particle and three slits + one detector experiment
    invitea4c39ff2
    Hello everybody,
    What would happen if in the Young's two slit experiment is done with three slits and at only one slit some sort of particle detecting or particle tagging device is placed and at the remaining slits no means of particle detecting is introduced.
    I know the results of two slits with and without one or two detectors. But in this other scenario I imagine that perhaps a third of the particles shot will read on the detector and will land without an interference pattern, and the others will go undetected and will land with some kind of interference pattern between the other two slits. But I’m wondering if the presents of a single detector will foul the whole thing up somehow ending with no interference pattern result at all. Answering this question will help my thinking on the slit issue a lot.
    Many thanks
    invite6dffde4c
    Re : particle and three slits + one detector experiment
    Hi!
    Is the English text in a French forum a remainder of April Fools' day?
  1. overvoltage detector
    Par invite37d910a0 dans le forum Électronique
    Dernier message: 12/01/2010, 15h40
  2. Philadelphia expériment .Ouverture des portes temporelles.
    Par invitecc4b9066 dans le forum Discussions scientifiques
    Dernier message: 31/05/2009, 23h06
  3. Infos sur la PIV (Particle Imaging Velocimetry)
    Par invite14cc36bb dans le forum Physique
    Dernier message: 11/05/2009, 14h03
  4. Gravity Recovery and Climate Experiment(GRACE)
    Par invite9b3f90ce dans le forum Astronautique
    Dernier message: 04/03/2009, 12h06
