Le tube de Rijke
Le tube de Rijke
    invited66333b9
    Red face Le tube de Rijke
    Bonjour! J'ai trouvé un document super interessant sur le tube de Rijke, un phénomène dont j'étudie actuellement la théorie, mais il est en Anglais, j'ai pas trouvé la traduction, et les "google traduction" etc me sortent des phrases qui n'ont pas de sens. J'ai besoin de quelqu'un qui s'y connait et en physique et en anglais (je sais, je demande trop ) qui pourrait me traduire ce texte, ou bien seulement traduire ce qu'il juge me sera necessaire. Merci beaucoup de votre aide
    The sound comes from a standing wave whose wavelength is about twice the length of the tube, giving the fundamental frequency. Lord Rayleigh, in his book, gave the correct explanation of how the sound is stimulated.[7] The flow of air past the gauze is a combination of two motions. There is a uniform upwards motion of the air due to a convection current resulting from the gauze heating up the air. Superimposed on this is the motion due to the sound wave.
    For half the vibration cycle, the air flows into the tube from both ends until the pressure reaches a maximum. During the other half cycle, the flow of air is outwards until the minimum pressure is reached. All air flowing past the gauze is heated to the temperature of the gauze and any transfer of heat to the air will increase its pressure according to the gas law. As the air flows upwards past the gauze most of it will already be hot because it has just come downwards past the gauze during the previous half cycle. However, just before the pressure maximum, a small quantity of cool air comes into contact with the gauze and its pressure is suddenly increased. This increases the pressure maximum, so reinforcing the vibration. During the other half cycle, when the pressure is decreasing, the air above the gauze is forced downwards past the gauze again. Since it is already hot, no pressure change due to the gauze takes place, since there is no transfer of heat. The sound wave is therefore reinforced once every vibration cycle, and it quickly builds up to a very large amplitude.
    This explains why there is no sound when the flame is heating the gauze: all air flowing through the tube is heated by the flame, so when it reaches the gauze, it is already hot and no pressure increase takes place.
    VirGuke
    Re : Le tube de Rijke
    Le son vient d'une onde stationnaire entretenue par la source de chaleur.
    Le mouvement de l'air est la somme d'un mouvement constant de convection dû au réchauffement de l'air et d'un mouvement sinusoïdal beaucoup plus rapide dû à l'onde stationnaire.
    Le point important est que la pression de l'air augmente quand il est chauffé et ce d'autant plus qu'il est froid au début. L'air au dessus de la source de chaleur est déjà chaud, car il vient de passer par la source.
    Pendant la phase de détente du maximum de pression jusqu'au minimum de pression, l'air provient d'au-dessus de la source, poussé par l'onde stationnaire. Il est déjà chaud donc sa pression varie peu.
    Pendant la compression, l'air va dans le sens inverse, une grande partie vient juste de passer dans l'autre sens juste avant et est donc déjà chaud donc ne change pas de pression. Cependant, pendant ce cycle, l'ensemble s'est légèrement déplacé vers le haut, à cause de la convection, si bien que tout à la fin du cycle, une partie d'air frai entre en contact avec la source. Comme il était froid, sa température et sa pression augmentent brutalement, apportant un surplus de pression ce qui entretien l'onde.
    invited66333b9
    Bonjour, merci beaucoup de votre aide!
    mais il ya certaines choses que j'ai pas très bien comprises si vs le permettez
    Pourquoi si la tranche d'aire déjà chaude, alors sa pression variera peu lors de la "détente" ?
    de même pourquoi si la température est basse alors elle augmente brutalement (une fois en contact de la source de chaleur?) et en quoi ça entretient l'onde?
    Merci encore une fois
    invited66333b9
    pour les deux premieres questions est ce en rapport avec l'allure du diagramme en P,T de l'air (ou de l'azote) ?
  1. Interférence amplificateur a Tube et écran a tube cathodique
    Par invite99f54725 dans le forum Électronique
    Dernier message: 03/08/2013, 13h17
  2. [Biologie Cellulaire] différence entre tube neural et tube nerveux
    Par invite8b22398f dans le forum Biologie
    Dernier message: 18/12/2010, 10h45
  3. Réponses: 11
    Dernier message: 03/07/2010, 14h01
  4. Bille dans un tube tournant, réaction du tube sur la bille.
    Par invite0c5534f5 dans le forum Physique
    Dernier message: 28/05/2009, 14h11
  5. tube neon // tube fluo
    Par invite37693cfc dans le forum Technologies
    Réponses: 35
    Dernier message: 05/05/2008, 17h54
