUSES NOFCMEN                    //Fail-safe clock monitor enabled
    #FUSES NOPBADEN                   //PORTB pins are configured as analog input channels on RESET
    #FUSES NOWRTC                   //configuration not registers write protected
    #FUSES NOWRTB                   //Boot block not write protected
    #FUSES NOEBTR                   //Memory not protected from table reads
    #FUSES NOEBTRB                  //Boot block not protected from table reads
    #FUSES NOCPB                    //No Boot Block code protection
    #FUSES MCLR                     //Master Clear pin enabled
    #FUSES NOLPT1OSC                  //Timer1 configured for low-power operation
    #FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
    #FUSES PLL1                     //No PLL PreScaler
    #use delay(clock=20000000)
    #use rs232(baud=9600,parity=N,xmit=PIN_c1,rcv=PIN_c2,bits=8)
    #define RS485_ENABLE_PIN   PIN_A3
    #define use_portb_lcd=1
    #include "lcd.C"
    char timed_getc() {
       long timeout;
       int timeout_error;
       timeout_error=FALSE;
       timeout=0;
       while(!kbhit()&&(++timeout<50000)) // 1/2
                                        // second
              delay_us(10);
       if(kbhit())
              return(getc());
       else {
              timeout_error=TRUE;
              return(0);
    int res;
    LONG timeout;
    void main()
       setup_adc_ports(NO_ANALOGS);
       setup_adc(ADC_OFF);
       setup_spi(FALSE);
       setup_wdt(WDT_OFF);
       setup_timer_0(RTCC_INTERNAL);
       setup_timer_1(T1_DISABLED);
       setup_timer_2(T2_DISABLED,0,1);
       setup_comparator(NC_NC_NC_NC);
       setup_vref(FALSE);
       setup_oscillator(False);
       lcd_init();
       delay_ms(100);
       lcd_putc("\fvaleur:");
       output_low(RS485_ENABLE_PIN);
       while(1){
             output_high(RS485_ENABLE_PIN);
             putc(0x00);
             putc(0x25);
             delay_ms(10);
             timeout=0;
             deb:
             delay_ms(10);
             res=timed_getc();
             lcd_gotoxy(4,2);
             printf(lcd_putc,"%4U",res);
             delay_ms(100);
       // TODO: USER CODE!!
    Dernière modification par JPL ; 20/05/2014 à 19h04. Motif: Ajout de la balise Code (#) pour garder l'indentation
    tinaarfa
    Récupérer des données
    J'ai besoin d’écrire un programme pic qui permet de récupérer une tension Ua d'un module PZ96_E4 via RS485 , le pic est 18F2550 , les données nécessaires sont dans ce document ci joint , je veux une aide pour faire cà !
    invitee05a3fcc
    Re : Récupérer des données
    tinaarfa
    salut,
    désolé mais c aussi ma question , je n'ai reçois aucune réponse !
    pour cette question j'ai mis un nouveau fichier qui explique bien le problème
    Veuillez respectez mes salutations et l expréssion de mon profond respect.
    Merci.
    tinaarfa
    je sais pas comment écrire ce programme et quelle est la commande utilisée pour cà ?!!
    JPL
    Re : Récupération d'une tension via la liaison RS485
    Fusion des deux discussions.
    tinaarfa
    Pouvez vous m'aider svp !
    JPL
    Attendre quelques heure dans un forum n'a rien d'anormal : il faut que quelqu'un susceptible d'aider passe par là. Donc reste calme, ici on n'est pas aux urgences ni sur une hot line.
    tinaarfa
    ok je suis désolé :/
    Merci.
  1. Liaison RS485
    Par invite8e914094 dans le forum Électronique
    Dernier message: 25/01/2011, 16h44
  2. liaison RS485
    Par invite98f618be dans le forum Électronique
    Dernier message: 08/04/2009, 15h32
  3. Consommation liaison RS485
    Par invite74b5b8f7 dans le forum Électronique
    Dernier message: 24/03/2009, 08h21
  4. Liaison RS485 sur une camera
    Par invite1f0d3928 dans le forum Électronique
    Dernier message: 30/01/2008, 11h16
  5. Liaison RS485 sans fil
    Par invite5637435c dans le forum Électronique
    Dernier message: 22/09/2006, 05h52
