capter la tension d'un panneau
    salimhala
    hi !
    i got some problems with my project, and I need some help
    my project is about making a MPPT board which command the converter as just in this following image:
    and I have the circuit of the board but I have to use Proteus ISIS for simulation and so i got some problems with some components on the circuit , let me just put the picture and then explaine my problems:
    so the 1st problem is how to get the Voltage and the curnent values into the tow pins of the PIC µcontroller , am I going to use sensors or what ?? because that's what I think ; I thought that I need a curent sensor and an other one for voltage , can you please tell me if I'm right??! and then i want to know how to make the PIC read those values and then I can use the mikroC program inwhich I have to do some calculations just as the following:
    -configure the PIC registers to do these operations( by the way I'm using PIC18F1220 due to it's performences that have been showen in a report that I've got)
    -read the values of the curent and voltage that comes out of the solar panel as the first image shows.
    -calculate the power (P=Vpv*Ipv) (pv=photovoltaïque)
    -do the previous operation 8 times and then calculate the average of these points of power for more precesion ( otherwise we can just use the first calculated power)
    -compare the first calculated power with the next one so we can get a derivative which could be >0 or <0 and basing on that and also on the status of alpha which is the PIC output signal that can take the value 1 or 0
    -this signal is going to be compared with another signal coming from the NE555 on the circuit via an Ampli LM311 which generate another signal tha goes to command the converter DC/DC shown on the first image
    the program that i got also from the same report is just as follows (after some little modifications ):
    Code:
    int i,H;
    unsigned int tension_haute,tension_conv,tension_haute_totale;
    unsigned char tension_faible,intensite_faible;
    unsigned int intensite_haute,intensite_conv;
    unsigned int intensite_haute_totale,tension_panneau;
    unsigned long puissance,ancienne_puissance,puissance_totale;
    unsigned int m;
          //   /* I didn't get it from this part till... !!!
    void traiteIT(void);
    #pragma code it=0x08
    void saut_sur_spIT(void)
    _asm
        goto traiteIT
    _endasm
    #pragma code
    #pragma interrupt traiteIT  */
    //////////////////////////////////////// debut
     void interrupt(void)
         if(INTCON.TMR0IF)
         INTCON.TMR0IF=0;
         H=1;
         T0CON.TMR0ON=0;
    }      //....till this line/////////////////  fin      &&  still didn't get it !!   /
    //////////////// debut de fonction qui configure les registres
    void configurer_registres(void)
    i=0;
    m=0;
    H=1;
    puissance=0;
    ancienne_puissance=0;
    ADRESH=0x00;
    ADRESL=0x00;
    WDTCON=0;
    INTCON.TMR0IE=1;
    INTCON.GIEH=1;
    INTCON.TMR0IF=0;
    INTCON2=0x00;
    INTCON3=0x00;
    PIR1=0x00;
    PIE1=0x00;
    IPR1=0x00;
    PIR2=0x00;
    PIE2=0x00;
    IPR2=0x00;
    RCON=0x00;
    T0CON=0x46;
    ADCON1=0x7C;
    ADCON2=0x92;
    PORTA=0x00;
    TRISA=0x03;
    PORTB=0x00;
    TRISB=0x00;
    /////////// ///////Fin de fonction qui configure les registres
    ///////////////////debut de la fonction de conversion d'intensite.
    unsigned int intensite(void)
    intensite_haute=0;
    intensite_haute_totale=0;
    intensite_faible=0;
    for(i=0;i<1;i++)
    {}                //////un peu de retard.
    ADCON0=0x05;
    for(i=0;i<10;i++)  ///un autre retard !! i don't know why the hell is that for!
    ADCON0=0x07;
    while(ADCON0 !=0x05)
    intensite_haute=ADRESH;
    intensite_haute_totale=intensite_haute<<8;
    intensite_faible=ADRESL;
    intensite_conv=intensite_haute_totale+intensite_faible;
    return(intensite_conv);
    //////////////////Fin de la fonction de conversion d'intensite.
    /////////////////////debut ...convesion de tension
    unsigned int tension (void)
    tension_haute=0;
    tension_haute_totale=0;
    tension_faible=0;
    for(i=0;i<1;i++){}
    ADCON0=0x01;
    for(i=0;i<10;i++){}
    ADCON0=0x03;
    while(ADCON0 !=0x01)
    tension_haute=ADRESH;
    tension_haute_totale=tension_haute<<8;
    tension_faible=ADRESL;
    tension_conv=tension_haute_totale+tension_faible;
    return (tension_conv);
    ////////////////////////fin ...convesion de tension
    ///////////////////debut de la fonction de calcul de Puissance
    unsigned long calcul_de_puissance(void)
    unsigned long x,y;
    x=tension(void);
    y=intensite(void);
    puissance_totale=x*y;
    return(puissance_totale);
    //////////////// Fin de la fonction de calcul de Puissance
    ///////////////////debut de la fonction de calcul de Puissance_moyenne
    unsigned long puissance_moyenne(void)
    unsigned long puissance_moyenne_totale,calc_puissance,somme8point_P;
    puissance_moyenne_totale=0;
    calc_puissance=0;
    somme8point_P=0;
    for(m=0;m<8;m++)
    calc_puissance=calcul_de_puissance(void);
    somme8point_P+=calc_puissance;
    puissance_moyenne_totale=somme8point_P>>3;
    return(puissance_moyenne_totale);
    ///////////////////Fin de la fonction de calcul de Puissance_moyenne
    ////////////////////debut de la fonction de calcul de la derivee de Puissance
    unsigned char derivee_de_puissance(void)
    unsigned char derivee;
    unsigned long puissance=0,ancienne_puissance=0;
    puissance=puissance_moyenne(void);
    if(puissance> ancienne_puissance)
                  derivee=1;
                  PORTB.RB0=1;
    else
                  derivee=0;
                  PORTB.RB0=0;
    ancienne_puissance=puissance;
    return(derivee);
    ////////////////////Fin de la fonction de calcul de la derivee de Puissance
    //////////////////////debut de programme principal:
    void main() {
    unsigned char derivee_de_P;
    int v;
    configurer_registres();
    tension_panneau=tension();
    if(tension_panneau<0x2B9)
                             PORTB.RB1=1;
    else
                             PORTB.RB1=0;
    while(1)
            derivee_de_P=derivee_de_puissance();
            if((derivee_de_P==1)&&(PORTB.RB1==1))
                                                     PORTB.RB1=1;
            else if((derivee_de_P==0)&&(PORTB.RB1==1))
                                                          if(H==0)
                                                          PORTB.RB1=1;
                                                          else
                                                          PORTB.RB1=0;
                                                          H=0;
                                                          T0CON.TMR0ON=1;
            else if((derivee_de_P==1)&&(PORTB.RB1==0))
                                                          PORTB.RB1=0;
            else if((derivee_de_P==0)&&(PORTB.RB1==0))
                                                          if(H==0)
                                                          PORTB.RB1=0;
                                                          else
                                                          PORTB.RB1=1;
                                                          H=0;
                                                          T0CON.TMR0ON=1;
            else{}
     v=PORTB.RB1;
    Lcd_Init();
    Lcd_out_cp(v);
    //////////////////////////////fin de programme principale.
    the rest of the program , .. i guess I understanded it so if you can help me with this ( by the way I'm using MikroC and ISIS 8 for simulation)
    i don't have much time left so please help me with this , I do apriciate your help and thanks
    Tropique
    Re : problems with MPPT solar charger controller(using PIC18F1220)
    Hi Salimhala, and welcome,
    I remind you that french is the official language of Futura, and all transactions have to be carried out in this language.
    If you don't stick to this rule for your next posts, the topic will have to be closed.
    Also note that there are many more english-speaking forums than for any other language, including french, and you shouldn't have difficulties finding a suitable one: EDAboard, etc.
    salimhala
    d'accord ;
    maintenant j'ai un autre problemme c'est que je peut pas pas trouver un composant sur ISIS qui est "solar cell" et je connais pas la referance pour telecharger son librerie si vous pouvez m'aider et aussi je veut savoir la maniere à calculer le gain d'un circuit , mon cas est de deux ampli operationels un montage inverseur précedé par un suiveur
    salimhala
    capter la tension d'un paneau
    Hi !
    j'ai ce dernier circuit que j'ai parler precedement ,mon encadrant dit que je doit calculer le gain de ce circuit dans cette image ci-desous(ce qui est circulé dansl'image):
    pour mettre la valeur trouvée (du gain) dans le programe suivant:
    Code:
    // Lcd pinout settings
    sbit LCD_RS at RB0_bit;
    sbit LCD_EN at RB1_bit;
    sbit LCD_D7 at RB5_bit;
    sbit LCD_D6 at RB4_bit;
    sbit LCD_D5 at RB3_bit;
    sbit LCD_D4 at RB2_bit;
    // Pin direction
    sbit LCD_RS_Direction at TRISB0_bit;
    sbit LCD_EN_Direction at TRISB1_bit;
    sbit LCD_D7_Direction at TRISB5_bit;
    sbit LCD_D6_Direction at TRISB4_bit;
    sbit LCD_D5_Direction at TRISB3_bit;
    sbit LCD_D4_Direction at TRISB2_bit;
    unsigned long valeur;
    unsigned char d1, d2, d3, d4,*text;
    void main() {
      text = ("tension: ");
      ADCON1=0x82;
      TRISA=0xff;
      lcd_init();
      lcd_cmd(_lcd_cursor_off);
      lcd_cmd(_lcd_clear);
      while(1)
      Lcd_Out(1, 1, text);
      valeur=Adc_Read(1) ;
      valeur=  valeur*100/10;/* cette valeur :100/10 est supposée d'etre le gain, j'ai la mis au hasard dans ce cas*/
      d1= valeur/1000;
      d2=( valeur%1000)/100;
      d3=(( valeur%1000)%100)/10;
      d4=(( valeur%1000)%100)%10;
      lcd_chr_cp(d1+48);
      lcd_chr_cp(d2+48);
      lcd_chr_cp('.');
      lcd_chr_cp(d3+48);
      lcd_chr_cp(d4+48);
      lcd_out_cp(" V");
      Delay_ms(1000);
      Lcd_Cmd(_Lcd_CLEAR);
    concernant ce program si vous pouvez m'expliquer pourqoi d1+48 (par exemple car j'ai essayé autre chiffre differant de 48 et ils ont donné rien dans la simulation)
    leprof m'a dit aussi qu'il suffit de calculer ce gain ,et dans la simulation je peut mettre un montage equivalent , et voila ce que j'ai essayé de faire ,ce qui m'a donné
    quelque chose mais je suis pas sure et je veut savoir quels sont ,en exact, les composants que je vais circuler aussi sur l'image suivante et leurs roles precisemment;
    donc si vous pouvez verifier ce montage , en fin de compte je veut juste mattre une source de courant et la convertit vers une tension qui doit etre inclut dans
    la referance du PIC( <5V) et afficher la tension reelle sur la LCD
    Rq: la simulation est faite par "proteus ISIS" et le program sur "mikroC"
    et merci
    Bonsoir salimhala et tout le groupe
    Citation Envoyé par salimhala Voir le message
    ... maintenant j'ai un autre problème ... je veux savoir la manière à calculer le gain d'un circuit ...
    La charte du forum ne permet pas les doublons, c'est à dire la multiplication des discussions sur un même sujet. Les deux discussions ont été fusionnées.
    Le schéma que tu donnes est un des montages fondamentaux des montages des AOP, dont les formules sont basiques, et que tu dois rechercher dans les sujets qui les traitent.
    C'est à toi qu'il appartient de les trouver, de les comprendre, et de les appliquer. Te les donner serait contre productif.
    Ce gain (plutôt cette amplification), dépend des valeurs des composants utilisés (des résistances) qui ne sont pas spécifiés.
    Edit: à titre d'exemple, voici la première réponse à la demande "formules aop" sur un moteur de recherche:
    http://www.elektronique.fr/cours/AOP...es-de-base.php
    Dernière modification par gienas ; 18/03/2014 à 20h41.
  1. régulateur de tension pour panneau solaire
    Par invite973c289d dans le forum Électronique
    Dernier message: 02/03/2014, 18h14
  2. Augmenter la tension d'un panneau photovoltaique
    Par invite82fa658b dans le forum Technologies
    Dernier message: 02/12/2013, 10h15
  3. Fixer la tension d'alimentation d'un panneau solaire
    Par invite174b3952 dans le forum Électronique
    Dernier message: 30/07/2009, 06h50
  4. chute de tension panneau solaire et moteur?
    Par inviteacf1ad14 dans le forum Électronique
    Dernier message: 12/02/2009, 12h06
  5. caractéristique intensité tension d'un panneau solaire
    Par invitea6d735e3 dans le forum Technologies
    Dernier message: 02/10/2007, 07h33
