STM32F4 - Décalage d'un signal PWM
    invite9cc9ad42
    J'ai programmé un signal PWM utilisant le port PB4 avec le timer TIM3 dans mon STM32F4 Discovery
    Code:
    int main (void)
    while(1)
    TIM3->CCR1 = 1000 ;
    /*____________________________TIM3______________________________*/
      /* TIM3 clock enable */
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
      /* GPIOB Clock  */
      RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_0 | GPIO_Pin_1;
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
      GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
      GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
      GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
      GPIO_Init(GPIOB, &GPIO_InitStructure);
      GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_TIM3);
      GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_TIM3);
      GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_TIM3);
      GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_TIM3);
    //________________________________________________________________
    /*__________________________TIM3____________________________________*/
      /* Time base configuration */
      TIM_TimeBaseStructure.TIM_Period = 1999;
      TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
      TIM_TimeBaseStructure.TIM_ClockDivision = 0;
      TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
      TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
      /* PWM1 Mode configuration: Channel1 */
      TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
      TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
      TIM_OCInitStructure.TIM_Pulse = 0;
      TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
      TIM_OC1Init(TIM3, &TIM_OCInitStructure);
      TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
      /* PWM1 Mode configuration: Channel2 */
      TIM_OC2Init(TIM3, &TIM_OCInitStructure);
      TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
      /* PWM1 Mode configuration: Channel3 */
      TIM_OC3Init(TIM3, &TIM_OCInitStructure);
      TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
      /* PWM1 Mode configuration: Channel4 */
      TIM_OC4Init(TIM3, &TIM_OCInitStructure);
      TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
      TIM_ARRPreloadConfig(TIM3, ENABLE);
      /* TIM3 enable counter */
      TIM_Cmd(TIM3, ENABLE);
    Ce programme donne un signal PWM à 50%
    Je veux décaler ce signal PWM en temps
    avec une période T réglable
    Quel paramètre dois je changer ?
    J'ai essayé de varier TIM_ClockDivision qui était initialement
    TIM_TimeBaseStructure.TIM_Cloc kDivision = 0;
    de 0 à 1 le signal se décale mais par une valeur T que ne le connais pas et elle n'est pas réglable
    Quel est l'intervalle de variation de ce paramètre ClockDivision s'il vous plaît ?
    sly37
    Re : STM32F4 - Décalage d'un signal PWM
    Alors j'ai pas tout comprit à ta demande mais je peux t'expliquer les réglages possibles sur ce genre de Timer.
    Dans une PWM tu peux régler la fréquence du signal et le rapport cyclique.
    La fréquence ou période est réglable par "TIM_TimeBaseStructure.TIM_Per iod =..."
    Le rapport cyclique est réglable par "TIM_OCInitStructure.TIM_P ulse =..."
    Ce rapport cyclique ne s'exprime pas en % mais il reçoit une valeur comprise entre 0 et TIM_Period.
    Les registres TIM_Prescaler et TIM_ClockDivision sont initialisés en début de programme pour fixer le cadencement de ton timer.
    Si tu agis sur un des deux pour faire varier la PWM, ça ne marchera pas. Par ce principe tu fais varier la période mais avec des bonds énormes !
    En cours de déroulement du programme tu peux modifier la valeur de PWM par "TIM3->CCR1=..." pour la voie 1 par exemple.
    Je ne sais pas si tu débute mais ton programme n'est pas bien structuré
    Bon courage pour la suite.
    Dernière modification par sly37 ; 10/01/2013 à 11h31.
    invite9cc9ad42
    Merci pour votre réponse,
    Je sais que les réglages possibles sont la période et le rapport cyclique.
    Mais la tache que je vais l'effectuer est de décaler le signal d'une période T
    J'ai programmé le signal 1 et je veux le décaler pour être comme le signal 2 voila !
    Nom : images.jpeg
Affichages : 582
Taille : 6,9 Ko
    Je veux juste savoir sur quel paramètre peux je jouer ?
    par exemple j'ai essayé de changer dans PWM configuration le mode
    TIM_OCInitStructure.TIM_Output State = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OCPola rity = TIM_OCPolarity_High;
    De PWM1 à PWM2 je trouve que le signal est devenu inversé
    il était 00000 11111 00000 11111 .... avec PWM1
    mais avec PWM2 --> 11111 00000 11111 0000
    voila
    le décalage que je demande que le signal sera de la forme suivante 000 00000 11111 00000 11111
    j'espère que ma demande est clair ...
    sly37
    je suis désolé d'être aussi ignorant Taeway mais je ne comprends pas ta demande.
    Un chronogramme de ce que tu veux STP.
    Saches qu'avec ce µC on peut quasiment tout faire donc ne t'inquiète pas sur la solution, le tout c'est de se comprendre !
    invite9cc9ad42
    Je vous ai montré le chronogramme mon ami
    J'ai généré le signal 1 de la photo je veux avoir le signal 2
    Nom : images.jpeg
Affichages : 573
Taille : 6,9 Ko
    Je souhaite retarder la réponse de signal dans le temps par une période T variable
    sly37
    D'après tes chronos tu veux déphaser tes signaux en paramétrant le déphasage, c'est ça ?!
    invite9cc9ad42
    Oui exactement !
    sly37
    Après petite réflexion, une des solutions serait de faire une PWM sur une sortie 1 telle que tu le fais ci-dessus.
    ça te fait la première sortie, pour la 2nd il faut utiliser le mode "One Pulse Mode".
    Ce mode permet de générer un pulse sur une sortie à partir d'un Trig interne ou externe.
    Gros intérêt puisque tu prends ta 1ère PWM comme Trig interne, donc ta sortie 2 sera forcément cadencée à partir de la PWM.
    Et surtout avec ce mode tu peux gérer le "deadtime" de manière très simple à partir d'un registre.
    Je te laisse te documenter sur ce mode et reviens vers nous si tu vois pas la solution.
    invite9cc9ad42
    J'ai pensé qu'il y a un petit réglage à faire sur les paramètres de Timer pour arriver à mon objectif
    Je vais voir le principe du mode "One Pulse Mode" et comment l’implémenté pour générer le deuxième signal dont signal 1 va être son Trig interne.
    Je vous tient au courant
    invite9cc9ad42
    Excuser moi pour le dérangement
    Mais je n'ai pas compris la différence en chronogramme entre un signal PWM et un signal One-Pulse PWM Mode :-/
    En plus que les exemples que je trouve utilise presque le même algorithme de Pwm que j'ai utilisé, ils changent juste les paramètre de TIM_OCInitStructure.TIM_Pulse = 0; de 0 à une valeur ..
    donc je n'ai pas pu avancer .
    sly37
    Nom : Exemple1.jpg
Affichages : 578
Taille : 28,1 Ko
    Une partie de ce que j'ai déjà essayé sur un projet.
    Si ça t'intéresse je te file le code mais ces sorties ne conviennent peut être pas.
    invite9cc9ad42
    Merci pour le chronogramme.
    Pouvez vous me donner le code pour essayer d'avoir la sortie désirée.
    sly37
    Voici un bout de code dont je me suis servis il y a quelques temps.
    Je ne peux pas le tester actuellement, mais s'il ne marche pas chez toi je t'expliquerai comment faire pour t'en sortir.
    Il suffit de configurer tes propres ports pour ça marche.
    L'idée générale c'est de générer une PWM à partir d'une timer quelconque, puis de capturer cette PWM sur une entrée timer qui accepte le trig et ensuite de faire coincider la sortie OnePulse avecette entrée.
    Courage chez moi ça fonctionne très avec 3 sorties utilisées en OnePulseMode.
    /*----- Config sortie PWM : PA8 TIM1.CH1 -----*/
    void Init_PWM_PA8(void)
    /* Time Base configuration */
    TIM_TimeBaseStructure.TIM_Pres caler = 0;
    TIM_TimeBaseStructure.TIM_Coun terMode = TIM_CounterMode_Up;
    TIM_TimeBaseStructure.TIM_Peri od = gConsig.PeriodPWM;
    TIM_TimeBaseStructure.TIM_Repe titionCounter = 0;
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
    /* Configuration in PWM mode */
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
    TIM_OCInitStructure.TIM_Output NState = TIM_OutputNState_Disable;
    TIM_OCInitStructure.TIM_Pulse = gConsig.RapportVari;
    TIM_OCInitStructure.TIM_OCPola rity = TIM_OCPolarity_Low;
    TIM_OCInitStructure.TIM_OCNPol arity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdle State = TIM_OCIdleState_Set;
    TIM_OCInitStructure.TIM_OCNIdl eState = TIM_OCIdleState_Reset;
    TIM_OC1Init(TIM1, &TIM_OCInitStructure);
    /* TIM1 counter enable */
    TIM_Cmd(TIM1, ENABLE);
    /* TIM1 Main Output Enable */
    TIM_CtrlPWMOutputs(TIM1, ENABLE);
    /*----- Config sortie du One Pulse Mode -----*/
    void Init_OP_PA2(void)
    TIM_TimeBaseStructure.TIM_Peri od = gConsig.ValPeriod;
    TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
    /* TIM2 PWM2 Mode configuration: Channel1 */
    TIM_OCInitStructure.TIM_Pulse = gConsig.ValDelai;
    TIM_OC3Init(TIM2, &TIM_OCInitStructure);
    /* Input Capture Mode sur PA0 : TIM2.CH1 */
    TIM_ICStructInit(&TIM_ICInitSt ructure);
    TIM_ICInitStructure.TIM_Channe l = TIM_Channel_1;
    TIM_ICInitStructure.TIM_ICPola rity = TIM_ICPolarity_Rising;
    TIM_ICInitStructure.TIM_ICSele ction = TIM_ICSelection_DirectTI;
    TIM_ICInitStructure.TIM_ICPres caler = TIM_ICPSC_DIV1;
    TIM_ICInitStructure.TIM_ICFilt er = 0;
    TIM_ICInit(TIM2, &TIM_ICInitStructure);
    /* génération du One Pulse Mode sur PA2 : TIM2.CH3 */
    TIM_SelectOnePulseMode(TIM2, TIM_OPMode_Single);
    /* Input Trigger selection PA8 : TIM1 CH1 */
    TIM_SelectInputTrigger(TIM2, TIM_TS_TI1FP1);
    /* Slave Mode selection: Trigger Mode */
    TIM_SelectSlaveMode(TIM2, TIM_SlaveMode_Trigger);
  1. Division d'un signal PWM
    Par invite8cad5ce2 dans le forum Électronique
    Dernier message: 21/08/2012, 10h42
  2. Décalage temporel d'un signal acoustique !
    Par invite91b75ae6 dans le forum Électronique
    Dernier message: 12/01/2012, 17h35
  3. amplitude d'un signal pwm
    Par invite68aa31e7 dans le forum Électronique
    Dernier message: 11/02/2010, 14h15
  4. Décalage d'un signal analogique +/- 2.5V vers -600V / -595V
    Par invitea69c1094 dans le forum Électronique
    Dernier message: 23/04/2008, 07h41
  5. Passer d'un signal analogique à un PWM
    Par invite4af455c2 dans le forum Électronique
    Dernier message: 17/04/2006, 11h52
