Modifier le programme en remplacent le bouton poussir par un detecteur de mouvement - Page 2
Affichage des résultats 31 à 60 sur 68
    invite0852c877
    Re : Modifier le programme en remplacent le bouton poussir par un detecteur de mouvement
    Désolé :/
    Voila j'ai encore modifié t'en pense quoi
    Code:
    #include <arduino.h>
    #include <SD.h>
    #include <SoftwareSerial.h>
    #define PIC_PKT_LEN 128 //data length of each read, dont set this too big because ram is limited
    #define PIC_FMT_VGA 7
    #define PIC_FMT_CIF 5
    #define PIC_FMT_OCIF 3
    #define CAM_ADDR 0
    #define CAM_SERIAL softSerial
    #define PIC_FMT PIC_FMT_VGA
    File myFile;
    SoftwareSerial softSerial(2, 3); //rx,tx (11-13 is used by sd shield)
    const byte cameraAddr = (CAM_ADDR << 5); // addr
    const int PIR_MOTION_SENSOR = A5; // the number of the pushbutton pin
    unsigned long picTotalLen = 0; // picture length
    int picNameNum = 0;
    void setup()
    Serial.begin(115200);
    CAM_SERIAL.begin(9600);
    pinMode(PIR_MOTION_SENSOR, INPUT);
    pinMode(4,OUTPUT);
    if (!SD.begin(4)) {
    return;
    initialize();
    void loop()
    	int sensorValue = digitalRead(PIR_MOTION_SENSOR);
    	if(sensorValue == HIGH)  //when the sensor value is HIGH, someone is in here
    	   Capture();
               delay(5000);
    void clearRxBuf()
    while (CAM_SERIAL.available())
    CAM_SERIAL.read();
    void sendCmd(char cmd[], int cmd_len)
    for (char i = 0; i < cmd_len; i++) CAM_SERIAL.write(cmd[i]);
    int readBytes(char *dest, int len, unsigned int timeout)
    int read_len = 0;
    unsigned long t = millis();
    while (read_len < len)
    while (CAM_SERIAL.available()<1)
    if ((millis() - t) > timeout)
    return read_len;
    *(dest+read_len) = CAM_SERIAL.read();
    Serial.write(*(dest+read_len));
    read_len++;
    return read_len;
    void initialize()
    char cmd[] = {0xaa,0x0d|cameraAddr,0x00,0x00,0x00,0x00} ;
    unsigned char resp[6];
    Serial.print("initializing camera...");
    while (1)
    sendCmd(cmd,6);
    if (readBytes((char *)resp, 6,1000) != 6)
    Serial.print(".");
    continue;
    if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x0d && resp[4] == 0 && resp[5] == 0)
    if (readBytes((char *)resp, 6, 500) != 6) continue;
    if (resp[0] == 0xaa && resp[1] == (0x0d | cameraAddr) && resp[2] == 0 && resp[3] == 0 && resp[4] == 0 && resp[5] == 0) break;
    cmd[1] = 0x0e | cameraAddr;
    cmd[2] = 0x0d;
    sendCmd(cmd, 6);
    //Serial.println("\nCamera initialization done.");
    void preCapture()
    char cmd[] = { 0xaa, 0x01 | cameraAddr, 0x00, 0x07, 0x00, PIC_FMT };
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    if (readBytes((char *)resp, 6, 100) != 6) continue;
    if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x01 && resp[4] == 0 && resp[5] == 0) break;
    void Capture()
    char cmd[] = { 0xaa, 0x06 | cameraAddr, 0x08, PIC_PKT_LEN & 0xff, (PIC_PKT_LEN>>8) & 0xff ,0};
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x06 && resp[4] == 0 && resp[5] == 0) break;
    cmd[1] = 0x05 | cameraAddr;
    cmd[2] = 0;
    cmd[3] = 0;
    cmd[4] = 0;
    cmd[5] = 0;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x05 && resp[4] == 0 && resp[5] == 0) break;
    cmd[1] = 0x04 | cameraAddr;
    cmd[2] = 0x1;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    if (resp[0] == 0xaa && resp[1] == (0x0e | cameraAddr) && resp[2] == 0x04 && resp[4] == 0 && resp[5] == 0)
    if (readBytes((char *)resp, 6, 1000) != 6)
    continue;
    if (resp[0] == 0xaa && resp[1] == (0x0a | cameraAddr) && resp[2] == 0x01)
    picTotalLen = (resp[3]) | (resp[4] << 8) | (resp[5] << 16);
    //Serial.print("picTotalLen:");
    //Serial.println(picTotalLen);
    break;
    void GetData()
    unsigned int pktCnt = (picTotalLen) / (PIC_PKT_LEN - 6);
    if ((picTotalLen % (PIC_PKT_LEN-6)) != 0) pktCnt += 1;
    char cmd[] = { 0xaa, 0x0e | cameraAddr, 0x00, 0x00, 0x00, 0x00 };
    unsigned char pkt[PIC_PKT_LEN];
    char picName[] = "pic00.jpg";
    picName[3] = picNameNum/10 + '0';
    picName[4] = picNameNum%10 + '0';
    if (SD.exists(picName))
    SD.remove(picName);
    myFile = SD.open(picName, FILE_WRITE);
    if(!myFile){
    //Serial.println("myFile open fail...");
    else{
    for (unsigned int i = 0; i < pktCnt; i++)
    cmd[4] = i & 0xff;
    cmd[5] = (i >> 8) & 0xff;
    int retry_cnt = 0;
    retry:
    delay(10);
    clearRxBuf();
    sendCmd(cmd, 6);
    uint16_t cnt = readBytes((char *)pkt, PIC_PKT_LEN, 200);
    unsigned char sum = 0;
    for (int y = 0; y < cnt - 2; y++)
    sum += pkt[y];
    if (sum != pkt[cnt-2])
    if (++retry_cnt < 100) goto retry;
    else break;
    myFile.write((const uint8_t *)&pkt[4], cnt-6);
    //if (cnt != PIC_PKT_LEN) break;
    cmd[4] = 0xf0;
    cmd[5] = 0xf0;
    sendCmd(cmd, 6);
    myFile.close();
    picNameNum ++;
    invite1d577638
    Teste, tu verras bien...
    (Code non indenté, je lis pas...!)
    invite0852c877
    c'est je l'ai indenter^^
    j'ai testé mais bon sa ne marche pas,j'ai mis ma carte sd sur ma tablette et il n'y a pas de photo pris :/
    invite1d577638
    Citation Envoyé par moduleloi Voir le message
    Quelle version du programme ? Celle post #31 ?
    Ajoute une led qui clignote ou un serial.print avant le capture() histoire de faire un peu de debug...
    invite0852c877
    Oui c'est celle du post 31
    j'ai rajouté serial.print sa ne fonctionne pas :/,je sais pas comment ajouté une led et le mettre dans quel emplacement
    Code:
    #include <SD.h>
    #define CAM_ADDR 0
    File myFile;
    int picNameNum = 0;
    void setup()
    pinMode(4,OUTPUT);
    if (!SD.begin(4)) {
    return;
    initialize();
    void loop()
             Serial.println("taking");
    	   Capture();
               delay(5000);
    void clearRxBuf()
    CAM_SERIAL.read();
    int read_len = 0;
    return read_len;
    read_len++;
    return read_len;
    void initialize()
    while (1)
    sendCmd(cmd,6);
    Serial.print(".");
    continue;
    cmd[2] = 0x0d;
    sendCmd(cmd, 6);
    void preCapture()
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    void Capture()
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    cmd[2] = 0;
    cmd[3] = 0;
    cmd[4] = 0;
    cmd[5] = 0;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    cmd[2] = 0x1;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    continue;
    break;
    void GetData()
    SD.remove(picName);
    if(!myFile){
    else{
    cmd[4] = i & 0xff;
    int retry_cnt = 0;
    retry:
    delay(10);
    clearRxBuf();
    sendCmd(cmd, 6);
    sum += pkt[y];
    else break;
    cmd[4] = 0xf0;
    cmd[5] = 0xf0;
    sendCmd(cmd, 6);
    myFile.close();
    picNameNum ++;
    invite0852c877
    je vien de modifier encore tu le trouve pas mieux ?
    Code:
    #include <SD.h>
    #define CAM_ADDR 0
    File myFile;
    int picNameNum = 0;
    void setup()
    pinMode(4,OUTPUT);
    if (!SD.begin(4)) {
    return;
    initialize();
    void loop()
       int n = 0;
    while(1){
    Serial.println("\r\nbegin to take picture");
    delay(200);
    if (n == 0) preCapture();
    Capture();
    GetData();
    Serial.print("\r\nTaking pictures success ,number : ");
    Serial.println(n);
    n++ ;
    void clearRxBuf()
    CAM_SERIAL.read();
    int read_len = 0;
    return read_len;
    read_len++;
    return read_len;
    void initialize()
    while (1)
    sendCmd(cmd,6);
    Serial.print(".");
    continue;
    cmd[2] = 0x0d;
    sendCmd(cmd, 6);
    void preCapture()
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    void Capture()
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    cmd[2] = 0;
    cmd[3] = 0;
    cmd[4] = 0;
    cmd[5] = 0;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    cmd[2] = 0x1;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    continue;
    break;
    void GetData()
    SD.remove(picName);
    if(!myFile){
    else{
    cmd[4] = i & 0xff;
    int retry_cnt = 0;
    retry:
    delay(10);
    clearRxBuf();
    sendCmd(cmd, 6);
    sum += pkt[y];
    else break;
    cmd[4] = 0xf0;
    cmd[5] = 0xf0;
    sendCmd(cmd, 6);
    myFile.close();
    picNameNum ++;
    invite1d577638
    C'est à dire "ça ne fonctionne pas" ?
    Il t'affiche "taking" ?
    Oui -> le capteur de mouvement fonctionne, pas la caméra.
    Non -> Le capteur ne fonctionne pas. Revoir son programme.
    Et le reste des messages apparaît dans le moniteur ? Genre "initializing camera..." ?
    invite0852c877
    ou taking ? il n'y a pas d'erreur sur le programme j'arrive à l'enregistré sur arduino,mais quand je fais la manip,il n'y a pas d'image apres 10 seconde de soit disant détection,je ne sais pas du tout si le programme fonctionne sur la manip
    invite0852c877
    oui il apparait sur le moniteur
    invite1d577638
    Le "talking" ?
    -> revoir le programme de la caméra, qui soit disant fonctionnait seul.
    invite0852c877
    Bon,on repart à 0 parce que je suis mélangé voici le programme qui fonctionne boutton poussoir + ma caméra
    // File SerialCamera_DemoCode_CJ-OV528.ino
    // 8/8/2013 Jack Shao
    // Demo code for using seeeduino or Arduino board to cature jpg format
    // picture from seeed serial camera and save it into sd card. Push the
    // button to take the a picture .
    // For more details about the product please check http://www.seeedstudio.com/depot/
    Code:
    #include <SD.h>
    #define CAM_ADDR 0
    File myFile;
    const int buttonPin = A5; // the number of the pushbutton pin
    int picNameNum = 0;
    void setup()
    CAM_SERIAL.begin(9600); //cant be faster than 9600, maybe difference with diff board.
    pinMode(buttonPin, INPUT); // initialize the pushbutton pin as an input
    //Serial.println("Initializing SD card....");
    pinMode(4,OUTPUT); // CS pin of SD Card Shield
    if (!SD.begin(4)) {
    //Serial.print("sd init failed");
    return;
    //Serial.println("sd init done.");
    initialize();
    void loop()
    int n = 0;
    while(1){
    //Serial.println("\r\nPress the button to take a picture");
    while (digitalRead(buttonPin) == LOW); //wait for buttonPin status to HIGH
    //Serial.println("taking");
    if(digitalRead(buttonPin) == HIGH){
    delay(20); //Debounce
    if (digitalRead(buttonPin) == HIGH)
    delay(200);
    Capture();
    //Serial.print("Saving picture...");
    GetData();
    //Serial.print("\r\nDone ,number : ");
    //Serial.println(n);
    n++ ;
    void clearRxBuf()
    CAM_SERIAL.read();
    int read_len = 0;
    return read_len;
    read_len++;
    return read_len;
    void initialize()
    while (1)
    sendCmd(cmd,6);
    Serial.print(".");
    continue;
    cmd[2] = 0x0d;
    sendCmd(cmd, 6);
    void preCapture()
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    void Capture()
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    cmd[2] = 0;
    cmd[3] = 0;
    cmd[4] = 0;
    cmd[5] = 0;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    cmd[2] = 0x1;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    continue;
    break;
    void GetData()
    SD.remove(picName);
    if(!myFile){
    else{
    cmd[4] = i & 0xff;
    int retry_cnt = 0;
    retry:
    delay(10);
    clearRxBuf();
    sendCmd(cmd, 6);
    sum += pkt[y];
    else break;
    cmd[4] = 0xf0;
    cmd[5] = 0xf0;
    sendCmd(cmd, 6);
    myFile.close();
    picNameNum ++;
    je l'ai trouvé sur ce lien et sa fonctionne tres bien quand je l'ai testé manuellement
    http://translate.google.fr/translate...it&prev=search
    invite1d577638
    Ok, maintenant modifie ce programme de façon à y inclure le détecteur de présence...
    invite0852c877
    D'accord mais c'est sa qui ma casse la tete depuis 2jour,j'ai beau modifier 1000 fois sur le moniteur pour supprimer le boutton poussoir et inclure un détecteure de présence ,manuellement sa ne fonctionne pas,des fois l'effort ne paye pas :/
    invite1d577638
    Je t'ai mâché le boulot page précédente pour un programme quasi identique... Cesse de t'apitoyer sur ton sort, réfléchis un peu et code intelligemment ! C'est pas si dur...
    Identifie la fonction qui déclenche la prise de la photo, et arrange toi pour qu'elle soit appelée lors d'une détection de mouvement sur ton capteur...
    invite0852c877
    Bon,j'ai fais comme tu m'a dit sur la page précedente regard ce que sa donne,sa ne marche toujour pas mais je pense que c'est mieux
    Code:
    #include <SD.h>
    #define CAM_ADDR 0
    File myFile;
    int picNameNum = 0;
    void setup()
    if (!SD.begin(4)) {
    return;
    initialize();
    boolean isPeopleDetected()
    	if(sensorValue == HIGH)//if the sensor value is HIGH?
    		return true;//yes,return true
    	else
    		return false;//no,return false
    void loop()
      int n = 0;
      while(1){
        Serial.flush();
        while(isPeopleDetected() == LOW);
        if(isPeopleDetected() == HIGH){
          delay(50);
            delay(200);
            if(n == 0)Capture();
            Capture();
            GetData();
          Serial.print("Taking pictures success ,number : ");
          Serial.println(n);
          n ++ ;
    void clearRxBuf()
    CAM_SERIAL.read();
    int read_len = 0;
    return read_len;
    read_len++;
    return read_len;
    void initialize()
    while (1)
    sendCmd(cmd,6);
    Serial.print(".");
    continue;
    cmd[2] = 0x0d;
    sendCmd(cmd, 6);
    void preCapture()
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    void Capture()
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    cmd[2] = 0;
    cmd[3] = 0;
    cmd[4] = 0;
    cmd[5] = 0;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    cmd[2] = 0x1;
    while (1)
    clearRxBuf();
    sendCmd(cmd, 6);
    continue;
    break;
    void GetData()
    SD.remove(picName);
    if(!myFile){
    else{
    cmd[4] = i & 0xff;
    int retry_cnt = 0;
    retry:
    delay(10);
    clearRxBuf();
    sendCmd(cmd, 6);
    sum += pkt[y];
    else break;
    cmd[4] = 0xf0;
    cmd[5] = 0xf0;
    sendCmd(cmd, 6);
    myFile.close();
    picNameNum ++;
    ta fonction ispeopledetected retourne TRUE ou FALSE pas HIGH ou LOW!!
    invite1d577638
    Effectivement, tu t'y prends mal... Il n'y a pas à tatonner et à faire 50 versions...
    1-Donne moi, dans le code du capteur de présence, les lignes qui sont exécutées au moment où le capteur détecte une présence.
    2-Donne moi, dans le code de l'appareil photo, la fonction à appeler qui réalise la prise de vue (une ligne).
    3-Assemble les deux, et donne moi juste le code résultant de cet assemblage (pas le code en entier).
    invite0852c877
    1)
    Code:
    	else
    2)
    Code:
    Capture();
    3)
    Code:
         {delay(200);
          Capture();
    Voila je m'y prend toujour mal ?
    Dernière modification par Antoane ; 07/04/2015 à 20h57. Motif: Réparation balises code
    invite1d577638
    1-Presque. Étudie la remarque de jiherve.
    2-Oui.
    3-Presque bon. Reprends 1 et conclue. (Et teste...)
    Re
    Progress is on the way!
    invite0852c877
    Code:
    	if(sensorValue == True)//if the sensor value is HIGH?
         {delay(200);
          Capture();
    Voila ^^,je vais le tester demain,mais sa devrai faire quoi normalement avec ce petit code ?
    Re
    ben normalement si le test de tes variables est fait avec le bon type alors peut être que la bobinette cherrera?
    invite0852c877
    d'accord mais j'ai pas compris ,je vais pas le faire fonctionner avec ce petit code
    invite1d577638
    Fait marcher tes neurones... Le code 1 il est extrait d'où ? Reporte les modifications que tu as apportées à 1, c'est à dire le code 3, à l'endroit où tu as prélevé code 1... . Et compile l'ensemble !
    invite0852c877
    Oui j'ai compris sa ,mais je vois pas quoi mettre dans void setup,je vais pas mettre la meme chose vu que j'utilise un detecteur de mouvement et le code 3 je vais le mettre dans void loop non ? en faite je me mélange je pense
    invite1d577638
    dans le setup(), il doit y avoir le contenu du setup des 2 programmes...
    invite0852c877
    Comme sa ?
    Code:
    void setup()
        if(Pir_Motion_sensor,HIGH)
      if (!SD.begin(4)) {
        return;
      initialize();
    void loop () {
    	if(sensorValue == true)//if the sensor value is HIGH?
         {delay(200);
          Capture();
        GetData () ;
    invite1d577638
    De loin et sans avoir le reste sous les yeux, ça semble pas mal.... Teste !
    PS : "comme ça" svp.
    invite0852c877
    D'accord ^^,mais bon le reste c'est la meme chose que le programme avec boutton poussoir non ?
    invite1d577638
    Non... il faut que ton programme final contienne les fonctionnalités des 2 premiers programmes : celui de la photo et du détecteur...
  1. aide pour modifier un programme du pic
    Par invite8fabcf6d dans le forum Électronique
    Dernier message: 03/02/2013, 19h55
  2. Probléme pour modifier un programme
    Par invitea883d7b1 dans le forum Électronique
    Dernier message: 27/04/2011, 11h49
  3. modifier un detecteur de mouvement et de bruit
    Par inviteeefb43ab dans le forum Électronique
    Dernier message: 15/01/2010, 18h22
  4. Modifier Un Programme de Pic
    Par invitef894bf53 dans le forum Électronique
    Dernier message: 15/06/2009, 09h36
  5. Lumiere avec detecteur IR auto et bouton de forcage
    Par invitec1ef9e87 dans le forum Électronique
    Dernier message: 01/11/2007, 18h39
