[Programmation] Connecter deux modules bluetooth entre eux
    invite416ab5bd
    Bonjour !
    Je possède deux modules bluetooth ( http://www.gotronic.fr/art-module-bl...g010-21436.htm ) et deux arduino. Mon but est de connecter les deux modules entre eux pour ensuite envoyer un valeur issue d'un capteur d'une carte à l'autre.
    Pour l'instant mon problème est la connexion des deux modules entre eux. L'un doit être en maitre et l'autre en esclave. Pour cela je dois configurer les modules via les commandes AT.
    D'après la doc technique :
    The default communication baud rate is 9600, matching the password is 0000 or 1234
    Lights blinking when the search, When light means has been connected to the host device.
    AT command:
    Testing Communications
    Send: AT (return OK, one second left and right once)
    Returns: OK
    Bluetooth serial communication baud rate change
    Send: AT + BAUDI
    Returns: OK1200
    Send: AT + BAUD2
    Returns: OK2400
    BAUD1 --------- 1200
    BAUD2 --------- 2400
    BAUD 3 --------- 4800
    BAUD 4 --------- 9600
    BAUD 5 --------- 19200
    BAUD 6 --------- 38400
    BAUD 7 --------- 57600
    BAUD 8 --------- 115200
    BAUD 9 --------- 230400
    BAUD A --------- 460800
    BAUD B --------- 921600
    BAUD C --------- 1382400
    Interference causes system instability is not recommended for use in more than 115,200 baud. rateAfter setting more than 115,200 computer unusable , use in microcontroller programming using this baud rate higher than 115200 in order to
    Re-issue the AT command set low baud
    After the baud rate with AT command set , don’t need re- setting the baud rate the next time .
    It will saved after power off automatically.
    3 Bluetooth name change
    Send : AT + NAMEname
    Returns : OKsetname
    Parameter name: The name of the current to be set , the Bluetooth name is searched . Within 20 characters .
    For example: sending AT + NAMEdagu
    Return OKsetname
    At this time the name of the Bluetooth bill_gates
    Parameters can be powered down to save , simply modify one . PDA client refresh services can be seen after the change of the name of the Bluetooth
    4 Bluetooth pairing password change
    Send : AT + PINxxxx
    Returns : OKsetpin
    Parameter xxxx: pairing password to be set ,4 bytes.
    this command can be used slave or master . Machine is a phone adapter or pop-up window when asked to enter a passcode from the manual input of this parameter can be connected from the machine . Primary Bluetooth module search from the machine, if the password is correct , it is automatically paired , in addition to the main module from the module can be connected to the outer pair other products from the module contains the pair can be connected , for example, a digital camera containing Bluetooth , Bluetooth GPS, Bluetooth serial printers , and the like.
    For example: sending AT + PIN8888
    Return OKsetpin
    Then the Bluetooth passkey is 8888 . Parameters can be powered down to save , simply modify once.
    Cela devrait marcher. Cependant je n'arrive pas à envoyer une commande AT... Sur mon arduino j'ai essayé avec ce code (récupéré sur internet, j'ai juste changé la vitesse de transmission qui serait de 9600 pour mon module même en AT ) :
    Code:
    #include <SoftwareSerial.h>
    SoftwareSerial BTSerial(00, 01); // RX | TX
    void setup()
      Serial.begin(9600);
      Serial.println("Enter AT commands:");
      BTSerial.begin(9600);
    void loop()
      if (BTSerial.available())
        Serial.write(BTSerial.read());
      if (Serial.available())
        BTSerial.write(Serial.read());
    Cependant je n'ai aucun retour dans le Moniteur série quand je rentre une commande...
    Comment résoudre ce problème ? Mon code arduino n'est pas le bon ? Mon câblage est vérifié, j'ai bien croisé tx et rx.
    Pour préciser, je n'ai quasiment aucune connaissance en électronique ou en programmation, merci d'avance pour votre aide !
    invite1d577638
    Re : Connecter deux modules bluetooth entre eux
    Ton code est un peu étrange... Il utilise une librairie pour créer un port série virtuel.
    Je n'ai pas la doc sous les yeux, mais j'ai l'impression que tu as tenté de créer un port série virtuel sur les mêmes broches que le port hard.
    Si tu veux juste tester des commandes AT, tu peux simplement faire un truc du genre :
    Code:
    void loop()
        Serial.write("ATxxxx");
        delai une seconde
    Dans un premier temps pour valider le fonctionnement. Après si tu veux pouvoir entrer des commandes depuis un terminal, il faut effectivement rajouter un port série virtuel, mais en lui attribuant d'autres pins...
    invite416ab5bd
    Citation Envoyé par Yoruk Voir le message
    Code:
    void loop()
        delai une seconde
    Le problème c'est que je n'ai rien pour vérifier la bonne réception de la commande AT de cette manière alors que via le terminal, un réponse m'est retournée.
    La seule doc que j'ai est celle que j'ai citée dans mon message. Je n'ai pas vraiment compris la remarque à propos de la mise en place d'un port série virtuel. Comment le faire justement ?
    Merci de la réponse !
    invite1d577638
    Reprend la documentation du port série virtuel et associe-le à d'autres pins...!
    invite416ab5bd
    J'ai donc essayé différents pins, sans résultats, avec ce code :
    Code:
    SoftwareSerial BTSerial(10, 11); // (RX, TX)
    void setup()
        Serial.begin(9600);
        Serial.println("Enter AT commands :");
    void loop()
    invite1d577638
    Attention, ce module à l'air de fonctionner en 3v3, pas en TTL !
    Tu es sûr de tes branchements ?
    invite416ab5bd
    D'après la doc :
    Ce module Bluetooth 4.0 de Dagu permet d'ajouter une liaison Bluetooth sur vos projets à microcontrôleur (communication via série TTL).
    Alimentation: 3,3 à 6 Vcc (régulateur 3 Vcc intégré)
    Mes branchements ont l'air bons, il a que 4 pins, TX, RX, VCC et GND. J'avais testé 3V3 ou 5V, sans différences...
    invite1d577638
    Tu as bien une led qui clignote dessus ?
    Rassure moi, tu croises bien TX et RX ???
    invite416ab5bd
    Oui, il y a deux leds l'une est fixe ( témoin d’alimentation ) et l'autre clignote, elle passe au fixe lorsque le module est connecté ! Dans mon cas, elle clignote comme prévu.
    Bien sur, je croise RX et TX
    invite416ab5bd
    De plus, d'après la doc :
    Recherche et appariement automatiques lors de la mise sous tension
    Or, quand je met sous tension les deux modules ( chacun sur une arduino différente ) ils ne se connectent pas entre eux, il faut surement un programme sur les arduinos, lequel ? Connaissez vous des liens ? J'ai pas mal cherché, sans résultats.
    invite1d577638
    Il faut envoyer des codes pour régler l'appairage automatique (mot de passe identique, canal...)
    Mais avant ça, il faut réussir à les faire répondre aux sollicitations, si ça ne marche pas, le reste ne fonctionnera pas...!
    J'ai un module similaire, mais qui travaille exclusivement en 3v3. Certes je peux l'alimenter en 5v (il y a un régulateur de tension) mais j'utilise un convertisseur de niveau pour ne pas le flinguer avec des niveaux TTL sur la liaison série.
    Tu utilise quoi comme cartes arduino ?
    invite416ab5bd
    J'utilise des cartes arduino UNO. Je vais l'alimenter en 3V3 au final de toutes façon.
    J'ai essayé plusieurs pins, 2;3 10;11 etc, sans résultats...
    invite1d577638
    C'est pas l'alimentation du chip en lui-même, mais bien le niveau de la liaison série qu'il faut baisser. Sur tes UNO, c'est du TTL (niveau 5v). Et sur mon module, ce n'est pas du TTL mais du 3v3 !! Et mettre du 5v sur une broche qui n'en attend que 3.3...?
    invite416ab5bd
    J'ai essayé en 3V3, cela n'a rien changé.
    Je ne pense pas que le fait de l'avoir branché en 5V au début l'ai endommagé, il est bien indiqué qu'il peut être alimenté jusqu’à 6V, de plus sur le module on peut lire ceci :
    Nom : 7145234(1).jpg
Affichages : 858
Taille : 8,6 Ko
    invite1d577638
    Encore une fois, la tension d'alimentation est complètement différente de la tension de la liaison série !!!
    Je suppose que tu n'as pas d'adaptateur de niveau ?
    Il y a des leds d'activité de la liaison série sur le module ?
    invite1d577638
    Solution ultime : connecte ton module bluetooth sur les pins 0 et 1 de la UNO, dont tu auras retiré le 328p.
    Utilise ensuite la console de l'IDE pour envoyer tes commandes AT...!
    invite416ab5bd
    Alors, je n'ai pas d'adaptateur de niveau (je travaille avec le matériel de mon lycée donc j'ai pas mal de ressources sinon) par contre, avec un voltmètre, on voit bien que la sortie de la liaison série est en 5V, avec un pont diviseur de tension je l'ai abaissée à 3V3, mais aucun résultat...
    J'ai même essaye sans le 328p du coup et même comme ça cela ne marche pas !
    J'ai deux module, et aucune différence entre les deux, donc ça serait étonnant que le problème vienne du module, j'ai essayé avec plusieurs arduino etc, toujours pareil
    invite1d577638
    Citation Envoyé par Shantorian Voir le message
    Il est impossible de quantifier le niveau d'une liaison série avec un voltmètre. Il faut un oscillo.
    Tu as placé ton diviseur sur quel signal ?
    Si tu as un oscillo, vérifie que tu as bien du signal sur la ligne Arduino -> Module quand tu envoies une commande. Et vérifie aussi le RX.
    invite416ab5bd
    J'ai placé le pont diviseur sur RX et TX. Je n'ai pas d'oscilloscope sous la main maintenant.
    Je trouve cela étrange que cela soit aussi difficile de mettre en place un simple module bluetooth. J'y passe des heures
    invite416ab5bd
    Normalement c'est cette méthode qui devrait être la bonne, car normalement mon module devrait s’appelle Linvor aussi d'après d'autres utilisateurs...
    http://forum.arduino.cc/index.php?topic=107547.0
    Mais seulement non... Je ne comprends pas :')
    invite1d577638
    Tu as théoriquement besoin d'un pont diviseur uniquement dans le sens Arduino TX -> module RX. Dans l'autre sens, tu balances des niveaux 3v3 alors que la arduino en attends 5, du coup si tu diminues encore, c'est sûr que ça ne va pas marcher.
    Met un coup d'oscillo sur les lignes dès que possible... ça peut être un problème d'impédance.... Et ça permettra d'isoler le problème.
    paulfjujo
    Justement, il devrait y en avoir une !
    Un module MAITRE et un module ESCLAVE .
    exemple ICI
    avec un module BT RN41 et un module BT HC06 (linvor)
    attention au models livrés par RPC (Chine) et PUB mensongere sur le modele presenté (toujours sans doc tech. d'ailleur)
    soit disant MAITRE-ESCLAVE et seulement ESCLAVE en réalité.. car moins cher ?
    Dernière modification par paulfjujo ; 28/03/2016 à 17h23.
    invitef86a6203
    Attention !
    Certains modules ne fonctionnent pas en mode Master malgré les commandes AT .
    Par exemple;
    Le module HC-06 ne fait pas le mode master alors que le HC-05 lui le fait.
    De visu, ils sont identiques ...
    invite416ab5bd
    Citation Envoyé par paulfjujo Voir le message
    exemple ICI
    Attention !
    Par exemple;
    Merci de vos réponses !
    Certes, cependant quand bien même j'aurais deux esclaves ( j'ai d'autres modules je vais tester dès aujourd'hui ) je devrais quand même pouvoir accéder aux commandes AT or ici, ce n'est pas les cas...
    invite1d577638
    ...donc oscillo pour lever le doute sur l'origine du problème.
    invite416ab5bd
    Alors avec oscilloscope, j'ai relié les sorties rx;tx du module et de l'arduino. Je savais pas ce que je devais faire exactement alors je vais expliquer ce que j'ai fais, sans savoir si c'est bon et si ça m'aide.. Si jamais ce n'est pas le cas, quelle est la manip avec l'oscillo ?
    Je travaillais avec ce code sur l'arduino :
    Code:
    void setup()
        Serial.begin(9600);
    void loop()
    Ici, "Channel 1" correspond au RX venant du module et "Chanel 2" au TX venant du module. On voit deux tensions différentes.
    Et là, "Channel 1" correspond au RX (pin10) de l'arduino et "Channel 2" au TX (pin11). ( J'ai la même chose sur les pins 0 et 1 )
    En abaissant la tension à 3V3 : (Je n'ai aucune idée de pourquoi le premier canal est à 3V et pas à 3V3, j'ai fait le même pont diviseur...
    Dernière modification par Antoane ; 07/04/2016 à 13h19. Motif: Rapatriement des PJ sur le serveur
    paulfjujo
    s'il ne veut pas repondre à une commande AT
    la solution ultime
    déja testé OK personnellement...
  1. Compréhension du protocole bluetooth appliqué aux modules bluetooth
    Par invite7808af07 dans le forum Électronique
    Dernier message: 02/03/2015, 14h27
  2. communication entre deux modules XBee
    Par invite0bfac504 dans le forum Électronique
    Réponses: 16
    Dernier message: 29/03/2013, 17h03
  3. Comment connecter deux ordinateurs entre eux?
    Par invitea9f6b401 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 13/01/2011, 23h17
  4. connecter deux portables entre eux
    Par invite652a09b3 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 20/06/2010, 17h53
  5. Comment connecter deux PC entre eux ??
    Par invite4ea83d95 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 13/01/2004, 17h18
