Gillesh voilà d'où vient la courbe PS (lien direct).
http://books.nap.edu/books/030910225...08c0g79001.jpg
Avec sa légende :
FIGURE 8-2 Here, six climate reconstructions have been used to predict ground subsurface temperature. For each curve in the upper panel, the temperature reconstruction is used as the surface temperature for a thermal model to predict the temperature at depth. The top panel shows the six reconstructions, with zero defined as the 1961–1990 mean. The reconstruction shown in black (labeled POM-SAT) uses the borehole temperatures to constrain the Pre-Observational Mean (POM) and uses the instrumental temperature record from 1856 onward. The measured subsurface temperature pattern (bottom panel, black circles) is explained almost perfectly by the instrumental record and preceding cool centuries (black curve in the top panel). SOURCE: Harris and Chapman (2001). Reproduced by permission of American Geophysical Union; copyright 2001.
. C'est manifestement un filtre très passe-bas, et je doute effectivement qu'on arrive à dire quoi que ce soit de sensé sur les variations multidécennales naturelles (qui me donnent l'impression d'etre un paramètre clé à connaitre pour le soustraire proprement du signal anthropique)
