Mission sur la Lune Physique Newtonienne ou RG
    FERPOR
    Dans le cadre d'envoyer des humains sur la lune, est-ce que les calculs sont suffisants en utilisant la mécanique classique (Newtonienne) ou bien est-il obligé de passer la des calculs en RG?
    GBo
    Re : Mission sur la Lune Physique Newtonienne ou RG
    Les équations de Newton suffisent en principe mais pour les missions Artemis (missions de longue durée avec orbiteur lunaire etc..) il faut un temps plus précis que pour Apollo et donc on tient compte des effets relativistes:
    The development of a common, consolidated, and consistent time distribution architecture for the Artemis enterprise is documented within this paper with a focus on the implementation challenges and concerns specific to lunar-centric timing systems. A summary of the short-term and long-term needs is presented to provide context for the sensitivity to time knowledge accuracy. Coordinating time across mission operation centers separated by large distances and under the influence of different gravitational fields adds complexity to the clock synchronization process, yet is necessary to achieve the navigation accuracy and meet Moon to Mars objectives. While initial missions are expected to have limited sensitivity to time knowledge uncertainty, long-term use cases and infrastructure become increasingly reliant on tight timing synchronization. To address this, the Artemis missions are projecting to initially use mathematical representations of lunar time for surface system operations by the second lunar surface mission. As communication and position, navigation, and time (PNT) infrastructures are deployed, they form the basis for broad time dissemination and synchronization, shifting the burden from the lunar user and the dependence away from terrestrial operators. The use of a consistent lunar time scale through a unified distribution network will enable the long-term exploration goals laid out for lunar science and exploration. As on Earth, a realizable uniform time scale will lower the barrier to entry to encourage a lunar ecosystem.
    Source de l'abstract:
    "Synchronizing Watches between Earth and Moon: Development, Implementation, and Challenges of Artemis Integrated Timing Architecture"
    https://ntrs.nasa.gov/citations/20250005289
    Dernière modification par GBo ; 06/01/2026 à 19h18.
    FERPOR
    Merci pour la réponse documentée
    ThM55
    Pour leurs sondes interplanétaires, mais aussi pour tous les observateurs ou voyageurs du système solaire, les spécialistes du JPL ont établi des éphémérides qui prédisent par le calcul, avec adaptation aux observations, la position de milliers de corps du système solaire. Voici la référence qui décrit ce modèle:
    https://ssd.jpl.nasa.gov/doc/Park.2021.AJ.DE440.pdf
    Pour intégrer les équations du mouvement de ces corps ils utilisent la première approximation post-newtonienne de la relativité générale: voir équation (27). Vous pouvez utiliser leur site qui permet d'extraire des données et aussi de connecter ses propres programmes à leur API. C'est assez différent des éphémérides usuels publiés par les observatoires, leurs méthodes sont spécifiques.
    FERPOR
    Merci c'est très intéressant en effet.
  1. Exercice physique newtonienne
    Par invitec8093774 dans le forum Physique
    Dernier message: 14/01/2017, 19h42
  2. La mécanique Newtonienne et la physique du saut
    Par invite93279690 dans le forum Physique
    Dernier message: 15/10/2015, 19h15
  3. Réponses: 0
    Dernier message: 07/12/2011, 23h00
  4. physique newtonienne
    Par invite1a4e1a97 dans le forum Physique
    Dernier message: 01/05/2011, 22h07
  5. vulgarisation:physique newtonienne,relativité et physique quantique
    Par invite2593aa43 dans le forum Lectures scientifiques
    Dernier message: 04/10/2007, 19h26
