VB.net Serveur Client Problème dans le code
    invite668e064f
    Exclamation VB.net Serveur Client Problème dans le code
    Salut tout le monde j'ai créer un logiciel et il ne fonctionne pas, il refuse de se connecter c'est un logiciel de type framwork voici le code serveur et client
    serveur :
    Code:
    Private Sub ReactorButton1_Click_1(sender As System.Object, e As System.EventArgs) Handles ReactorButton1.Click
            Winsock1.LocalPort = 8080
            Winsock1.Listen()
        End Sub
        Private Sub Winsock1_ConnectionRequest(sender As Object, e As AxMSWinsockLib.DMSWinsockControlEvents_ConnectionRequestEvent) Handles Winsock1.ConnectionRequest
            Winsock1.Close()
            Winsock1.Accept(e.requestID)
        End Sub
        Private Sub Winsock1_DataArrival(sender As Object, e As AxMSWinsockLib.DMSWinsockControlEvents_DataArrivalEvent) Handles Winsock1.DataArrival
            Dim data As String = ""
            Dim opt() As String
            Winsock1.GetData(data)
            opt = Split(data, "||")
            Select Case opt(0)
                Case "connecté"
                    Me.Text = "Connecté !"
                    PictureBox1.BackColor = Color.Lime
                Case "MSG"
                    If ReactorMultiLineTextBox1.Text = "" Then
                        ReactorMultiLineTextBox1.Text = (ReactorMultiLineTextBox1.Text & "Message de " & opt(1))
                    Else
                        ReactorMultiLineTextBox1.Text = (ReactorMultiLineTextBox1.Text & vbCrLf & "Message de " & opt(1))
                    End If
                    MsgBox("Message de " & opt(1), MsgBoxStyle.Exclamation, "Nouveau Message")
                Case "déconecté"
                    Me.Text = "Cuisine "
                    PictureBox1.BackColor = Color.Red
            End Select
        End Sub
    et voici le client :
    part1 :
    Code:
    Private Sub Button40_Click(sender As System.Object, e As System.EventArgs) Handles Button40.Click
            If Button1.Text = "Se connecter" Then
                On Error Resume Next
                Winsock1.Close()
                Winsock1.Connect(TextBox2.Text, TextBox5.Text)
            End If
        End Sub
        Private Sub Winsock1_ConnectEvent(sender As Object, e As System.EventArgs) Handles Winsock1.ConnectEvent
            Me.Text = "Caisse connecté !"
            Button40.BackColor = Color.Lime
            Winsock1.SendData("connecté" & "||")
        End Sub
    part2 :
    Code:
    Dim txtpsd As String = ("Caisse" & " : " & Form3.RichTextBox1.Text)
            Dim txtmy As String = ("Moi" & " : " & Form3.RichTextBox1.Text)
            Winsock1.SendData("MSG" & "||" & txtpsd)
    invite805ff73c
    Re : VB.net Serveur Client Problème dans le code
    Tu comptes le poster encore combien de fois ton pb? http://forums.futura-sciences.com/el...leme-code.html
    invite668e064f
    Red face Re : VB.net Serveur Client Problème dans le code
    Oui Dsl mais d'abord je me suis planter de catégorie et ensuite chrome à planter de '--'
    JPL
    Discussion fermée. Merci de continuer sur la précédente.
  1. VB.net Serveur Client Problème dans le code
    Par invite668e064f dans le forum Programmation et langages, Algorithmique
    Dernier message: 05/09/2013, 15h58
  2. VB.net Serveur Client Problème dans le code
    Par invite668e064f dans le forum Électronique
    Dernier message: 03/09/2013, 18h31
  3. Protéger le code php contenu dans un serveur installé chez un client
    Par invite0f178c4b dans le forum Logiciel - Software - Open Source
    Dernier message: 13/12/2011, 10h50
  4. erreur dans le code client FTP
    Par invitea2c33247 dans le forum Programmation et langages, Algorithmique
    Réponses: 18
    Dernier message: 24/01/2011, 18h03
  5. Client/serveur
    Par invite89e47f89 dans le forum Internet - Réseau - Sécurité générale
    Dernier message: 30/01/2007, 19h11
