odd/even effect
odd/even effect
    invitefaa6af90
    odd/even effect
    je suis entrain de lire un article et ils parlent de odd/even effect.. Je ne trouve absolument rien sur internet qui parle de ca.. Quelqu'un pourrait me dire de quoi il s'agit??
    Merci.
    invitefdc34ab3
    Re : odd/even effect
    tu lis un article sur quel sujet ?
    invitefaa6af90
    voila l'abstract
    "In this study, the interdependence between molecular architecture and photo-polymerization is evaluated for self-assembled monolayers containing diacetylenes. While such assemblies provide added robustness and versatility in molecular design, direct surface-attachment significantly limits the degrees of freedom within the monolayer structure. As a result, the polymer conjugation length as evidenced by the chromatic properties cannot be directly predicted from the extensive literature on Langmuir–Blodgett (LB) films. Indeed, a clear odd/even effect is observed in the polymerization properties of these surface-confined monolayers that is not evident in LB systems. Odd-numbered methylene spacers between the surface and the polymer backbone lead to the longer conjugation length blue form, whereas even-numbered spacers yield the shorter conjugation length red phase. This observation is consistent with simple modeling that indicates a release in localized strain upon polymerization for the odd-numbered spacer architectures. While spacers of both 5 and 9 methylene unit yield similar conversion efficiency to the blue-phase polymer, the kinetic profiles with UV exposure are quite different. The longer conversion times for the shorter spacer are attributed to lower freedom of movement within the monolayer to achieve the spatial alignment required for the topochemical polymerization."
    invitefdc34ab3
    si tu regardes l'article en question, la chaine alkyle porteuse de l'atome de soufre a 4, 5 ou 6 carbones.
    les auteurs observent des effets sur les spectres IR et raman en fonction du nombre pair ou impair de carbones... c'est tout. je pense que c'est quelque chose de spécifique à leur étude...
  1. l´effet Odd-Even
    Par Bartolomeo dans le forum Physique
    Dernier message: 02/12/2009, 14h28
  2. mpemba effect
    Par invite5ad8e560 dans le forum Physique
    Dernier message: 21/05/2005, 14h24
  3. Salt out Effect et protéines
    Par invite2f0f2f6d dans le forum Chimie
    Dernier message: 01/12/2004, 19h39
