vhdl-ams
vhdl-ams
    inviteca3df33a
    vhdl-ams
    Bonjour a tous et bonne annee!
    J'essaye de modeliser un comparateur en vhdl-ams sur le logiciel ncvhdl mais je n'arrive pas a corriger les erreurs a la compilation...
    Voici mon code:
    Code:
    --library ieee;
    --use ieee.electrical_systems.all;
    library ieee, disciplines;
    use ieee.std_logic_1164.all;
    use disciplines.electrical_system.all;
    entity comparateur is
     	generic (level : real := 2.5; -- seuil
    		 vcc   : real := 5;   -- etat haut sortie
    		 gnd   : real := 0);  -- etat bas sortie
    	port(terminal e, ref: electrical;  -- entree analogique
                        signal   s: out std_logic); -- sortie numerique
    end comparateur;
    architecture archi of comparator is
    quantity v across e;       -- across quantity to ground
    begin
          s <= `1' when v'Above(level) -- v > level
          else `0';                    -- v < level
    end architecture;
    Voici mes erreurs:
    ncvhdl -work st_lib -message ../sources/comparateur_ent.vhdl
    ncvhdl: 13.10-s013: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
    ../sources/comparateur_ent.vhdl:
    ncvhdl_p: *E,MISCOL (../sources/comparateur_ent.vhdl,14|15): expecting a colon (':') 87[4.3.3] 93[4.
    3.2].
    architecture simple of comparator is
    ncvhdl_p: *E,ENNOFN (../sources/comparateur_ent.vhdl,19|32): Intermediate file for entity 'COMPARATO
    R' could not be loaded, entity may require re-analysis.
    ncvhdl_p: *E,EXPBEG (../sources/comparateur_ent.vhdl,19|37): expecting the reserved word 'BEGIN' [1.
    2].
    ncvhdl_p: *E,UNKCCS (../sources/comparateur_ent.vhdl,21|9): unknown concurrent statement [9].
    ncvhdl_p: *E,UNKCCS (../sources/comparateur_ent.vhdl,21|11): unknown concurrent statement [9].
    ncvhdl_p: *E,UNKCCS (../sources/comparateur_ent.vhdl,21|18): unknown concurrent statement [9].
    ncvhdl_p: *E,EXPEND (../sources/comparateur_ent.vhdl,21|21): expecting the reserved word 'END' [1.2]
    ncvhdl_p: *E,ILLPRI (../sources/comparateur_ent.vhdl,25|10): expecting an expression or operand [7.1
    ] [7.3].
    end architecture;
    ncvhdl_p: *E,EXPACN (../sources/comparateur_ent.vhdl,28|16): expecting an architecture name [1.2].
    errors: 9, warnings: 0
    En fait quand je regarde sur internet il y a plein de librairies differentes pour cette extension du vhdl, peut etre que je n'utilise pas les bonnes, peut etre qu'il y a des librairies specifiques au logiciel que l'on utilise. Comme vous le voyez je suis perdu, toute aide serait la bienvenue. Merci d'avance!
    Re : vhdl-ams
    Donc en fait sans sourciller on compare un truc de nature "electrical" inconnue au bataillon avec des real?
    Il faudrait au moins le package décrivant ce ou ces types.
    inviteca3df33a
    Re : vhdl-ams
    Le type electrical devrait normalement etre "compris" par le compilateur grace a la librairie electrical_system non ? Je suis d'accord pour les real, je les ai oublie! Je vais voir ce que ca donne avec ca.
    Ps: connaitriez vous un site ou je pourrai trouver tous les packages utile en vhdl et vhdl-ams?
  1. Vhdl
    Par invitefcc1b3ac dans le forum Électronique
    Dernier message: 15/11/2010, 19h43
  2. Vhdl
    Par invite68aa31e7 dans le forum Électronique
    Dernier message: 07/07/2009, 22h11
  3. Vhdl
    Par invite35890bd8 dans le forum Électronique
    Dernier message: 09/12/2008, 21h59
  4. Point flottant en VHDL et vhdl-200x
    Par invite6eee6b27 dans le forum Logiciel - Software - Open Source
    Dernier message: 02/09/2008, 19h47
  5. vhdl
    Par invite21ed25dc dans le forum Électronique
    Dernier message: 09/12/2007, 14h29
