pic 16f877A et capteur sht75
    invite78234403
    j'ecris ce code et je simule avec proteus isis mais rien se passe
    #include "16F877A.h"
    #use delay(clock=1M)
    #byte PORTB=0x06
    #byte PORTC=0x07
    #byte TRISB=0x86
    #byte TRISC=0x87
    /*SHT75 Sensor Macros*/
    #bit SCL=PORTB.0 // Serial Clock pin
    #bit SDA=PORTB.1// Serial Data pin
    #bit SCL_DIRECTION=TRISB.0
    #bit SDA_Direction=TRISB.1
    #int_timer0
    INT i;
    #define MEASURE_TEMPERATURE 0x03
    #define MEASURE_RELATIVE_HUMIDITY 0x05
    /*SHT75 Temperature and Humidity Sensor Functions*/
    void SHT75_Reset(void);
    void SHT75_Transmission_Start(void) ;
    void SHT75_MCU_ACK(void);
    unsigned long Measure_SHT75(unsigned char command);
    unsigned long Measure_SHT75_Temperature(void );
    unsigned long Measure_SHT75_Relative_Humidit y(void);
    unsigned long Measure_True_Humidity(unsigned long SHT75_temperature,unsigned long SHT75_Relative_Humidity);
    /*************SHT75 Constants For Calculation************/
    const unsigned int C1 = 205;
    const unsigned int C2 = 367;
    const unsigned int C3 = 16;
    const unsigned int D1 = 4010;
    const unsigned int D2 = 1;
    const unsigned int T1 = 1000;
    const unsigned int T2 = 8;
    SHT75 Global variables
    unsigned long SORH; //This is used to Calculate the True_Humidity
    void main()
    //setup_timer_0 (RTCC_DIV_4|RTCC_INTERNAL);//fe=4096000/4/4/256=1kHz
    //enable_interrupts(INT_TIMER0);
    // enable_interrupts(GLOBAL);
    void SHT75_Reset()
    unsigned char i;
    SCL = 0;
    SDA_Direction = 1;// Define SDA as input to pull the DATA line high
    for (i = 1; i <= 20; i++)// repeat 18 times
    SCL = ~SCL;// invert SCL
    void SHT75_Transmission_Start()
    SDA_Direction = 1; //data Line High Pulled Up Resistor
    SCL = 0;
    Delay_us(1);
    SCL = 1;
    SDA_Direction = 0; //Make Data line as Output pin
    SDA = 0;
    Delay_us(1);
    SCL = 0; //SCL Low
    Delay_us(1);
    SDA = 0; //SDA Still Low
    Delay_us(1);
    SCL = 1;
    Delay_us(1);
    SDA_Direction = 1; //Pull High the Line
    SDA = 1; //Not Required
    Delay_us(1);
    SCL = 0;
    void SHT75_MCU_ACK()
    SDA_Direction = 0;
    SDA = 0;
    SCL = 1;
    Delay_us(1);
    SCL = 0;
    Delay_us(1);
    SDA_Direction = 1;
    unsigned char i,j;
    unsigned long k;
    j = command;
    SCL_Direction = 0;
    SHT75_Reset();
    SHT75_Transmission_Start();
    k = 0;
    SDA_Direction = 0;
    SCL = 0;
    for(i = 1; i <= 8; i++)
    if ((j & 0x80) == 0x80)
    SDA_Direction = 1;
    else
    SDA_Direction = 0;
    SDA = 0;
    Delay_us(1);
    SCL = 1;
    Delay_us(1);
    SCL = 0;
    j <<= 1;
    SDA_Direction = 1;
    SCL = 1;
    Delay_us(1);
    SCL = 0;
    Delay_us(1);
    while (SDA == 1);
    //Time to Read 2-Bytes from the Sensor
    for (i = 1; i <=16; i++)
    k <<= 1;
    SCL = 1;
    if (SDA == 1)
    k = k | 0x0001;
    SCL = 0;
    if (i == 8 )
    SHT75_MCU_ACK(); //Send Ack from Micro to Sensor
    return k; //Return value For calculations
    unsigned long SHT75_Temperature;
    SHT75_Temperature = Measure_SHT75(MEASURE_TEMPERAT URE);
    if(SHT75_Temperature>D1)
    SHT75_Temperature = D2*(SHT75_Temperature) - D1 ;
    else
    SHT75_Temperature = D1 - D2*(SHT75_Temperature);
    return (SHT75_Temperature);
    unsigned long SHT75_Relative_Humidity;
    long temp;
    This will Return SOt see Section 4.3 of SHT75 Datasheet
    SHT75_Relative_Humidity = Measure_SHT75(MEASURE_RELATIVE _HUMIDITY);
    SORH = SHT75_Relative_Humidity; //Used to Calculate the True Humidity
    //Thats why the above variable is declared as Global Variable
    temp = SHT75_Relative_Humidity*SHT75_ Relative_Humidity;
    temp = temp/100000;
    temp = temp*C3;
    SHT75_Relative_Humidity = C2*SHT75_Relative_Humidity/100;
    SHT75_Relative_Humidity = SHT75_Relative_Humidity - temp;
    SHT75_Relative_Humidity = SHT75_Relative_Humidity - C1;
    This Code is Highly Accurate and Efficient
    return SHT75_Relative_Humidity;
    unsigned long Measure_True_Humidity(unsigned long SHT75_Temperature,unsigned long SHT75_Relative_Humidity)
    long SHT75_True_Humidity;
    long temp;
    SHT75_True_Humidity = (long)SHT75_Temperature - 2500;
    temp = T1 + T2 * SORH;
    temp = temp/100000;
    SHT75_True_Humidity = SHT75_True_Humidity + temp + SHT75_Relative_Humidity;
    return SHT75_True_Humidity;
    pouvez vous m'aider S.V.P
    invitee05a3fcc
    Re : pic 16f877A et capteur sht75
    Tu as les lettres J i c u e o b m n et r sur ton clavier ?
    invite78234403
    j'ai pas compris
    invitee05a3fcc
    Citation Envoyé par puzzlou Voir le message
    j'ai pas compris
    C'est bien dommage .....
    invite78234403
    ok pas de problème et désolé si ma question n'est pas à la hauteur
  1. SHT75 envoie un signal inutilisable
    Par invite5820f017 dans le forum Électronique
    Dernier message: 25/05/2011, 14h47
  2. Code en C pour PIC avec Sensirion SHT75 / SHT71
    Par invitedd558ae9 dans le forum Électronique
    Dernier message: 13/04/2010, 22h50
  3. Sht75 Pic16f876 récupérer les informations
    Par invitef9035af2 dans le forum Électronique
    Dernier message: 20/01/2010, 22h48
  4. pic 16F877A
    Par invite636b8579 dans le forum Électronique
    Réponses: 22
    Dernier message: 01/04/2009, 15h00
  5. pic 16f877a
    Par invited2ae1532 dans le forum Électronique
    Dernier message: 01/02/2008, 10h49
